Geekman; I'm trying to get my account settled out here, and I'm not quite sure how this all works yet. I see where you're going with your solution, but I need more detail,
  • 9 more comments
  • dustin_bell Sep 29, 2009
    actually it was an error that it came up under printers. I have an Intel Mobile Pentium 4 that is telling me through the "wireless network connection" window that it is connected to the internet, but when I go to pull up my browser, or update my itunes, it tells me the computer can't connect to web
    Awesome, I'm going to print this out and try each of these in succession. I will get back to you when one of them works, (or doesn't work). I appreciate your thorough response. Talk soon.
    solution one did not work.
    Solution two is quite a bit more involved, but I'm getttin to work on it.
    okay,
    I plugged in my grandma's ethernet cable and my connection came right up. I was able to brows. My Operationg system is Windows XP, and I'm not sure who manufactured my wireless card or how I could get that information. I am also not sure if I have a firewall up. I don't believe so, but maybe.
    I haven't been near this lab top in 8 months and I'm trying to get back in working order.
    I don't have any idea what you mean by the "ping command," but I could intuitively fumble through it if you explain further.
    Again, my computer is still telling me it is connected with excellent strength to the wireless network here. I just can't get on the web in spite of this.
    scratch that last message. I just read the second part of your messege where you describe the ping command. I'm currently trying that route.
    first ping127...worked. 4 of 4 returned.
    ping 192.168.0.1 did not work. It sent me back the prompt, "request timed out...." repeated 4 times.
    So, apparently, I can't talk to the router? I'm a moron on all this tech stuff. When my card is receiving a signal it is receiving it from my grandma's wireless modem, isn't it? Modem? Router? Same thing I thought. Please don't laugh, thats why I pay organizations like this to help my pea brain through this stuff.
    What does this last ping failer indicate?
    okay so 1st ping worked, second ping didn't work. the release and renew ipconfigs obveousely didn't work because I've plugged my ethernet back into my grandma's computer to talk with you. I'm trying to Google ping right now.
    I want to mention...several hours ago when I turned my laptop on, and saw that it was getting a wireless signal, as it still is, it was loading the Google default page. When I tried to navigate away it gave me the disconnected page, but then when I closed down and opened back up, it was on the google page again...which is my default for this computer.
    alright, finished with what you've recommended so far.
    1. ping 127.0.0.1 worked.
    2. ping 192.168.0.1/1.1 did not work "request timed out"
    3. ipconfig/release could not be performed while media was disconnected
    4. same with ipconfig/renew, but ethernet connection is not what I'm concerned about.
    5. "pinging www.google.com returned a "ping command couldn't find host," prompt.
    6. "pinging 66.102.9.104 didnt' work either. It returned this messege: "request timed out."
    What the heck is going on here. I need the ether cable for this desk p.c. and I'd like to have my lap top behind me running off of its wireless card as it says it is.
    Thank you for you assisstance, you seeem like a saint.
    RNJ,
    I'm just curious, what might be going on here. I tried those solutions, and none of them seemed to provide the right salve as you can see. My "Wireless Connection Window," is still telling me I'm connected, but I cannot connect to Google, or the web in general.
    Help?
    to make it simple, where do I go within the OS to find out what kind of wireless care I have in here. I bought it off of a buddy, and I've gone through what lump of papers he gave me in the transaction. There is no mention of the wireless card?
    President:
  • 1,462 Answers
Can you clearly explain the query, Are you talking about FixYa account or anything else regarding printers as you selecte the printer category
Please leave it as comment, and we may solve your issue..
RNJ VINODKUMAR
Posted on Sep 29, 2009
  • 3 more comments
  • Vinod Kumar
    Vinod Kumar Sep 29, 2009
    Lets try various things to solve your issue:
    First:
    If the others can access the internet, then we have to assume that the router is connected correctly.
    Therefore it must be the settings on your computer.
