Question about Canon Pixma MP500 All-In-One InkJet Printer
When i print from microsoft word the ink is too heavy and the dark colours dont dry leaving smudging, what am I doing wrong?
zeusfaber
  • 247 Answers
SOURCE: ink won't dry
Unless the problem coincides with a change in ink cartridge, my guess is an incompatibility between the ink and the paper. Could you have changed the paper you're printing on. If so, is the new paper of a different quality? If you're using coated (eg photo) paper, are you printing on the right side? Check the "paper quality" setting on the printer (or the software you're using to drive it) - it needs to match the specification of the stuff you're printing onto. Photo quality papers are capable of absorbing much more ink than plain paper (which is how you get the colour intensity). If the printer thinks it's using photo paper, it will throw out enough ink to get that colour build - leaving a sticky mess if what is really loaded is just plain paper. A.
Posted on Apr 29, 2007
  • 181 Answers
SOURCE: ink not dry and significant smudging
there r various modes in the printer in which u have to print .and that u have to select.as you said it is printing properly on ordinary paper.the printer is perfect.the photo paper have less soaking power that ordinary paper.as the photo paper can consume ink but not so quickly as ordinary paper.
u just change that printmode and then check out how it prints.
for example the modes r ----------best mode printing.
better mode printing.
fine mode printing
normal mode printing.
draft mode printing
economy mode printing.
now i f u print in best mode it will consume lots of ink but will take lots of time to print.
if u select normal mode it will consume less ink and print quickly.
u can change the settings in printer properties.
thanks
Posted on Nov 14, 2008
SOURCE: Ink will not dry
Without having to apply a varnish, the best way is to use frog juice which is a spray which come as both matt or gloss and gives the same eefects as a varnish but isnt noticable with the matt. This reduces the solid black areas from smudging.
Posted on Jan 10, 2009
  • 21 Answers
SOURCE: Canon PIXMA MX700 printhead immediately coated with ink, smudges
It's likely that the foam pads that the print head rests on when the printer is not in use are saturated with ink. They're to the right as you look into the printer: a rectangular one for black ink and a square one for the colored ink. If you power the printer off and back on, with the cover open, you'll see where the printhead goes to rest.
The pads aren't easy to get at, but you can blot them with a paper towel. Gummy, half-dried ink dissolves in rubbing alcohol, and you can soak a paper towel or a cotton ball with alcohol and wipe down the area. I've had good luck soaking the pads with alcohol, then blotting them dry with a rag.
Posted on Sep 11, 2009
Martyn01202
  • 217 Answers
SOURCE: I'm trying to print wedding
Sounds like the ink isn't having time to dry and is rubbing along paper.
Paper may be too thick. If it prints OK on normal paper (test first) but not on thick card, then it doesn't support thick paper settings.
Posted on Jan 31, 2011
Unwanted colour lines on prints
It may be time for a new printer. Colored lines are often an indicator that the printhead is worn out. Dark smudges on the back of the print are likely just a need for cleaning the inside.
Sep 02, 2014 | DSC GESTETNER - DSc38u Color Printer
I'm trying to print wedding invitations on my Canon MP460. I'm using a cardstock thickness of paper and have set the ink levels for "Other Photo Paper" on my Mac. The paper has been going through...
Jan 31, 2011 | Canon PIXMA MP460 All-In-One InkJet...
No Black ink printing have cleaned heads, re-aligned, replaced black ink cartridge for 3 new ones, still no joy. all colours printing ok but nothing on the black. HELP
Hola
Defective printing does not print crisp, white out in print, or not even print anything, just move the spool and nothing appears, the colors go wrong. However, in these cases is that we have a cartridge slightly obstructed or completely clogged with dried ink if you have heavy, it is likely that the ink has been of poor quality and dries faster than usual, or perhaps use the printer and let a long time without use, this causes the microholes clogging, which in turn prevents the proper exit of the ink causing a bad impression.
The fastest, homemade solutions: Remove the cartridge from the printer, and then immerse the injector in a little warm water, leave it there for a while, then off, dry it well and perform the head cleaning process in the configuration utilities for our printer. / With cleaner (cleaning product containing alcohol and ammonia) do the same procedure as above should not work.
But sometimes, the problem is that there is air inside the cartridge that is inserted into the sponges, and instead of heat resistance ink what they get is only air. To fix it we will locate the top holes of the cartridge, where it enters the ink, and putting a napkin where the ink comes out we will proceed to introduce air (by the way you like, blowing, or injection) at the top and let that little bit of ink. proceed to clean heads to the usefulness of the system and ready.
Apr 06, 2010 | HP Photosmart C5180 All-In-One InkJet...
Printer leaves gray ink on page
I guess that you use a non-genuine print cartridges, try to use a genuine one.
please confirm me at walid_sayed@hotmail.com
thanks
Apr 03, 2010 | HP DeskJet F380 All-In-One Printer
After replacing cartridge in dell 810 the colours printing wrong
Hi
If you haven´t used your inkjet printer for a while it may just be dry ink clogging some of the nozzles in the print head.
To check if yours is clogged...
Remove the ink cartridges
Holding the cartridge upright and press down gently onto a paper towel.
The colour cartridge
you should see YELLOW, MAGENTA (red) and CYAN (blue)
But if any colours are missing? The inks have probably just clogged up? and you will need to buy a new one or if you know you still have ink then you can easily unclog it with a
Magic Inkjet Flush Kit (Which you can find on Ebay)
MIXED COLOURS
If you have others colours coming out then the colours have mixed...
Sometimes caused when people put tape onto the inks to keep them moist but instead the colours mix through capilary action.
If so... leave print head sitting on a paper towel for a few mins until the correct colours appear.
Read more about ink clogs here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
To prevent an ink clog it is best if you print something regularly about every 10 days to keep the tiny print head nozzles / jets open. Otherwise the ink in the print head will thicken. Then it´s like trying to pass a camel through the eye of a needle.
So to preven inkjet ink from clogging print something every 10 days if you dont have anything to print, use something like these test prints
PRINT TEST SHEETS FOR USE WITHMagic Inkjet Flush
http://magicinkjetflush.com/Ebay/Print_Test_Black.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Color.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Cyan.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Yellow.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Magenta.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Grey_Tones.jpg
Good Luck!
Hope this helps you!
Tinteiros (Ebay)
Oct 28, 2009 | Dell 810 All-In-One InkJet Printer
Ink comes out heavy in spots on print outs as if you had a jam and then the ink smudges - ink does not smudge just heavy on certain spots
Sounds like you need to replace either the fuser or the rollers the rollers could have ink build on them and it would smudge the ink.
Oct 21, 2009 | HP LaserJet 6p Printer
Print out is dirty, there are smudges of inks at the page center
What colour are the smudges, if they are one colour you can try changing that colour toner cartridges. Failing this then it sounds as if you may need a new drum
Dec 09, 2008 | HP LaserJet 2550L Printer
"Banding" on Prints
Do a thorough manual cleaning of printerheads (where the cartridges sit). Many printers are notorious for clogged nozzles and the ink dries on he prinheads until it becomes a bandind issue or ladders appear, smudges too. Use a proper cleaning solution and cotton buds, until most colour is gone off cotton buds. Reinsert cartridges and try again.
Aug 25, 2007 | Canon i9900 InkJet Photo Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
old marine
old marine
