Question about Canon imageRUNNER 1023iF Black and White Copier
Show three lines and black spote on the paper.
  • 318 Answers
First clean the scanner glass and the plattened glass with spirritos if the lines and spots still show on your copies,replace the drum unit.
Posted on Sep 29, 2009
    Problem Solver:
  • 13 Answers
Hello, you should check the 2 glass ( a small one on the left and az big one on the right ), clean it with alcohol.
If it doesn t disappear you should look in second the drum unit wich can be damaged ( usually do about 20k/25k copy )
If good too the third point to check is the fixing film ( not easy to check for a non technical person )
After you can check the transfert roller on the left door, it's a small sponge roller, look after damages on it.
Last point is the laser but i can't explain how to clean the laser protection glass.
Regards, Mug.
Posted on Sep 30, 2009
How to clean the photoconductor of E120n as the printed paper comes full of black spotes
there is a factory fault in the drum units of these machine. Replacing it with a genuine drum unit will lead to the problem reoccurring in 12 months. Replace the primary charge roller from an after market manufacturer will fix it for good and be much cheaper.
http://www.uninetimaging.com/US/EN/product/product.aspx?ProductID=11066
http://www.uninetimaging.com/US/EN/product/product.aspx?ProductID=12020
Feb 25, 2011 | Lexmark E120n Laser Printer
Epson C60 prints with ink marks on the page. I've tried cleaning it the best I can?
damil738 Streaking or spoting is usually caused by a bad ink cartridge or saturated waste ink pads (thats not common). You might try to remove the ink cartridges and with a paper towel dab around the the spikes that go into the cartridges (1 Black, 3 color) from the printer. Check the bottom of the cartridges for excess ink. If there is blockage go to Inkmizer.com, they have an excellant cleaning solution and directions to do it properly. Replace the ink cartridges no matter what you do. In most cases that solves the problem without doing anything else.
Nov 15, 2009 | Epson Stylus C60 InkJet Printer
Canon Pixma ip1500 is printing but very wierdly. random lines will not show up in black. If i change the color everything is fine but black will skip lines and such. Please help! Can't turn in job...
Your printhead is plugged and needs cleaning. If you remove the inks and then the printhead, you can wet and fold a paper towel and just dab the printhead gently on the wet towel. When you see a solid black line on the paper towel your printing should be improved.
Jun 23, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Black line on left side of paper
inside the printer on the paper pulling roller there will be some powder got collected on it due to this a black line appears on the paper.the power faLLS FROM THE TONER WHEN THE WASTE POWDER COLLECTING SECTION IN THE TONER GETS FULL SO IT FALLS on the roller while printing and this happens.take a air blower .bolw in to all the parts of the printer.keep the printer off .remove the toner cartridge.and keep the toner assessing door opened.and then blow the air in the printer.and then check out.
Feb 09, 2009 | HP LaserJet 3055 All-In-One Printer
Printer won't print out test paper.
you may try this
1) do clean nozzle cycle (do more times) until print normal, refill enough ink., not fixed go next
2) clean the color ink cartridge nozzles, put the cartridge down the soft paper damped with solvent or water, do it again untill to see three different color inkgo out on the paper.
Feb 08, 2009 | HP PSC 1600 InkJet Printer
Tally T6218 show paper out even if there is paper. what is the solution
Have to enable techmode (go offline and hold the line feed and enter button for three seconds)
then go into the test menu and do the fault override and turn off paper out sensor and then must calibrate the paper out sensor by checking and verifying voltage with paper in and paper out, this is done on the control panel.
Oct 21, 2008 | Tally Line Matrix T6215 Printer
Printer prints a line across the paper around three inch from the left hand side of the page.
Check your Toner Carts.
Is the line a certain color?
Black perhaps?
Lift the door of the toner cart.
If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well.
Is there a problem with the big orange roller?
BEWARE! Don't touch the fuser roller its EXTREMELY HOT!
Let the printer cool down before inspecting.
Apr 24, 2008 | HP LaserJet 5500dtn Color Printer
Canon imageRUNNER 1023iF Black and White Copier Logo
114 people viewed this question
old marine
old marine
