Question about Garden
Kew hobby 80-1 instructions
I need to know how to work the kew hobby 80-1 domestic pressure washer. I have one but it has no instructions
  • Anonymous Mar 27, 2014
    The. Only way to stop it is by unplugging the mains
I have a kew hobby 70 with little use. The nozzle wont spray, it just sends a weak jet of water. how can i fix it? I have hardly used it. It has been
in a shed for years . thanks
Posted on Dec 19, 2009
Do you have the schematic drawing of this model Kew Hobby 80-1??Need to open the bottom unit to check with water leakage when its on, jewt water seem
alright can spray at 80psi however water leak from the bottom of the unit.
Posted on Jun 11, 2012
  • 2 more comments
  • etan2411
    etan2411 Mar 15, 2013
    can you please reply to my queries, my email address:\
  • etan2411
    please reply the above queries to:etan2411@yahoo.com.sg
  • eddie tan
    eddie tan Dec 23, 2013
    No picture no sound!! No reply anyone??
  • eddie tan
    eddie tan Mar 13, 2015
    Hopeless No Fixya!!! answers till today 3 years!!
Kew 1640H with display flashing A 2 fault code
Hi really hope someone can help as I couldn't find a manual for my kew alto 1640hot and cold diesel pressure washer, problem is when I turn it on from been stood over night !i press on button and I see a f then a 1 flashing on the display ,anyone know what it means or we're the fault is,
Sep 18, 2011 | Garden
Kew hobby pressure washer. powers up ok but no pressure behind water jet..??
frozen output valves were the hoses attach to. two or them are present. one is inside the other
Apr 12, 2011 | Garden
Type- KEW Hobby waterblaster- requires addition pump oil. What kind of oil does it take.
Pump oil is 20 or 30 weight non-detergent motor oil. SAE20 or SAE30.
Pump oil fills about half-way up inside pump. Look for fill mark or read manual.
Of course you saved the manual, right? So you're not in line at fixya wanting a manual for some product made 5 years ago in China by a company that doesn't post manuals. Or manual is available in Italian and German with pages missing.
If this is gasoline-powered engine, do not turn machine upside down to drain oil or 10-W30 engine oil will drain into carburetor.
Nov 27, 2010 | Garden
My Hobby88 pressure washer stopped working, now I
Could be just a faulty capacitor that helps the motor to start. You will find this next to the motor if you remove the top cover.
Mar 28, 2010 | Garden
Kew Alto Force X-TRA cold water supply pressure sensor problem
Have the same p-washer (5-6 years old) and the same problem. Opened it and the pressure switch is the crook. A plastic pin has an inner and an outer spring on it (two consentric springs). The smaller inner spring is completely rusted away so the switch no longer operates correctly. Obviously the spring was of a too low quality. The service office say a new switch cost around 400NOK (50 euros) - so the washer is too expensive to mend. But I will try to get it working without the inner spring. Doubt if I succed. So will have to dump the washer.
Mar 19, 2010 | Garden
I have a Kew Hobby 80. The output from the lance is not constant but pulsates.
Could be the input water pressure is not sufficient. There is a pressure valve inside the machine that will cut off the motor if input pressure is too low or non existent.
Try a different source for the water input.
Feb 22, 2010 | Karcher PSI Electric Pressure Washer
Lost manual for K. E. W. HOBBY 88 pressure washer
Hi, Do you use the unit now. My unit of th same vintage has just failed and I would be interested in purchasing the same model slong as it works. Cliff Cason, Derbyshire DE6. Tel 01889 565574 mob 07711218929.
Sep 25, 2009 | Garden
Found this presure washer in the basement and want to know if it works the motor runs when you plug it in but does not build press. The brand is kew hobby
This may be as simple as still having air in the system.  Connect the machine to the water supply (but not the electric) then squeeze the trigger and allow water to flow for at least 60 seconds.  During that process, hold the nozzle outlet under the surface of water in a bucket so you can see when air stops coming out.  Keep going until you're sure there's no more air in the system.  Then switch it on.  If it still does not come up to pressure you'd probably be wise to abandon it.
Apr 16, 2009 | Garden
Garden Logo
3,180 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
