Question about Viking DFUW151 Wine Cooler
Where to purchase E16 240V 15W replacement lamp for Viking wine cooler within UK?
  • bangorjones Sep 29, 2009
    Many thanks,
    I'll give it a try.
    kind regards,
    D
  • Neciforo Llanto May 11, 2010
    If you want to purchase this item try to visit on ebay the online selling website.
    www.ebay.com
    Search the model of your item.
    Regards
    PCmania
  • 313 Answers
SOURCE: change 120v chager to run on 240v
all you needs is a step tranformer from 110v to 220v ac
Posted on May 28, 2008
  • 287 Answers
SOURCE: How to wire US dryer to UK supply - Whirlpool WED8300SWD
THIS document has a lot of info about the wiring for the unit you have. starting at page 6
I am, however confused about the voltage requirements as reference to 12/240VAC with a note to check the "rating" plate
If your unit is marked as 240VAC then it should be a simple task for an electrician to wire up the power. The instructions/details are in the manual (link provided) to connect it up as a standard 3 wire system used in the UK
The issue you have is that the motor may not like running on 50hz and may run HOT. It will also run slower on the lower frequency.
The specs on the website are as follows:-
Electrical Requirements
30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED
It may be worth getting all details off the rating plate and posting back here...
My suggestion is that you consult a qualified electrician before attempting to connect the unit to the power
Better safe than sorry.
Posted on Jul 08, 2008
SOURCE: Sony ICF-C1ip
hi, you resolv you problem of the icf-c1ip ?what is DC volts ?
Thanks ;)
Posted on Oct 22, 2008
  • 252 Answers
SOURCE: I have 2-240V (4.2V) basebaord heaters, Need Wiring Diagram
nothing wrong w/ 10/3 @ 20A. use the red and black and don't use the white. dosent matter which is which (blk and red).
Posted on Mar 22, 2009
  • 14 Answers
SOURCE: VinoTemp VT28TEDS - circuit board
Here is the phone number for Vinotemp International 800-777-8466 for customer service.
Posted on Sep 21, 2009
My wine cooler door swicht is not working,light is on even with the door closed
The switch is bad. Two wire simple switch. Replace it. Un-plug before replacing.
May 05, 2014 | Viking VUWC140 Wine Cooler
I have an opportunity to purchase a used full sized viking wine cooler model VCWB300R
It can be repaired but not easily. The cost will be more than a new unit as it requires specialised welding gear . Better to give this offer a wide berth and get a brad new one if that is what you want.
Mar 07, 2014 | Cars & Trucks
Viking wine refrigerator flashing red light
what is the model number is then we can get started then okay??
Sep 11, 2013 | Viking VUWC141 Wine Cooler
Need to replace compressor on vinotemp wine coooler
Return the compressor and buy another wine cooler. This work is too complex for people that do not do this every day, Thanks Sea Breeze
Nov 19, 2012 | VinoTemp VT-60 Wine Cooler
If I want to store both red and white wines, what is the best way to store them?
I also had the same indecision and finally I've purchased a dual zone wine cooler. The dual zone wine cooler allowed me to maintain two distinct and separated temperature zones within the same cooler which was exactly what is was looking for, and I think this is the optimal solution for you as well.
Aug 14, 2012 | Furniture
I can't find the plug and cable that came with the machine. Is there anywhere I can buy one? Thanks
If you are in the USA (110V) then try this website
http://www.sewingpartsonline.com/husqvarna-viking-215-sewing-machine-parts.aspx
If your country is 240V then you may need to purchase the power lead from a UK website or your local Husqvarna Viking agency.
Apr 26, 2011 | Husqvarna Huskystar 215 Sewing Machine
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
Trying to find where I can get a new thermistor for a Viking wine cooler VUAR141. It is actually a MARVEL 6BAR but I am told that these are the same model. Thank you.
There are a few sites on line that have the ability to sell you that part. Your best bet is to call the factory direct at 800-428-6644 and purchase prt number 42244531. I believe it has a list price between $40 to $50.
Apr 04, 2009 | Viking Professional Series VUAR141
Haier wine cooler freezes the wine.
You may find that the thermostat is not working. Try to turn the thermostat to the warmest setting, the compressor should switch off within two hours, if not change the thermostat.
Mar 09, 2009 | Haier BC112G Wine Cooler
Refrigerators Logo
73 people viewed this question
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Colin Stickland
Colin Stickland
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