    So open Internet explorer - Tools (ALT+T) - Internet Options - Connections (Tab) - It should have 'never dial a connection' selected.
    Hit the Lan Settings button and select 'automatically detect settings', click ok. Now restart the internet explorer and try connecting to Itune and other website and check whether it works
    SECOND:
    What router, wireless card (a/b/g/n), Operating system are you using. Do you use a software firewall which blocks your connection, if so which one?Can you connect to the router using a physical ethernet lead, and if so does the internet work using that? you have to try all these..
    The ping command sends a sonar type ping to another computer/website/router - it's the tool used to identify if your PC can see any other computers. If ping works, you will get a reply like this
    Reply from 66.102.9.104: bytes=32 time=43ms TTL=244
    if it fails, you will get a Request timed out message.
    So we will try ping and check the issue
    Try these command from a Dos prompt (start, run and type cmd (or command)) and post back with the results
    ping 127.0.0.1 - if this works, you have tcp/ip installed (good).
    ping 192.168.0.1 / ping 192.168.1.1 (try both depends on router) - can you talk to the router?
    ipconfig /release - Drop the ip address assigned to your PC
    ipconfig /renew - Pickup a new address from the router.
    ping www.google.com - if this works, but IE doesn't, then this indicates problems with your IE config (Tools/internet options/connections/lan settings screen)
    ping 66.102.9.104 -if this works, but pinging google doesn't, then you have a dns problem (the dns server translates the name google to the ip address, a basic function required for the internet to function)
    Let us know how you get on with all thes results,PLease leave it as comment so we can solve your issue..
    Please leave me comment after trying the above things and we amy solve your issue..
    RNJ VINODKUMAR
  • Vinod Kumar
    Please rate this solution, if it works.Else please leaveme your comment and i may assist in solving your issue
    RNJ VINODKUMAR
  • Vinod Kumar
    Ok..Leave me comment and about you result..I will help you
  • Vinod Kumar
    This could be like this, if your laptop recognizes your grandmas signal rather than the router,you wont able to do that..
    You router cant be pinged, this means you are not connected to the router
    Think your grandma laptop must be visible to you and you would have connected to his laptop...
    And finally Check the standard of the wireless router and your laptop wireless card, FOr eg if your Router is wireless b/g standards then your laptop must have either b or g wireless card..If your router has A standards then your laptop should have A card, If this conflict occurs then you wont able to use the connection from the router..
    Please leave your router name and your Wreless card name, ill check for the conflict and assist you furthur
    RNJ VINODKUMAR
  • Vinod Kumar
    Vinod Kumar Sep 30, 2009
    In the Network connection, you can see the list of network adapters installed for your machine..
    In the wireless network connection icon, Below that you can see the CONNECTED words with the name of your caed, written below that
    Please leave it as comment, we may help you to solve your issue
    RNJ VINODKUMAR
My cousin studied and got settled in United States with a good job. I too want to be like him. But don't know how to proceed. Can someone tell me from where and how to start?
Today, studying in US and getting settled there seems to be quite easy. All you have to do is to browse online. I guess this site will be useful to you - www.worldcolleges.info.
Sep 01, 2014 | Computers & Internet
Does bill consolidation loans for bad credit really work?
If you have bad credit at that point you won't qualify for actual credit where you pay off your financial obligations with a loan from a bank as well as salary that back in month-to-month installments. Debt consolidation typically describes a high-risk practice of financial debt settlement: purposely skipping on your charge card to attempt to force your creditors to settle for less. Stay away from any sort of "financial debt consolidation" professional that guarantees to slash your financial debt as well as repayments in half with debt settlement deal ... This is a high-risk strategy of purposely stopping all payments to creditors as well as requiring your accounts into default to try settlements. You pay a monthly cost to a debt consolidator ... this entire fee goes to building a negotiation account as well as to the consolidator's charges to "settle" your accounts in the future. Your charge card business will deliberately not be paid so that all the accounts will default/charge-off so that they can try settlement deals at around 50 %. If you are present on your accounts, this process will definitely ruin your credit ranking for sure. Financial debt settlement is like a roll off the cubes with your financial resources ... You could never anticipate just how your creditors will answer the thoughtful skipping of your accounts ... they might settle at 50 % ... or they might serve you a summons, take you to court ... and if they earn, you might be considering wage garnishment.
