Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
Electric baseboard heater
I have an older apartment building (built 1910) that I remodeled, and installed 8 ft baseboard heaters in each room (13'x13') 2000 watts each at 240v.
I am concerned about this winter. since it gets very cold here (9 degrees last winter) I am wondering if this will be enough to heat these rooms??
I have signed up for weatherization, but am still waiting on that. once weatherization happens I am confident that 2000 watts per room will be enough, but until then..... do I need to have some extra space heaters on hand to cover the coldest of days??
  • miraclemant Sep 29, 2009
    the wiring in the building was updated sometime in the past, along with 200 amp boxes for each apartment.
    also I ran new wiring to each of the new baseboard heaters and thermastats which meets code.
    and why would I "have someone" else do what I am knowledgable about and can do myself???
    by code, you are allowed to do your own wiring on your own property!!!
  • 22 Answers
This is a tough call but with 2000 watts in each room there should be more than enough heat .the rooms should maintain a average temp of 73 to 78 degrees temp without weatherazation and that is of course there is no drafts coming from any windows or near a front or back door that opens and closes alot . Basiclly you have it covered but definatley get the house winterize/insulated real good.I would keep 1 or 2 space heaters on hand just incase the person in house feels there cold just to cover yourself ,usually it the female complaining its cold if its not warm enough but there have been some males that need that temp to be 80 degrees all the time.good luck but im sure it will be ok!!
Posted on Sep 29, 2009
Testimonial: "very thought out and helpful.... just hope he is right, lol"
For space heaters 'THE MOST IMPORTANT' factor aside from wattage or power of heater is where you locate it. Putting in a corner or under a table is NOT the most efficient. A space heater, electric heater or any heater should be put under a window. It will make a world of difference as the heated air rises and heats the cold air near the window and is forced away from the cold window and into the room gradually.
Posted on Nov 19, 2014
  • 3,600 Answers
I am concerned anout your wireing di you have someone change the wiring or the Main box?
  • Bruce Hathcock Sep 29, 2009
    Did not say you coulden't do it I was asking if it was done. Did not want you to add a load on a already 125 amp main from the dark ages.
Heater sizing
12000 btu's per 500 square feet is a good rule of thumb
Jul 19, 2009 | Fahrenheat Electric Convector Baseboard...
Oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Electric baseboard heat not getting hot
Is your fuse box and main power source large enough to handle the full load if all are turned on at the same time? Are you uses two pole breakers? you might only be feeding with 110 volt. This would prevent them from getting very hot.
Jan 03, 2009 | Heating & Cooling
Electric baseboard heater hums while running
is a 60 cycle hum, resonating with the power. check screws that mount it nothing to really worry about
Dec 31, 2008 | Fahrenheat Built-In Baseboard Thermostat...
Electric baseboard heaters
measure the room, then multiply the length by the width to get the square feet you want to heat. multiply this by 10 and that is the watts you need to heat the room assuming you are using standard 220/240v baseboards.
Dec 25, 2008 | Marley Electric Hydronic Baseboard Heater,...
How to size a room for baseboard.
HERE YOU GO CALCULATE THE HEAT @ 10 WATTS PER SQUARE FOOT , TAKE THE LENGTH X WIDTH X 10 AND THIS WILL TELL YOU THE AMOUNT OF WATTAGE YOU NEED . MOST ALL BASEBOARD HEATERS ARE RATED @ 250 WATTS PER LEN FT AS TO SAY A EX. A 4FT HEATER IS 1000 WATTS , MOST OF THE THERMOSTATS ARE RATED @ 20 AMPS AS IS THE 12-2-WG WIRE TO RUN TO HEATERS AND THERMOSTAT DIVIDE THE TOTAL WATTAGE BY THE LINE VOLTAGE USUALLY 240VOLT IN US .AND THIS WILL TELL YOU THE CURRENT DRAW ----WHICH CANNOT EXCEED 20 AMPS ON 12-3-WG AND THAT IS THE LIMIT OF THE THERMOSTAT AS WELL THESE STATES APPLY 99% OF THE TIME I DO REALIZE THERE ARE EX BUT HAVE USED THESE FORMULAS FOR 35 YEARS OF DOING MY WORK AND THEY DO FINE
Dec 16, 2008 | Fahrenheat Electric Convector Baseboard...
Rinnai 556
money seems to be an issue for lots of us. but if you don't mind a coupla extra bucks get a few axial muffin fans and use them to spread out the heat pattern at your bedroom doors
Jan 18, 2008 | Rinnai Toyostove Direct Vent Heater:...
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
416 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
