Question about Blaupunkt IDC-A09 5-Disc CD Changer
I'm having problems with my heater blower
I drive a 1995 Tacoma Toyota pickup, I'm having problems with the heater blower, It only runs on low speed and high speed
  • c8lynqtee
    c8lynqtee Sep 13, 2012
    Its most likely would be the blower resistor is faulty. Why!!! Because it only run's on high/low speeds.
  • 21 Answers
Bad blower resister
Posted on Apr 21, 2010
I have a 2008 Toyota Tacoma. The interior fan make a annoying ticking noise on low speed but its not noticable upon turning it to a higher speed.
ther is probly leaves or some trash in the blowermotor you will need to remove it lower righthand side of dash just 3 or 4 bolts the clean it out
Feb 09, 2011 | 2008 Toyota Tacoma
The low/med/high fan switch on my 1985 Toyota pickup is no longer working, How do I replace the heater fan blower switch?
Don't go there just yet ! Most heater motor speed problems relate to the heater resistor ! It's located in the ducting close to the motor assy and usually has 4/5 wires on to it and a 2 screw fixing. This componant must be cooled (hence air duct location) and is solely responsible for motor speeds ! You can check motor fan by test lamp/meter ! Good Luck
Dec 13, 2010 | 1985 Toyota Pickup
My AC/Heater fan blower just works on high, but when I hit a bump big enough to cause a significant vibration, I can use the other speeds (low, medium etc...). If I hit the bump again it'll just work on...
wiggle the wires behind the control unit to see if maybe there's a loose wire. If that does not work, then try tapping the climate control switch, if it works then you know it's your switch that needs to be replaced. If you want to fix it yourself, just take it out and dissasemble it and clean the unit with alcohol or nail polish remover and try it again on the part (knob) that makes contact with the board. a new unit is very expensive.
May 10, 2010 | 2005 Toyota Tacoma
Low and medium heater blower inoperative on 2006 toyota tacoma.
Resistor blown in heater. Follow the wires from the heater motor ( in foot well ) to a plug in the ducting between the fan and main heater body in centre of car. Unplug and remove the plate , it should be held in by a couple of screws. The plate should have a couple of wire coils of which , a couple will be broken. Replace resistor and heater should work.
Happy heating Marshall
May 05, 2010 | 2006 Toyota Tacoma
How do i replace the key ignition on the column of a 1995 toyota tacoma pickup, two wheel drive, 4cyl.
disconnect negative battery cable.remove upper & lower steering column covers.disconnect switch wiring connector. turn key to acc. release retaining pin through small hole in the side with a paperclip,slide key & cylinder out.re-assemble in reverse order.
Oct 10, 2009 | 1995 Toyota Tacoma
Replacing heater blower motor
this is not a problem with thw switch or motor. There is a resistor that is mounted inside the dash on the pasenger side that controls the speed of the blwer..these have a tendency to burn up after 10 years or so... replace the resistor, and you will be fine!  http://cgi.ebay.com/ebaymotors/Toyota-Truck-A-C-Heater-Fan-Resistor_W0QQcmdZViewItemQQcategoryZ33548QQihZ016QQitemZ260344846266QQrdZ1QQsspagenameZWDVW#ht_500wt_1230
Dec 23, 2008 | 1984 Toyota Pickup Deluxe
Toyota tacoma heater fan runs slowly in the 3rd & 4th positions
Using a voltmeter, the resisted voltage values for the fan motor are as follows:
LOW- 3 VDC
Med LOW - 6 VDC
Med HIGH - 9 VDC
High - 12 VDC
The fan resistor gets 12 volts from each position of the fan switch, and the 12 VDC is then lowered thru each of the 3 internal resistors inside the fan resistor. My guess is that the resistor has failed, and the resistance wires contained on it may have meshed together. The resistor is on the black box between the blower motor housing and the center of the dash. 2 phillips screws hold it in. Easy to remove/replace. Hope this helps, and thanks for choosing FixYa.
Nov 23, 2008 | 1983 Toyota Camry
Heater fan is SLOW....
check to be sure that nothing has made a nest in your blower motor.. I have found mouse nests, rats nests, and even dead snakes inside the blower motor on these trucks..with all the extra weight inside the blower, the low speeds turn slow and will burn the resistor out quicker.
Oct 12, 2008 | 1994 Toyota Pickup
What does it takes for a toyota tacoma 2000 v6 to complete the rediness test, not showing cat and evap been completed. fail smog test because the rediness test is not completed but the emissions levels...
It needs a "drive cycle". Start & run it, highway speeds, and then pull over & idle several times, then do city traffic "stop & go" driving, and then sustained highway speeds again. This completes the readiness thest and satisfys all of the monitors.
Aug 07, 2008 | 1995 Toyota Tacoma
Blaupunkt IDC-A09 5-Disc CD Changer Logo
166 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