Aug 31, 2012 | Finance
How do i change my payment option from credit card to redemm card??? after my account has been turned off from live do to the fact the creditcard doesnt work any more???
to change the payment option i hate to say it but you need to settle the remaining unpaid bills call xbox billing to settle it and request to remove your credit card from your account then after it is done that is the only time you can switch to a prepaid card.
Jul 25, 2010 | Microsoft Xbox 360 Console
Gud morning sir,i am unable to login my account eventhough i have tried all methods i am finding difficulty in logging in to my account : raghu_75444@yahoo.com is email id its damn urgent for me to gettin...
Go to this page:
https://edit.yahoo.com/forgotroot?done=http%3A%2F%2Fmail.yahoo.com&src=ym&partner=&intl=us
Mark which selection best fits your situation and click Next and follow the prompts.
Thanks for using Fixya.
PS. You should never put your email address on public sites such as this. There are "bots" combing the web looking for just that so they can send you spam.
Wayne
Feb 01, 2010 | Yahoo Mail
Can you help me shop on ebay? I dont have a credit or debit card, what else can i do? Thanks.
YOu can go to http://www.paypal.com and establish an account. It can be linked to your checking or savings account or to a credit or debit card. Your choice. It is a very secure way to deal with online purchases. If there is ever a problem with the buyer then paypal will help you settle the dispute and make sure you get your product or help you get your money back. Most ebay sellers prefer to work with paypal.
Nov 15, 2009 | eBay Auctions
Moved frig then plugged in and ran for several days then quit, then two days later started again and then a week later quit again? Frig is a ten year old side by side Kenmore about 21 sq feet, ice maker...
If you didn't give it enough time for the oil to settle back in the compressor that could be the problem. I would try leaving it off for a day to see if it will settle down and run better.
Sep 30, 2009 | Refrigerators
I need to close this email account
Go to My Account and Delete
Jul 10, 2009 | Yahoo Mail
HI geekman i tried that already it seems my audio device is working fine and all my volumes controls are up
Hi I am Vortash see the solution I set for resnthaver this may also be your problem .... Regards Vortash
Apr 23, 2009 | Lenovo ThinkPad T61 Notebook
Yahoomail configuration in outlook 2003
  • Install YPOPs! and make sure it is running.
  • Open Outlook.
  • Select Tools | E-Mail Accounts... from the menu.
  • Make sure Add a new e-mail account is selected.
  • Click Next >.
  • Check POP3.
  • Click Next >.
  • Type your name under Your Name:.
  • Enter your Yahoo! Mail address under E-mail Address:.
  • Type "localhost" under both Incoming mail server (POP3): and Outgoing mail server (SMTP):.
    • If "localhost" later turns out not to work, you can try "127.0.0.1" instead.
  • Type your Yahoo! ID under User Name:.
    • The Yahoo! ID is also the first part of your Yahoo! Mail address,i.e. everything before "@yahoo.com". If your Yahoo! Mail address is"example@yahoo.com", the ID is "example".
  • Enter your Yahoo! Mail password under Password:.
  • Click More Settings ....
  • Go to the Outgoing Server tab.
  • Make sure My outgoing server (SMTP) requires authentication is checked.
    • Leave Use same settings as my incoming mail server selected.
  • Click OK.
  • Now click Next >.
  • Click Finish.
Oct 24, 2008 | Microsoft Outlook 2003 for PC
177 people viewed this question
jasbo
jasbo
