Question about Epson Stylus CX6400 All-In-One InkJet Printer
Epson CX3900 printer indicates paper jam
Epson CX3900 paper jam? no jam evident: replaced 2 ink cartridges,
carriage won't move right to left
    President:
  • 787 Answers
Check the paper road and paper sensor.Probably have a piece of paper or something else in the printer.
Posted on Sep 29, 2009
Soulvisitor
  • 1113 Answers
SOURCE: Epson STYLUS CX3900 Black colour not printing
Are you using gen. epson cart? If not then try that first.
Sounds like you have a block black print head there are many posts on that subject.
Posted on Nov 04, 2007
SOURCE: refill instructions
how can i put the ink to this printer epson
Posted on Mar 05, 2008
tipstir
  • 67 Answers
SOURCE: EPSON R230 PRINTER
electrical problem system board needs to be diagnose
Try this method to reset the printer back to factory defaults
Turn off the printer unplug both the USB and power cord for 30 seconds. Plug in the power then press and hold down the power button for 30 seconds then release. Try it again, if it still does it then contact Epson, has these printers are some sort of electrical problem with the system board.
Posted on Jul 23, 2008
aicaxz
  • 511 Answers
SOURCE: EPSON tx100 refuses to print - ink light on
ink light on? Check status monitor. Usually after jammed paper, printer trouble to recognized ink. Do change ink tank procedure, unplug and plug again ink tank.
Posted on Jun 13, 2009
cns assoc
  • 677 Answers
SOURCE: Epson CX3900 says all cartridges empty but not true
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
Also go thru the utility to change cartridges. This will make the chip know that you have all new cartridges and will move the ink station in place.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Feb 05, 2010
Ink cartridges stuck on left side of carriage. Won't move. Tried all of the suggestions and still says carriage jam.
it will be stuck in roller cleaner mode, that is mechanical. the only real way is to push it thether over to the left. with the power off the printer, then close the compartments and turn on the printer it can take 2 o3 goes as it will try to move it right. you have to get it off the clip that is holding it there. the cartridge is held in place to stop it moving while the roller is cleared.
Jul 03, 2017 | HP OfficeJet 7410 All-In-One InkJet...
Paper jam cleared but wont start
  1. Unplug the power cable.
  2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step five . Do not try to force it to move if it is hung up on something. NOTE: Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
    • If the carriage moves freely, skip to Step five .
    • If the carriage does not move, continue with the next step below.
  3. Remove the print cartridges.
  4. Gently move the print cartridge to the far right of the printer.
  5. Remove the paper from the paper In tray, but do not remove the drawer.
  6. Remove the rear access door.
  7. With your fingers, rotate the rollers "up" three full rotations.
  8. Push the rear access door back into the printer until it snaps firmly into place.
  9. Replace the print cartridges.
  10. Plug the power cable into the HP All-in-One.
  11. Turn the power on.
Step five: Reload and test the printer Once the jammed paper is removed, verify that the printer is still functioning properly.
  1. Reload the printer with plain paper.
  2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
Step six: Service the printer Perform all the steps mentioned above. If problem persists, service the printer.
Oct 31, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Red warning lights remain on.....
Ink and paper light on : head carriage error/general error. Head can't move extremely to right : head carriage blocked or CR motor error. Turn of printer, unlock head carriage lock. Move head left and back to right (to parking position). Is it move freely?
Jun 16, 2009 | Epson Stylus Photo R200 InkJet Printer
Remove ink cartridge
I found that the proper way to do it only worked when the ink light was flashing red. Then when I pressed the stop button it moved across and stopped beneath the marker to show which cartridge needed changing. The I pressed the stop button again and it moved to a place where I could change it.
This happened despite the fact that the pictures I was printing blatently showed that I needed to replace my ink, it wasn't until I had printed the liney pictures a few times that the printer decided the ink level was low enough to turn the flashing light on and let me change it.
Jan 23, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson 1280 ink carriage making noise and not printing
hello there. try re-seating the cartridge. Take it out, then put it back in.
Nov 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson R320 carriage jammed
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R320 InkJet Printer
Here is how to get the ink cartridges to move to the changing position on the R320.
1. Press the paper jam/ink button on the printer control panel.
2. A menu comes up. 1st item is ink cartridge replacement. Press
OK button.
3. Another menu with ink cartridge replacement. Press OK button.
4. Thats it, ink cartridges move to the changing position. Change your cartridge as you normally would and follow prompts on screen to finish process.
Hope this helps.
Aug 21, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson 1280 Solid red mainteance light
Hi-
Is iot on the position where you can install the ink cartridge? try turning it off and unplug it from power supply then after 10mins replug and turn it back on. keep me posted, but if it will do the same thing chances are there is something wrong with the belts on it, better have it fix or have it check. Thanks for using fixya!!
Jun 26, 2008 | Epson Stylus Photo 1280 InkJet Printer
1400 carriage
if the printer power light is off and the paper and ink light are flashing there are a few things you can try.
1. remove all paper from the printer.
2. lift cover and check for paper jam
3. check to see that the ink cartridge cover is completley closed. (the covers do actually pop themselves open and jam)
if none of these fix your problem then your in the hands of epson tech support. they can be reached @ 562-276-7282
May 12, 2008 | Epson Stylus 1400 InkJet Photo Printer
Epson Stylus CX6400 All-In-One InkJet Printer Logo
260 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
