Question about Cell Phones
I already update new firmware also formatting the memory card, restore to factory setting.. Why still can't open my music player.. Same error out.. >> Updating Library >> no Music filed found........ What should i do????
    President:
  • 1,952 Answers
You will try reset in your mobile
Posted on Sep 29, 2009
Nokia 5130 when open music player play songs then error invalid application
try with the new firmware for the mobile from nokia web site or try formatting the phone completely before doing that take a back up of all your information from the phone..
Sep 30, 2010 | Nokia 5220 XpressMusic Cellular Phone
What should i do to fix the music player of my phone 5200 nokia?
Initially try by restoring the phone to factory default setting and format the memory card.if it does not help you.Try updating the firmware of the mobile sure it will solve the issue.Either update by yourself or contact service centre
Sep 23, 2010 | Nokia 5200 Cellular Phone
Sir i hav problem with my nokia handset model no. 3110c whenever i update the music library through music player it says no music files find pls help me and tell me the best possible solution.... thank...
Backup all the contents of the memory card on your computer, format it and reinsert it on your mobile (if you are doing this with a Memory Card Reader). But before you reinstall the memory on your phone, restore the phone's settings to it's default value, you'll find the options on the Settings Menu of your phone (Menu > Settings > press up key once and then "Restore Factory"), once you enter the factory default settings, you'll be asked to enter the security code, enter 12345 (if you haven't changed it, or else you have to use your own customized code). Confirm the process and your phone will automatically restart itself.
Now reinsert the memory card, and again remove it after a minute or two (if you don't have a card reader, connect it to the computer using the usb cable, by selecting the connection type as "Mass Storage'), after it's connected, open the memory card directory and copy/paste all the music files from the computer to the Music folder of the memory card (don't paste it anywhere except the music folder).
Now you'll be able to open or update the music player or the library. If the problem persists, you'll need to update the phone's firmware and I would recommend you to get it flashed.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 05, 2010 | Nokia 3110 Cellular Phone
Nokia 3110c music player is showing no music files found...what to do...i formatted my memory card but no use????
Is the memory card showing on your phone? Can you see the memory card in the Gallery?
Firstly restore you phone to it's default settings (factory default). That'll help you fix your problem. To do this, Open "Menu" > "Settings" > scroll down to the bottom, select > "Restore Factory" > "Ok" and when you are asked to enter the security code enter 12345 or your personal customized code if you've changed it recently. Your phone will restart automatically.
If this doesn't help, you'll need to update your phone using Nokia updater or from a Nokia Servicing Center or from a Nokia mobile repairing shop.
Good luck.
Jul 06, 2010 | Nokia 3110 Cellular Phone
Music player not open
Turn off your mobile, remove your memory card, again switch on your phone and check whether you can open the player or not. If so, your memory card is the culprit. Scan it using an updated antivirus, turn off the phone and again reinsert the memory card. If the problem persists, you need to format the memory card after backing up all the data, and restore the files again reinstall it. Your player will be fine.
If in case the player can't be opened even after removing or formatting the memory card, you need to update the phone firmware. I would suggest you to get it done from a service center or from any local mobile repairing center.
Good luck.
Jun 29, 2010 | Nokia 3110 Cellular Phone
Nokia 3110c music player problem.
Your firmware seems to have got corrupted. Please update the firmware. But beware, if you do it yourself then only the corrupted files will get re-installed.. While if you get it done thru Nokia Care then the whole firmware will get updated to the latest one.
Aug 21, 2009 | Nokia 3110 Cellular Phone
How to format phone memory of nokia 3110c
Actually I want to format my phone memory of Nokia 3110c as whenever i try to enter confriguation setting for GPRS it gives me errot target memory is full, Inspite there is nothing there in memory.
Apr 27, 2009 | Nokia 3110 Cellular Phone
Formatting internal memory of nokia 3110c
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 - Memory Cards - Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Jan 14, 2009 | Nokia 3110 Cellular Phone
Cell Phones Logo
461 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
