Question about Samsung SyncMaster 753S 17" CRT Monitor
No power and some ic's are burn inside - Samsung SyncMaster 753S 17" CRT Monitor
    Guru:
  • 126 Answers
All you to do bring it to the nearest Computer Center, if that problem manage the Technician then good for you but if not then buy a new one.
Power failure are the delicate troubleshoot on monitors.
Posted on Sep 29, 2009
Printer smells
it may be ur power board.
discconnect it from power first and leave for 2hras
Jun 22, 2008 | Konica Minolta magicolor 2400 Laser...
M-Audio AV20 smells like burnt
Yes, it is possible to burn an IC and not the fuse, because of Safety standards, the fuse has the function to avoid a possible fire, but it should deliver all the power needed by the circuit it is protecting, and that amount of power can burn, in this case, the IC.
From my technical point of view, there should not be a problem to connect the speaker to 110 V instead of 220 V, all that might happen is to have less power available at output, I have no idea about the reason of the burnt IC, but, as we all know, they (the IC's), don't need a reason to burn themselves whenever they decide to.
So, the next step, will be to replace the burnt IC, and that is not a simple task, you need a SMD station and some experience in doing such jobs.
Good luck and best wishes.
Apr 11, 2013 | M-Audio AV20 STUDIOPHILE
How do i get parts for behringer b215d my power ic is burn out
Regards, urgent help.
I have a powered speaker Class D, and the PWM isdead. change the IC 3525, is controled by a NE555 which is shutting down. works when connected to a higher voltage 150v, but turned it off, I think by overheating. I already changed mosfets, and ICs. I think that may be some component failure is triggering the protection, someone could help me. I'm a musician and I depend on this car for my livelihood. Thanks
Jan 06, 2012 | Behringer B215D Powered Speaker (550 Watts...
I need sheme for YPLM-M003B of LG L1717S-SN.IC in primar of power supply is burned.
I have this power board,LAF0001 pwm is the only use IC.
20 pin Inverter IC labeled (0zl68GN VKo257 5T 0647B1)
and 2 8 pin dip IC
Sep 10, 2011 | Televison & Video
The fuse keep burning
Somethings shorted inside. Could be the output IC or transistor, diod in power supply, power transformer. Somebody will have to open it up to find out.
It could be a cheap fix like a couple $4 transistors or it could be expensive, like a
Apr 17, 2010 | Cerwin Vega V-10S Subwoofer
Mixer not working and board getting hot
There is likely a voltage regulator or a diode burned out in the vicinity of the power supply. If you have the schematic, start at the power supply and work through the circuit to the I.C. Also look up the pinout on the internet for that I.C. With the power on test the voltages at each pin on the I.C. You should not have supply voltage readings on any of the signal pins. This is an indication that the I.C. is also burned out. Use a volt ohm meter with a D.C. voltage setting. Also hopefully your meter should have a diode test function. If not you can still test them with the resistance test function.Here is a link to an explanation:http://www.elexp.com/t_test.htm I hope this helps.
Mar 03, 2010 | Vestax Pmc 280 DJ Mixer
Hitachi 53UDX10B Power Light Flashing after convergence IC replacement
C603 is a polyestor capacitor 0.068UF-FEB 50V part number 0880047R S901 is the power relay ALKS329 the part number for the relay is FJ00142 . I recomend checking the pins on the ICs to make sure they are not bridged. If you need more assistance let me know. Vance Baldwin should have the parts if not you may have to order through hitachi
Jun 06, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Samsung SyncMaster 753S 17" CRT Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
