Question about Samsung SF-750 Plain Paper Laser Fax
On the transmission journal what does g3 stand for mean on the mode section?
    President:
  • 3,085 Answers
G3 means you have the latest version of the UNIVERSAL FAX STANDARDS and is compatible with all other fax machines.
Posted on Sep 29, 2009
What does blinking hold light mean on 2009 ponitac g3
dash cluster hold, or console hold(shift)?
the operators guide covers this in the glove box.
in fact it mentions, every warning lamp.
my wild guess, is the A/T TCM shifting brain, is upset.
scan it.
GOOGLE it yet. here is 2nd hit.
page 3-30 , it says the transmission needs service. (its correct)
http://www.vadengmpp.com/owners-manual/pontiac/2009-Pontiac-G3.pdf
Jul 01, 2014 | 2009 Pontiac G3
What is the function of the button near the auto transmission gear with writing c and s
It stands for "Sport" and Comfort", it changes the way the transmission shifts. Read a more detailed description below.
In C, the transmission starts from a stop in 2nd gear unless the kick down switch is activated (pedal to floor from standing start). The transmission will shift at lower RPM's. This is used for everyday driving. The S mode will cause the transmission to start in 1st gear regardless of pedal position and shift at higher rpm. This button has NO effect on suspension, Mercedes have separate suspension control switches.
If this helped please rate my help.
Feb 28, 2011 | 2004 Mercedes-Benz C-Class
Brother IntelliFax-2820 Plain Paper Laser Fax does not automatically print a transmission report each time we send a fax. Is there a way to automatically have that happen. We can't find it.
You need to set up the Transmission Verification Report and Journal Period in the menu table.
Press Menu/Set, 2, 4, 1.
-OR-
Press Menu/Set, 2, 4, 2.
You can use the Transmission Report as
proof that you sent a fax. This report lists the
time and date of transmission and whether
the transmission was successful (OK). If you
select On or On+Image, the report will print
for every fax you send.
If you send a lot of faxes to the same place,
you may need more than the job numbers to
know which faxes you must send again.
Selecting On+Image or Off+Image will print
a section of the fax's first page on the report
to help you remember.
Note
When the Verification Report is turned Off or
Off+Image, the Report will only print if there
is a transmission error, with ERROR in the
RESULT column.
1 Press Menu/Set, 2, 4, 1.
2 Press ? or ? to select On, On+Image,
Off or Off+Image.
Press Menu/Set.
3 Press Stop/Exit.
Printing reports
1.XMIT Report
2.Journal Period
Nov 15, 2010 | Brother IntelliFax-2820 Laser Fax
What does the 'S' and 'E' on the transmission box means. The transmission makes noise when I drive in Drive and Low
hi the S stands for Sports Mode, the E stands for Economy Mode, they speak for them selves
Oct 09, 2010 | 1989 Mercedes-Benz 190
How do i print the fax log and error report??????
The fax log or Journal is printed automatically after every 50 communications (tansmissions and receptions). If you want to print a copy of the journal;
Select Fax mode and press <Information> icon on the upper right corner of the touch panel.
Press <Print Journal>
An error report is printed whenever the transmission or reception has failed.
If Transmission result report is on, a report is printed every time so you have a record of whether it was successful or not.
Good luck and please rate me, thanks.
Jan 27, 2009 | Ricoh Aficio 2022 Black and White Copier
What does mode G3 send error mean?
The other fax machine is not G3, which is the latest configuration. Maybe a very old fax machine.
Jan 16, 2009 | HP 1040 Plain Paper Inkjet Fax
Stop Transmission Verification Report on Brother 2820
It should be under the REPORTS section of the menus.
Step through the menus to turn off CONFIRMATION REPORTS.
Sep 30, 2008 | Brother IntelliFax-2820 Laser Fax
Canon super g3 image class d880
E000 means your fuser section is having problems.sometimes you can reset but may need to replace fuser unit.
Sep 04, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
My 4216F has stopped transmitting in ECM mode.
ECM mode stands for "Error Correction Mode". This feature aids in compensating for bad line conditions. However, when dialing international calls, you cannot assess the condition ot the various telephone service companies your call might be going through. If you can transmit without problem locally, then there is no problem in your machine. You should then call your telephone company and get them to check you line connection under the argument that long-distance or international calls cannot be completed.
Be blessed.
Aug 21, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Samsung SF-750 Plain Paper Laser Fax Logo
628 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
