Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I have changed the ink cartridges and all that happens is an flashing "E" in the tiny viewer. Pluss the warning lights flashing. I had a paper jam last evening but I do not thnk they are related. Except that this morning I took the back plate offf to aake sure nothig was blocking can't see anything but In't get the back on again. I have Parkinsons which makes life a bit slower. Graham
SOURCE: printer jam
Paper jams up goes in wrong I set it in straight and than it goes on an angle
Posted on Apr 11, 2008
kodakman1986
  • 4 Answers
SOURCE: installed new ink cartridge/ still saying low color
try calling 1 800 421 6699 for US.
solution
try to remove inks, then reseat it..
then remove printhead, by pushing the latch on the upper right, then put it back in. be sure that it will snap. close the door with no inks. try to look at the message, if it has the same error, put the inks on it and close the door again.. then if you still have the error message, call the hotline no. and I'm Afraid that you need a Printhead replacement or defective ink issue...
they will replace it for free..
Posted on Feb 10, 2009
SOURCE: After adding paper it says it still needs paper
try to make sure that the paper is printer paper
Posted on Mar 23, 2009
SOURCE: kodak #G600 printer dock/roller won't pull paper through
I read this solution to a problem someone else was having which was similar to my problem. I wiped off the roller with a damp cloth, made sure it was dry and that's all it took to allow the roller to be able to start to pull the paper through. - thanks for the help!
Posted on May 28, 2009
  • 68 Answers
SOURCE: I have a easy share printer dock series 3 and when
the only possibilty which I know is to try a firmwareupdate of you printer dock.
You can download it here.
Follow the installation instruction on the website.
Posted on Oct 13, 2009
Resume button will not stopt flashing!
the resume button wont stop flashing means you had a paper jam you need to clear the jam or there is tiny piece of paper in the printer remove the cartridge and flush out with a mild air blower and also check the cartridge ink level and insert the cartridge
Oct 26, 2011 | Office Equipment & Supplies
Tip
Bottom Two Lights Flashing
Was printing recently and paper tray ran empty. Then cartridges jammed to the right side and bottom two lights flashed continuously, in spite of disconnecting power, restart, etc. Finally, in attempt to change ink cartridges, pushed down on housing for ink cartridges and heard a click. They were jammed in the far right position. Restarted printer and all worked fine. Not very techy, but it worked!
on Jul 28, 2008 | HP DeskJet 5550 InkJet Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Paper won't feed yellow light flashes on my hp deskjet f4440. Followed every instruction I could find without improvement...
I had same problem. It ended up being a paper jam altho I could never see anything jammed in the paper paths. Perhaps it was a tiny piece of torn paper that I couldn't see. Anyhow, I fixed it by taking a piece of 8.5x11 cardstock and manually pushing it into the paper feed path in between the rollers. It did not go all the way through so I pushed it in and pulled it back out a few times. Apparently it dislodged whatever was causing the jam and the doggone yellow light finally stopped flashing!!! good luck.
Sep 17, 2010 | HP Office Equipment & Supplies
Paper jam ? can see no problem, display flashes E
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 11, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
My red lights are both flashing and printer will not responed
Both red lights flashing? One should be for paper jam and the other for low/insufficient ink. I presume this is a deskjet/injet printer. The combination of these two lights flashing usually indicates a more serious issue rather than just low ink or paper jam. It is indicative of incompatibility of ink cartridge. After a while some cartridges just could become incompatible with the machine. All things being equal (i.e. no paper jam issue) a replacement of your ink cartridge will resolve this issue. Just get brand new ink cartridge/cartridges. It is usually ok to replace only the one that has become incompatible. But the issue is you need to troubleshoot to determine. You may not have the resources to do this, so better to replace both or replace one-by-one.
Sep 15, 2009 | Epson Stylus Photo R260 InkJet Printer
Hp 845c orange light keeps flashing
When the orange light is flashing, either paper jam or ink problem is happening.Try unloaging & reloading the stack of paper in the main tray. Remove & reinsert ink cartridges in the printer. You may also clean the contacts of the cartridge and inside the product.
Mar 09, 2009 | HP DeskJet 845c Printer
Printer Will Not print
There probably is, in fact, a "paper jam". A very tiny piece of paper is stuck somewhere in this printer. If the printheads (where the ink carts. are) move freely when cover is opened, it's most def. a paper jam.
gurutim
Dec 18, 2008 | HP DESKJET PRINTER, HP OR COMPATIBLE
Paper jam error message
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Apr 21, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Ink and paper lights flashing red and I cannot print
No body wants to take it to repairs, we all hate spending money if it can be avoideded. Do't fret. First, i would bet you have a paper jam that you have missed. This would stop the carriage and head cleaning. Open up the cover as if replacing ink. Get a torch and really thoroughly check for tiny paper jams or ujo's(unidentified jamming objects)check where paper goes too. Now close cover turn off, unplug, all cables, replug, turn on, try printing now. Post back if no good. Cheers lilacgerry
Aug 27, 2007 | Epson Stylus C84 InkJet Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
21 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
