Question about KitchenAid Architect Series KEBC208KSS Electric Double Oven
How to clean roof of AKL 828 /1x
How do I clean the roof of my AKL 828/1x oven?
    President:
  • 1,653 Answers
Buy a can of oven cleaner suitable for use in electric ovens and follow the instructions on the can. Its basically spray the aerosol foram and wait then rinse off or preheat the ovena nd do the same and depends on the brand that you buy. It is a bit smelly but does the job! Most supermarkets and domestic appliance stores stock these products.
Posted on Sep 29, 2009
Testimonial: "Thank you very much.Iwill try that"
Euromaid oven instructions
Try search engine
Jul 20, 2014 | Ovens
Cleaning roof of oven, does the can the element be removed
Oven roof is made up of metal normally and i think Liquid Roof is best for repairing leaks. You should have a look at it.
Liquid Roof AND RV Roof Coatings
Mar 24, 2014 | Bosch HBN 131560B / 131520 hot-air...
How can I clean the roof of my Stoves 720EF Electric Double Oven
I have been using the Lakeland brush on oven cleaner for ALL of the inside of the oven including the stay clean bits without any problems. With the 720, I just brush on the cleaner and follow the instructions. To answer you question, I don't actually lie upside down, you should be able to reach it fairly easily. You may need a number of attempts to get the worse of! Be careful of the thermostat sensor at the top rear right of the oven. It should be bright and clean but will not take any heavy handed cleaning, especially the thin wire leading to/from it. FYI the fan cover at the rear of the oven is held on by 4 self tapping screw and comes off/ goes back on with any problems.(The rear of the cover by the vents build up with grease). Don't use the cleaner on any aluminuim bits ( which includes the fan) as it harms it.
Dec 31, 2011 | Stoves 720EF Electric Double Oven
How do i get inner glass door off ignis akl905 to clean it
Simple . for the ignis AKL 950 OVEN. Takes two minutes.
1/ get a 7mm socket or spanner.
2/ open door flat, no need to take off.
3/ bottom of glass, both left and right are two black plastic brackets , with a 7mm bolt through them. Undo bolt both sides.
4/ remove plastic bracket, just lift out.
5/remove door , clean.
Put back on, refit brackets and tighten bolts.
Job done.
Takes two minutes. Just remember which side of glass faces inside. think both sides same, but could be wrong.
Hope this helps. sid . derby..
Feb 14, 2011 | Whirlpool Ovens
Stove top works, broil works, clean works. I can't get the oven to heat up past 220 degrees. Is there a fuse in this model? Any idea what the problem could be? Thanks!
At the back of the oven where the sides meet the top you will see a thermastat it looks like a small knitting needle with a copper wire disapering into the back of the oven, ensure that it is not touching the oven roof or side, it should be about 1/4 "from any metal surface.
This tells your oven when to switch the heating element on and off, the copper wire goes all the way to the dial on the front of your oven.
The element is working so the problem is either the temperature dial or the thermostat.
Nov 05, 2009 | Ovens
Difficulty in cleaning my Miele combi oven
I have the same cleaning problem as Denise503 with her Miele combination oven - help if anyone has a solution - I have got to the stage where I don't want to use it.
Apr 10, 2009 | Ovens
AKL 888/01 ELECTRIC OVEN IGNIS STARTS FOR ABOUT A MINUTE THEN STO
hi did you every get this problem resolved as i am now having the same issue?
Thanks Mikala x
Mar 31, 2009 | Ovens
The screws holding the grill element to the roof of my Electrolux oven have come out.They can be removed in order to clean the roof of the oven. According to the manual, it is easy to screw these back in...
Possibly held with self tapping scerws, and hole has enlarged, all you will see are 2 small holes if this is the case, then use larger screws..
If this helps, please leave positive feedback. Thanks
Nov 26, 2008 | Ovens
KitchenAid Architect Series KEBC208KSS Electric Double Oven Logo
125 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
