Question about Hotpoint NBXR463EBWW Electric Dryer
Splendid washer and condensing dryer combo
We have a condensing dryer and it heats up the clothes but never dries them what could be the problem?
  • 29 Answers
Since the clothes ARE getting hot, it's not the tripped breaker(s) mentioned in Solution #2, because these would cut off power to the heating element(s).
Since it's a Condensing dryer, it can't be an obstructed exhaust hose, either (as there is no dryer exhaust).
Remove the lint filter(s). Holding it over a sink, see if water flows through it. The waxes in "dryer sheets" clog lint filters and, even though invisible to the eye, can totally obstruct the air flow and stop a dryer from drying. Wash it with soap and water.
Question: Does your dryer have a small drain hose leading out the back and going down a drain? If it's clogged, the dryer can't remove any more moisture. If there's no drain, then you have an internal "catch tank" to collect the water evaporated out of the clothes. It's supposed to be emptied after every load. Empty it.
If that's not the problem, I suspect your condenser is not working (removing moisture from the hot stream of air blowing through the wet clothes. This could be because: (1) It's clogged - Take out the boxy thing (technically called a heat exchanger) made of thin aluminum "fins" or tubes, and wash it off in the sink. or (2) The little fan that cools the condenser isn't running. In this case you'll need to call a technician. Good luck
Posted on Jan 07, 2008
If it's a condensing dryer, then it won't have a vent or exhaust hose, right?
Posted on Jan 06, 2008
    Scholar:
  • 146 Answers
You either have a tripped breaker (reset even if they don't looked tripped), a defective thermostat or heating element, or if the dryer is getting warm but just not hot enough, you have either a pinched off or clogged exhaust. If the exhaust hose is pinched off or clogged it causes what is called a dryer short cycling which means it will never get up to temperature and will cycle on and off. If it's not getting hot at all start with the breakers.
Posted on Dec 22, 2007
Clicking noise in splendid dryer
We did not get a book. It washed the clothes BUT water still in washer. we don't no how to put it on to dry the clothes?
Mar 05, 2014 | Splendide 2100 Vented Washer-Dryer
Wdc1025 splendide all in one combo,the dryer doesnt seem to get hot enought to dry??help
Do the clothes eventually dry over a longer period time than usual? If so, there are 2 possible problems.
1. Your dryer vent is nearly clogged
2. If it is electric, then the heating element is going bad.
GOOD LUCK
Mr. Tin Man
Dec 19, 2010 | Washing Machines
My motor yacht's Splendide Washer Dryer combo has nerver dryed the clothes
Thor Appliances - www.thorappliances.com - and LG both have machines that can replace the Splendide.
Aug 04, 2010 | Splendide Comb-O-matic 6200 Non-Vented...
Dryer will not Dry!
A conventional dryer uses 240 volts to heat air, which passes through the tumbling laundry, picking up moisture, which is then vented to the building's exterior.
Your dryer uses 120 volts to warm air, which picks up moisture from the tumbling clothes, which then passes through a vent pipe in the back right corner of the dryer where a cold water spray causes the moisture to condense, run to the drain, and then is pumped out of the washer/dryer combo. There is no exterior vent to the outside of the building. Drying with your dryer will take at least twice as long as with a standard dryer. You can wash large loads, but can only dry small loads, and the clothes will not be as dry when dryer is finished as they will be with a standard dryer.
All that said, to make sure your dryer is performing as well as it can, you might like to take the back cover off and check the elbow at the very left bottom corner (when viewed from behind) to make sure nothing is obstructing the flow of water under the tub to the drain.
Aug 21, 2009 | LG WD-3243RHD Front Load Washer / Dryer
We bought a used motorhome with a Splendide 2100 w/d combo. It does not dry the clothes, but washes fine. There was no manual on this appliance, so don't know how to find out the problem. Can you help?...
Your heating element could be out. This could be just a bad element or if you don't hear the fan come in the the dry cycle, the fan probably failed and caused the element to burn out. If your clothes are getting warm but not drying completely then you need to check your exhaust hose and make sure it is not clogged with lint.
Jul 13, 2009 | Splendide 2100 Vented Washer-Dryer
Doesn't completely dry clothing
Make sure lint filter is clean and vent pipe and outlet are not clogged.  If the clothes are getting warm then the element is working.
May 30, 2009 | Splendide 2100 Vented Washer-Dryer
Splendide 2100 no longer dries clothes
We had the same problem with our splendide 2100 top loader. If you remove the top cover, you will find 2 circular like black discs (the size of a dime) on the right hand side about 6 inches from the front. You need to push those down (with a very small blunt object) to reset them. Please make sure that you unplug your washer/dryer before you attempt this. Good luck.
Aug 24, 2008 | Splendide 2100 Vented Washer-Dryer
Hotpoint NBXR463EBWW Electric Dryer Logo
407 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
