Question about Nintendo DSi White Console
Hi my dsi has froze, when you turn it on the touch screen will not work, then when you get into the start screen it is stuck on pictochat nintendo the only thing you can access is the camera by r + l buttons the other buttons and everythin else wont work
    Problem Solver:
  • 11 Answers
It isnt frozen its broken send it into nintendo and they will repair it for free if it is still underwarranty if not you will have to pay a fee depending on what is broken
this has happened to me i sent it in and when i got it back it worked perfectly
Posted on May 08, 2010
Screen touch
Refer to the trouble shooting at Nintendo. Your screen may not be working due to the game your playing if any. If that's not the case you may need to recalibrate your touch screen.
http://www.nintendo.com/consumer/systems/dsi/en_na/trouble_screen.jsp#respond
Aug 15, 2013 | Nintendo Dsi Pink Console
Touch screen is not responding and can not play any games.
Perform a recalibration as soon as you notice a problem, to prevent performance errors.
If the calibration problems do not go away you may need to contact Nintendo for technical service or if you think you can replace the screen you self i can give the process to do so...
How to Replace a Nintendo DSi Touch Screen
Finding someone to fix a Nintendo DSi touch screen can be time-consuming and costly. However, with the right tools, you can do it yourself. Even if you've never tried fixing anything until now.
Instructions
things you'll need:
* Tri-wing screwdriver
* Precision Phillips screwdriver
* Precision flathead screwdriver
* New Nintendo DSi touch screen
Turn the Nintendo DSi over and find the five screws on the edges of the bottom. Take each one out with your tri-wing screwdriver. In the center you will find an additional screw that will need to be removed with a precision Phillips screwdriver. This keeps your battery in place.
Take the battery out. Underneath it you will find two screws that must be removed with the tri-wing screwdriver. After both have been taken out, pull up on the bottom casing to access the motherboard. In order to replace a Nintendo DSi touch screen, this will have to be removed.
Detach the right and left buttons in the top corners by pulling up. Underneath each one will be a spring---make sure you don't lose these. Then remove the four screws in the middle of the motherboard with the precision Phillips screwdriver.
Look for the ribbon attached on the bottom left corner of the motherboard. Take a precision flathead screwdriver and pull up on the black bar that connects the ribbon. You should be able to slide it out by pulling back.
Find the two small connectors that are locked in with two tiny clips on each one. Lift up on all four clips to pull out the underlying connectors. Take out the motherboard and turn it upside down. Now you are ready to replace your DSi touch screen.
Detach the Nintendo DSi touch screen with your fingernails. Pull it away from the adhesive, one side at a time. Take the new screen and peel away the protective plastic before replacing it. Line it up where the old touch screen was and reassemble the Nintendo DSi.
Hope it helped...
Aug 15, 2011 | Nintendo DSi Blue Console
My daughter has a pink nintendo dsi...for some reason it seems stuck it won`t play a game and the touch screen doesn`t work. it is under a year old and went to walmart where was bought and said to contact...
can you get the DSi connected to the Internet? Update the firmware on it. Specific information can be found at www.Nintendo.com. My daughter's DSi did the same thing, the problem cleared with the new firmware. If it doesn't resolve it, the tech support folks at Nintendo.com should be able to assist... they are a bit slow to respond... but be patient, they do know their stuff.
good luck,
Mark
Apr 13, 2011 | Nintendo Video Game Consoles & Games
Cant sign into pictochat \r\nkeeps on signing out sraight after i sign in.
Hi amzlobow,
This problem might be caused by your internet. try reseting your Internet router. if that does not work then perhaps the simple answer is that someone already knows your Password and Username, try changing the password.
if that does not help then try turning off your DSI for a couple of minutes.
i hope this helps.
Mar 27, 2011 | Atlus PictoChat for DS
My son has managed to change the language to german and we cannot change it back. It does not go into a screen to allow us to pick english. Any suggestions?
turn on your DS, touch the screen to open the menu(from top to bottom(DS Game, Pictochat, DS Download play, GBA Game) and underneath the GBA Game there is a little button that looks like an open DS... Touch that button, Now you will see a menu with a Wrench and Clock & Calendar, a Person, and a Cross.
Click on the Wrench, and then click on he icon that looks like a globe, form there just choose the language that you want.
Mar 01, 2011 | Nintendo DSi Blue Console
When i turn on my dsi touch screen and buttons
have you gotten any food in it? to cause it to stick or anything?
Mar 13, 2010 | Nintendo DSi Black Console
Nintendo dsi error everywhere
Contact Nintendo for this problem,
it looks like the firmware went corrupted,
maybe some one has used a bad flash
adapter to play backuped games.
Don't tell them the part of maybe some one
used a bad flash adapter, becouse they then won't help you anymore or will cost you alot
of mony to get it fixed.
Also try to reset the dsi to the standard settings, this can wipe everything on the dsi,
making backups is recomended.
A factory reset on the DSi can be performed by holding down every button minus those of the d-pad and turning the system on.
Sep 18, 2009 | Nintendo DSi Black Console
DS Lite probem when powered on
have you replaced the touch screen or at leased opened up the console and unplugged thetouch screen cable.
Jul 03, 2009 | Nintendo DS Console
Cake Mania October Casino Level Stuck
You need to calibrate your touch screen...Follow these easy steps to do so.
1 Turn your DS on.
2 When you come to the main menu that lists pictochat, ds download play, and the game that is inserted in your DS, Tap the little ICON of the ds towards the bottom of the screen.
3 There should be a new menu that comes up with different colored squares. The yellow square has an odd icon with a box thing. Press this.
Follow the instructions from then on...
I hope this helps!
Jun 18, 2009 | Majesco Cake Mania for DS
Nintendo DSi White Console Logo
367 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
