Question about Quintum Tenor BX408 (501015800) 1x10/100 Mbps Networking Switch
I have just purchased a 2nd hand Quintum Tenor BX408. It all works, I can run the initial configuration wizard and set and IP address etc etc. I am installing it between our Ericcson BP250 PBX and the Telco. So configuration is 2 x ISDN BRI ports from the Telco to the Tenor then 2 x ISDN BRI ports from the Tenor to the PBX. ISDN ports with the Telco establish with no problems. ISDN ports with the PBX show Amber LEDs on the front panel. Further investigation shows that Layer2 is not coming up on the ISDN. I've tried a lot of things but I just cant seem to get this to work. You should know that I've enabled power-off bypass on the ports. When the Tenor is powered off the PBX works just fine and makes and receives calls. Appreciate nay assistance.
  • 2 more comments
  • dw42 Sep 29, 2009
    Here's the output from the "Support Information" section in the config manager. If you need output from the CLI can you assist with the correct commands. I'm a newcomer to Quintum.
    You'll notice the "Established Awaiting TEI" on port 2/2 and 2/4. Note that If I set the TEI value to say 24 rather than 64 it gets to the next stage in the layer 2 handshake saying "Established Awaiting".
    Thanks,
    David.
    Tenor BX [0]
    System Software P103-08-14 Sep 14 2006, 17:12:40
    H323 Module : 3.1.1
    Boot Software P103-08-08
    Serial Number: A013-020006
    20-Channel DSP Cards: 0 [0 0 0]
    120-Channel DSP Card: No
    Digital Interfaces: 4 [1 1 0 0]
    Database Version: DB_CMS_M09_A012_V7.0.00_080205
    Slot Dev Status Configuration
    01 01 Active Tenor BX408 System Controller
    02 01 Active DS1 Card
    02 02 Active n-Channel DSP Card
    The System is up for 0-Days, 0-Hrs, 5-Mins 12-Secs
    [Tenor BX408 Licensed Features]
    Maximum VOIP Calls....................................................0008
    Maximum PacketSaver Calls.............................................0000
    Maximum Gatekeeper Ports..............................................0016
    Maximum CallRelay Ports...............................................0000
    Maximum IVR Languages Enabled.........................................0001
    GK calls from Internal GW = 0
    GK calls from External GW(s) = 0
    Total calls active on GK = 0
    This Tenor is licensed for VoIP ports and 8 GK ports
    Installed Cards:
    Slot#02: 4 Channel BRI
    BRI Status:
    Activ InCon OutCon
    Slot Type PhysicalLayer DataLinkLayer TEI# chans /att% /att%
    2/1 BRI Active Active 64 0 0% 0%
    2/2 BRI Active EstablAwaitTEI 8319 0 0% 0%
    2/3 BRI Active Active 64 0 0% 0%
    2/4 BRI Active EstablAwaitTEI 8319 0 0% 0%
    Number of active channels: 0
  • dw42 Sep 29, 2009
    One more thing. It's not in production yet and it's on a public IP at the moment so I'm happy to give you access if that helps.
    David.
  • dw42 Sep 29, 2009
    As you can see the status changes, but only slightly. The Quintum manual says that 64 is the value for auto-negotiation of the TEI. So it should work at 64. Anyway as you can see it still doesn't work at 32.
    Regards,
    David.
    Installed Cards:
    BRI Status:
    Activ InCon OutCon
    2/2 BRI Active Awaiting Estab 32 0 0% 0%
    2/4 BRI Active Awaiting Estab 32 0 0% 0%
  • dw42 Sep 29, 2009
    Thanks, but the problem is not with the Telco provider side. That is working fine and the ports seem to negotiate the TEI just fine. The problem is with the BRI connections to the Ericcson PBX. They are the ones with problems.
    Here's the configuration:
    Telco BRI Line 1NT ---> Tenor Port 1 TE
    Tenor Port 2 NT -------> Ericcson PBX TE
    Telco BRI Line 2 NT ---> Tenor Port 3 TE
    Tenor Port 4 NT --------> Ericcson PBX TE
    The Tenor Ports 1 and 3 to the Telco have green status LEDs on the front panel.
    The Tenor Ports 2 and 4 to the PBX have amber status LEDs on the front panel.
    I've tried disabling the BRI termination as you suggest but that just gives a layer 1 fault and the front LEDs go RED.
    I've also tried swapping the ports Telco <> PBX and their associated configs. The problem moves with the ports with the Telco ports working fine so it doesn't seem to be a fault with the ports.
    We are in Australia so the ISDN standard we use here is ETSI not NTT.
    I suspect I'm just not setting it up correctly somewhere.
    Appreciate your assistance.
    Regards,
    David.
  • 3,741 Answers
Its the connection issue that is sure.but you will have to check line by line. ISDN BRI (uses one B channel for ISDN BRI (uses one B channel for voice and second B channel for data). .keep updated.
Posted on Sep 30, 2009
  • 19,396 Answers
Please do a Show ISDN Status on both situation, copy and paste, and publish the result here. When Layer 2 is active it must show multiple frame established instead of just active. Line must be something like this: TEI = 91, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Posted on Sep 29, 2009
  • 1 more comment
  • Ginko
    Ginko Sep 29, 2009
    Thanks, give me some time to read the script.
