Question about Agfa DuoScan T1200 Flatbed Scanner
Just bought it second hand - risky I know, but am having trouble.... Will it run with XP? It seems to turn on then a loud click and just stops. Feeling a little stupid - it could be a simple problem...
  • legendary020 Sep 29, 2009
    Thanks, yes I had released the screw and have downloaded the driver, however the scanner traveller (?) moves briefly until a microswitch kicks in a small arm that prevents further travel. It sits for a while and tries to repeat the process...
    President:
  • 1,653 Answers
Yes it will run with XP as long as you have a SCSI driver and FastSCSI connector.
Download the latest available driver and manual at the following AGFA Support link
http://static.agfa.com/digicam_scanner_drivers/scanner/duoscan/index.html
Make sure that the carriage is unlocked before powering it up.
1 . Pull the scanner carefully over the edge of the table until you can see the
unlocking screw at the bottom of the scanner .
2 . Take a coin and turn the screw a quarter turn counter clockwise .
The screw comes loose and your scanner is unlocked .
3 . Move the scanner back on your desktop . Allow a minimum of 10 cm ( 4 inches )
around each side of the scanner and a minimum of 15 cm ( 6 inches ) at the
rear of the scanner .
If this is not the problem than if it does nothing then it may be the carriage is jammed or simply cannot move to the 'home' position. Some gentle investigation with the carriage assembly will let you know if things are OK but make sure you are gentle with it otherwise you will need to realign it and that is much more difficult.
Posted on Sep 29, 2009
  • Karl Wright
    Karl Wright Sep 29, 2009
    The scanner needs to find a 'home' position when it starts up and can effective move down the scan page line until it hits the microswitch which tells it to stop and go back until it sees either an opto switch or reference mark which may be another microswitch and this is what tells the scanner that it is at the home position.
    Also re SCSI:
    1. After opening the Scan dialog box, a message appears telling that no scanner is connected, although the scanner is connected.
    2. Check the Installation procedure, to see if you followed the instructions. Pay special attention to the setting of the SCSI ID number.
    3. Maybe you did not wait long enough for all SCSI devices to startup, before you switched on your workstation. Therefore, try restarting your workstation.
    4. Disconnect all SCSI devices and connect them one by one, beginning with the scanner, to identify the device that causes the problem. Check if your terminator has been set correctly and restart your workstation.
    5. Make sure that your devices have different SCSI ID numbers. If there are devices with the same number, assign a different number to each device.
My 93 Buick lesabre recently started having a loud clicking sound while driving and in park. My friend and I noticed that when in park and we turn on the AC, It stops, But if continue to drive with AC on,...
how much does the clicking happen ? like every second or ten time a second or like every minute or so ? when the engine is not running just take your hand on the AC pump pulley and see if there is any kind of play in it. we'll start there.
Jun 07, 2012 | 1993 Buick LeSabre
I recently bought an invicata 8926A. It looks great, but I'm having some trouble winding it. When I wind it by moving it round and round for a few seconds, it runs for a while. But when i rest my...
It looks like your watch has mechanical issue. Without inspecting the watch it's hard to say what exactly the problem is and I suggest you return it for replacement under warranty.
Apr 15, 2011 | Invicta Watches
Loud bang, then drop in power, now car running rough!
Get a compression tester and find out if you blew a cylinder. You'll need to test all cylinders. Your most likely running on 7 cylinders instead of 8 or 5 instead of 6 if you have the V-6.
Jun 25, 2010 | 1998 Chevrolet Camaro
Hp pavillion ze4500 fan running continuously
weel its seems ur laptop is Clogged with Dust .the reason the Fan is Spinning fast is because parts r getting Heatedup.as a matter of fact wht u can do is |if ur r a pro open up ur laptop and clean the heatsink.that should take care of it.
May 10, 2009 | Gateway 5200S PC Desktop
My Dell600 won't power on with or without A/C adapter
Hi!
If the unit was a Brand New purchased, and still 4 months old, its better to avail the "warranty" of the unit, to save you from any trouble. But if it is a second hand without any warranty, you can eithertake this risky step or submit it to a certified service center.
The risky step is to open your laptop, and check the "charger terminal" for loose contact, or solder detached terminals.
Dec 31, 2007 | Dell Latitude D600 Notebook
Noisy laptop
sounds like the fan is bad in there. Here the service manual, it will show you how to take it apart.
http://support.dell.com/support/edocs/systems/latc610/en/index.htm
Dec 07, 2007 | Dell Latitude C610 Notebook
Agfa DuoScan T1200 Flatbed Scanner Logo
53 people viewed this question
Top Agfa Office Equipment & Supplies Experts
Chris Larocque
Pierre Legault
Are you an Agfa Office Equipment and Supply Expert? Answer questions, earn points and help others
