Question about Toshiba 43A10 43" Rear Projection Television
Convergence the convergence is off, but only in the upper-right corner. Also, it is sort of a line that runs horizontal approx. 9 inches.
    President:
  • 4,402 Answers
Bad convergence amp ics
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 19, 2007
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
Convergence
did u do a repair in recent days
by replacing the convergence ICs?
Jun 18, 2008 | Toshiba 43A10 43" Rear Projection...
How i adjust horizontal size and vertical size
To answer your concern, all you have to do is to change the setting of your aspect ratio on your TV.
Here is my suggested way to procede:
1. Apply 1080i signal, which should produce an oversized HD image on ColorStream1or 2.
2. Select an HD channel that is broadcasting standard 4:3 image, not wide screen.
3. Switch to the Service Mode ( Please refer to the above links). In the Service mode, press channel up/down to find the Adjustment parameters needed for the following steps.
4. Adjust HIT with volume up/down control for the image height to 22.5 inches.
6. Adjust WID for image width of 30 inches, (22.5*4/3)
7. Adjust HPOS to center the image.
8. Adjust PARA and TRAP to minimize geometric distortion.
9. Switch into Convergence mode and Adjust VLIN to get equally spaced horizontal grid lines.
10. Measure the length of the central grid lines and note the number of horizontal and vertical grid lines. This information is used to create an overlay grid.
11. Create the overlay grid on 40x25 x0.003 inch clear Acetate sheet, which you can get at the Art Supply store for under $2. Draw the grid with a fine line erasable pen. Draw vertical and horizontal lines through the center of the sheet so that the lengths are the same as the central grid lines. Now draw the grid so that it has the same number of lines as the convergence grid but are equally spaced, with the outer ones at the ends of the central lines.
12. Cut off about 1/4 inch from the right side of the sheet so that the sheet can lay flat against the screen, which is slightly less than 40 inches.
13. Put a reference mark on the TV frame 2.5 inches down from the upper left side of the screen.
14. Place the overlay on the screen so that the upper edge lines up with the reference mark. The overlay sticks by electrostatic attraction.
15. Use convergence controls to remove grid distortion and converge grid colors. Refer to the Anamorphic link for details.
16. Enjoy 1080i.
Other Comments:
I didn't realize I could create the overlay grid before placing the Acetate sheet on the TV screen, until I finished drawing the grid with the sheet placed on the screen. I added grid lines as called for in the procedure. I'm sure this method took much longer no only to draw the lines but some of them were difficult to see.
Part way through the convergence procedure, I became concerned that the image width was off since I did my screen adjustment with wide screen image. Thus, I decided to repeat that step with a 4:3 screen.
I confirmed the need to press 7 often to save results since after I adjusted one grid color without it, I accidentally hit a key that switched me out of convergence mode and when I switched back, all settings were gone.
Another mistake I made was not realizing that the cursor color determines which grid gets moved.
May 13, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
Convergence issue on Curtis Mathes CM19033S TV
try this will help u when my tv shows the problem i refer to this site onlyhttp://www.answers.com/topic/television-...
Nov 26, 2007 | Curtis CM19033S 19" TV
Black blob on bottom rh of screen,vertical & horizontal lines
The blob is a phisically damaged part of the LCD screen. Unfixable, the screen must be replaced and it will be expensive.
May 04, 2010 | Lenovo 3000 N200 Intel Pentium Dual Core...
Wavy horizontal lines running through the screen
Ur tv convergence is dead.U must know how to solders?The 2 STK convergence ICS.and some or all it resistors must change.Tries websites Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 17, 2010 | Mitsubishi WS-55613 55" Rear Projection...
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
Convergence problem with old rca 46 in rear projection TV
you will need to have a shop re converge it or order a new convergence board.
Nov 17, 2008 | RCA P46924 46" Rear Projection Television
Toshiba 43A10 43" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
