Question about Intel D865GBF Motherboard
I am not able to install sound driver. when i check in bios settings there is no sound option for disable and enable.
  • 3 Answers
Http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+865+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D865GBF
Download the drivers
Posted on Sep 05, 2011
  • 121 Answers
JUST INSTALL SOUND DRIVER FROM GIVEN CD
Posted on Oct 25, 2009
  • 107 Answers
Check under onboard chip. but if you motherboard doesn't have sound device most likely there is no option on it, if you plug a soundcard into your motherboard it will detect itself as your windows starts. there install the driver.
Posted on Sep 29, 2009
Onboard sound lost after video card installation
If your PC had an onboard video card before this, you may want to go in and make sure you have disabled it in the BIOS. This has happened to me before.
Nov 21, 2013 | Biostar P4M900-M7 Fe VIA P4M900 Socket 775...
My sound is not configured and i cannot get the driver.
If you cannot get the driver then you will have to buy a sound card. You should be able to buy them fhow around $20. The card will come with a driver installation CD and instructions on how to install the card and the drivers.
If you do install a sound card, and your previous sould playback device was built into your motherboard you should disable it in the system Bios.
To enter the BIOS setup program, hold down the delete key when you turn on you computer. (On some PC's it will be the F1, F2 or F10 key). Then search through the menus until your find your on-board sound device and change the setting from Enable (or Auto) to Disable. Then exit Bios setup with the save changes option.
If you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Regards,
Yavacotech
Dec 09, 2010 | Computers & Internet
Please can you give steps to disable the onboard usb controllers to use the CPI USB Card. I've installed the PCI Card after the onboard stop working
2.4.2 USB Configuration
The items in this menu allows you to change the USB-related features.
Select an item then press <Enter> to display the configuration options
USB Function [Enabled]
Allows you to enable or disable the USB function.
Configuration options: [Disabled] [Enabled]
Legacy USB Support [Auto]
Allows you to enable or disable support for USB devices on legacy
operating systems (OS). Setting to Auto allows the system to detect the
presence of USB devices at startup. If detected, the USB controller legacy
mode is enabled. If no USB device is detected, the legacy USB support is
disabled. Configuration options: [Disabled] [Enabled] [Auto]
USB 2.0 Controller [Enabled]
Allows you to enable or disable the USB 2.0 controller.
USB 2.0 Controller Mode [HiSpeed]
Allows you to configure the USB 2.0 controller in HiSpeed (480 Mbps) or
Full Speed (12 Mbps). Configuration options: [HiSpeed] [Full Speed]
BIOS EHCI Hand-off [Disabled]
Allows you to enable support for operating systems without an EHCI
hand-off feature. Configuration options: [Enabled] [Disabled]
NOTE!!!
Do not disable the BIOS EHCI Hand-Off option if you are running a
Windows® operating system with USB device
hope above given details with give you a detailed description as you desired.
good luck
Feb 04, 2010 | ASUS P5LD2-VM Motherboard
Mnutey iuyoiu
Check the BIOS ("del" key upon start-up or "F1, F2 or F10" depending on system to access the menu). Check for audio setting (may need to scroll through menu categories to see if onboard audio is enabled). If disabled, try to enable it by hit spacebar, left/right arrow key or + - keys to change setting. If it is an add-on sound card you may need to install or re-install the drivers and in this case the onboard audio should be disabled in BIOS.
Sep 12, 2009 | ASUS K8V-MX Motherboard
I m unable to open my laptop some kind of
Are you trying literally to open up your Laptop with a screw driver or something... or are you trying to install XP on a Vista pre-installed laptop... Here's the solution...
Go to the BIOS setup [press F8 on startup], & change the disk controller setting from AHCI to IDE. might worth the try. Some Laptops don't have option of SCSI or IDE. But there are SATA Enable/Disable option. Try disabling SATA. Make sure you have all the necessary drivers for your laptop before installing windows...
Let me know if this doesn't solve the problem...
Aug 09, 2009 | Computers & Internet
Dear Sir I'm unable to install the Windows Xp in my new laptop i think this problem is with sata HDD so can i download the drivers and install in my laptop
check in bios settings the sata hard disk detect or not.if not detect then u cant install. Reset your bios settings to defaults settings then save and exit.
also check your sata option in bios is enable.try in both situation sata enable and then try sata disable.
Dec 27, 2008 | Compaq Presario Notebook
I cannot enable the on board sound card(sound Max)
check the driver status of your sound , in the device manager, if its not installed , then install the drivers or if your sound is not detecting then
go to the BIOS and load optimized bios default settings then check
Nov 20, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Have reinstalled winxp in my pc.but, now showing Kernal poroblm, and cant install realtek sound-reg
You could check in the Bios to see if your on board audio device is enabled. To get in to Bios press the Del key as the PC starts up but before Windows loads. Then pick Advanced from the options at the top of the bios screen. You should see something like this:
HD Audio Controller [Enabled]
Front Panel Support Type [AC97]
Onboard PCIEX 10/100Mb LAN [Enabled]
LAN Option ROM [Disabled]
If it disabled, enable it and save the settings, then reboot.
If you don't have the manual for the motherboard you can get it from the link below.
Also check here for latest Audio drivers:
http://www.asus.com/products.aspx?l1=3&l2=11&l3=498&model=1574&modelmenu=1
Jul 18, 2008 | Intel Motherboard
Install xp in compaq presario c700
Dear sir, I purchased a new laptop compaq presario c700. When I tried to install os it is booting from cd but it is not recognising harddisk. I checked in BIOS but I didn't find the option where to find harddisk. So please provivide the solution
Dec 07, 2007 | Compaq Presario C700T Notebook
Intel D865GBF Motherboard Logo
603 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