  • Ginko
    Ginko Sep 29, 2009
    Hi, I could connect CLI via Telnet, but we are not supposed to provide remote support assistance, and I can get in troubles down here.
    Regarding your problem, what does happen if you set port at let say 32 instead of 64. 64 is just the TEI port number default value. If any other function is assigned to port 64, this may not work.
  • Ginko
    Ginko Sep 29, 2009
    64 is the default value, it may not work with BRI setting for your provider.
    To change BRI using the configuration manager go to to Circuit Configuration > Signaling Configuration > ISDN Signaling Groups >
    ISDN Signaling Group-n > General tab.
    - From the Protocol drop-down box, select BRI NTT.
    In BRI check also termination setting. Try using with termination set.
    To disable Termination in Configuration Manager, follow these steps:
    - Navigate to BRI Configuration - Digital Interface-n > Channels tab.
    - Click the checkbox in front of Termination.
    Try also calling your provider, and checking settings with the technician at the phone. you may be using incorrect BRI settings.
    If the unit is second hand, and you get problem only on layer two, the unit can also be defective.
Default IP address
Try: 192.168.1.1 or 192.168.1.2
Nov 13, 2013 | Quintum Tenor DX4120 Router (501012400)
I need quintum axt2400 support
In case you need support from outside (remote location) for fine tuning you tenors just provide me the IP Address and Password via mail and, or chat; contact me as bdheeman (at) gmail (dot) com.
Dec 29, 2012 | Quintum Tenor AXT2400 (501014800) VoIP...
NEED QUINTUM PASSWORD RESETTING
The detailed description of Configuring Terminal Software/Assigning IP address to Tenor DX is given below.If you need only RESETTING GOTO STEP 18.
1.From your PC, click on Start> Programs> Accessories> Communications> HyperTerminal. The Connection Description is displayed.
2.Enter a connection name (i.e., name for each unit such as Tenor DX 1 and click Ok.
3.Choose the connection port on your PC from the Connect Using drop down list box (i.e., Direct to Com1). Click Ok. The Com1 Properties window will be displayed. See Figure 3.
4.From the Bits Per Second drop down list box, choose 38400.
5.From the Data Bits drop down list box, choose 8.
6.From the Parity drop down list box, choose None.
7.From the Stop bits drop down list box, choose 1.
8.From the Flow control drop down list box, choose None. Click Ok. A connection to the Tenor unit is established.
9.Click on Call>Call. A connection to the unit will be established. The login prompt appears.
10.Enter a login name. The default login name is admin.
11.Enter a password. The default password is admin. (Once you are up and running, changing the password is a good idea for security purposes). Step through each of the following parameters and enter the correct values for your installation: IP address, Subnet Mask and Default Gateway.
12.At the Quintum prompt, type ei to reach the Ethernet prompt and then type config to change to the configuration mode.
13.To set the IP address, type set ipa followed by the IP address.
14.To set the Subnet Mask, type set subnetmask, followed by the subnet mask.
15.Type siprd to change to the Static IP Route Directory.
16.To set the Default Gateway IP, type change 1 g followed by the IP address for the default gateway IP.
17.Type submit.
18.Type maint to reach the maintenance mode and then mc. Type reset. A confirmation message will ask if you want to reset the unit. Type yes to reset the unit. The reboot enables the Tenor to incorporate the new settings.
19.Once the IP information is set, you are ready to configure the unit.
Jun 04, 2011 | Quintum Tenor DX2060 (501-0122-00)...
Hi how to resolve quintum ax series problems license hardware configuration mismatch is the problem
You need to request a new/updated License file from custspt@net.com
plz note that the quintum.com is net.com now.
Aug 23, 2010 | Quintum Tenor AXT2400 (501014800) VoIP...
I need quintum CLI configuration manual
pls cq
http://www.quintum.com/support/mgmt/index.shtml
u find GUI configuration software & also CLI Configuration manual
Dec 01, 2008 | Quintum Tenor DX2048 (501012100) 2x10/100...
Who can help solve my problem
The CM stands for "Configuration Manager", in other words, that is the GUI. The Tenor firmware either starts with a P or an S (e.g. P104-11-00 or S105-01-01)
Sep 17, 2007 | Quintum Tenor ASM200 (501-0132-00)...
Asm 200
There are 6 potential volume adjustments for an Analog Tenor.
Rx & Tx at the Phone, Line & IP - Adjust them carefully, 1 dB at a time. There are some tests that can be run to test impedance too, which will ultimately affect audio quality.
http://www.quintum.com/support/xplatform/telco/Tenor_MFG_Test_SecondGen.pdf
Feb 23, 2007 | Quintum Tenor ASM200 (501-0132-00)...
Unable to send calls out after a change in the IP address
I hope that you have solved this by now, but the only way to be certain about what exactly happened is by reading event log trace. Your Quintum Reseller should have this knowledge.
Aug 29, 2006 | Quintum TENOR 960 VoIP Terminal Server
Quintum Tenor BX408 (501015800) 1x10/100 Mbps Networking Switch Logo
200 people viewed this question
Top Quintum Computers & Internet Experts
David Payne
David Payne
Are you a Quintum Computer and Internet Expert? Answer questions, earn points and help others
