Question about ASUS Laptop Keyboard for Asus A3V A3E A4 R20 M9
Remove keyboard from Asus A4000 laptop
Trying to remove keyboard in Asus A4000, taken back off to find hidden screw, cant find it, there are 3 clips on the top of the keyboard they something is holding it down....does the whole chassis have to come off?
    Champion:
  • 253 Answers
No i think near the processorcooling must be a scrue to hold it...
Posted on Jan 09, 2010
How to remove keyboard
The upper part of the laptop don't have screws. Just with the help of flat screw driver remove the strip on the upper side of the keyboard. After removing you will see two screws down with the keyboard . Remover the screws and remover the connector of keyboard that connects the keyboard with the mother board.
Put new keyboard and put the keyboard connector back. Screw it back and put the strip back.
Step---1
Step----2
Step---3
Dec 18, 2014 | ASUS F75A-Eh51 Laptop Computer - 3Rd...
How do I remove the keyboard from Asus K50IJ ?
Try these steps:
1. Place your laptop on a clean, flat surface and remove all power sources from it. Open your laptop screen as far as you can.
2. Use the flathead screwdriver to pop open the hinge cover. Slowly and carefully pry it open from the right side to the left side, exposing the Asus keyboard screws. Using the Phillips screwdriver, remove the screws that hold the Asus K50IJ Keyboard in place. Keep these screws in a safe place.
3. Gently tug the Asus K50IJ Keyboard component toward your laptop screen. You are trying to pull it out of the slot that is located near the palm rest and mouse pad. It doesn't take much force, but you must be firm. Once you have pulled it out of the slot, you can lift it up and remove it from your laptop.
Jun 25, 2011 | ASUS K50IJ-C1 Notebook
My Hp compaq 6515b is not recognising my power password any suggestion.
1st method identfy bios when start up " AWARD BIOS, AMI BIOS,etc etc below some backdoor passwords try these first
Award BIOS' :
AWARD_SW, j262, HLT ,SER,SKY_FOX,BIOSTAR,ALFAROME,Lkwpeter,j256,
AWARD?SW,LKWPETER,syxz,ALLy,589589,589721,awkward,CONCAT,d8on,CONDO,j64,
szyx.
For AMI BIOS' try these backdoor passwords:
AMI,BIOS,PASSWORD,HEWITT RAND,AMI?SW,AMI_SW,LKWPETER,A.M.I.,CONDO.
For PHOENIX BIOS' try this backdoor password:
phoenix
2nd method: remove the laptop battery, and in back of your laptop 3 to 4 screws showing small keybord pictured or keyboard mark, remove those screw's, turn front and 3 little hidden clips upside of keyboard, slide down those clips, carefully remove the keyboard, in motherborad near touchpad, locate the small silver color coin battery, remove that battery for 1 minite or 2. and put it back. your password will reset. and also bios resets to factory setting.( before resetting just write down the setting on paper) best of luck keep smiling. aaarwind
Jan 15, 2011 | HP Compaq 6515b Notebook
Hello How do I remove the keyboard from an Asus A6J A6000 entertainment notebook? Thankyou
2. Use the flathead screwdriver to pop open the hinge cover. Slowly and carefully pry it open from the right side to the left side, exposing the keyboard screws. Using the Phillips screwdriver, remove the screws that hold the Asus A6J Keyboard in place. Keep these screws in a safe place.
3. Gently tug the Asus A6J Keyboard component toward your laptop display. You are trying to pull it out of the slot that is located near the palm rest and mouse pad. It doesn't take much force, but you must be firm. Once you have pulled it out of the slot, you can lift it up and remove it from your laptop.
4. Take the replacement keyboard and slide it into the slot. Once in place, screw it into place with the Phillips screwdriver and the screws you removed in Step 2. Fit the hinge cover back into place by snapping it in from left to right. Power on your laptop and verify that the Asus A6J Keyboard is working.
Dec 11, 2010 | ASUS A6J Notebook
I need to remove the CD player.
There's only one screw but it's well hidden
1. At the back of the laptop remove the three screws on the support posts for the screen
2. Open the laptop fully and lift the plastic panel that has the power button.
3. Remove the 2 screws holding the keyboard in place
4. Carefully slide the keyboard towards the monitor and lift.
5. To the left of the keyboard ribbon cable is the screw for cd drive
6. Remove, slide out optical drive, reassemble.
any further help let me know
Nov 05, 2009 | Acer Aspire 3000 Notebook
How to take apart hp ze5570us to see what is wrong with the plug socket for the charger? I have taken all screws out but the computer does not seem to be coming apart easily.
First of all remove all your components ie. RAM, hard drive, battery, CD/DVD drive etc. Sometimes there are screws located in the area where these components are located that secures the top and bottom halves of the case.
I suggest that as you remove the screws from the bottom of the case you take a note where the came from as some of the screws are different lengths.
There may be s strip panel between the top of the keyboard and the LCD screen, remove this first, it will be clipped in place and held with screws from the bottom of the laptop.
Next the keyboard should removed and keyboard cable.
Look closely for screws hidden behind plastic stick on covers, you need to use a sharp thin blade to lift off these covers to reveal the screws behind the covers.
The top and bottom halves of the case is usually held in place with plactic clips, start at an opening and carefully pull apart until a clip releases and the work along that edge to release more clips. Continue along each edge until you separate the case.
The LCD screen is usually secured with screws on the back edge of the laptop and possible with screws near the edge of the motherboard. Take care to disconnect the video connector.
The motherboard needs to be removed from the bottom half of the case so you can access the power connector.
Take careful note where you remove each screw as you need to put them back in reverse order.
Best of luck, have fun.
Jun 15, 2009 | HP Pavilion ze5570us Notebook
Trouble seperating top cover from base/mobo / asus f3s notebook
Have you removed the keyboard, sometimes there is a screw under the keyboard that holds the top and bottom of the case together.
Most laptops have clips/indents that clips top and bottom half of the case together. Start on one side, preferrably at an opening where the CD/DVD drive is located and gently apply pressure to separate the case along that edge. Once you free a catch/clip start working along that edge and continuing around to each side of the case.
Mar 26, 2009 | ASUS F3SC-B1 Notebook
How do I remove the keyboard on my Acer Aspire 1640z?
Ok,
Usually there are hidden screws under the screen.
usualy under some clip or something.
if you find them unscrew the keyboard.
DO NOT YANK IT OUT!
carefully remove the cord .
PLEASE SEND A PHOTO OF THE LAPTOP for further info
Jun 30, 2008 | Acer Aspire 1640Z Notebook
Acer aspire 5610 keyboard replacement
1. you need to remove the power cover (if you see the power button, that what i mean).
2. after you remove that cover, you will see 2 screw that hold the keyboard. Remove both screws.
3. Remove keyboard and replace it with new keyboard.
May 07, 2008 | Acer Aspire 5610-4648 Notebook
ASUS Laptop Keyboard for Asus A3V A3E A4 R20 M9  Logo
832 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
