Question about Garden
The trimmer head is jamming up, will not idle due to head jamming.maybe the clutch has broken?. when turning head by hand you can hear it jamming up at the motor end. Any thoughts would be helpfull. 4 years old. Many Thanks.
  • 376 Answers
SOURCE: Replacing Drive Shaft for a Ryobi 725r
The lower flex shaft should cost around $40, unless you order it online and have to pay shipping. You should be able to get one from your local MTD dealer. (Ryobi is owned by MTD)
Posted on May 25, 2009
#1 Taper
  • 1040 Answers
SOURCE: trimmer head won't turn
If you didn't recently take it apart, then it sounds like you have broken the drive shaft in the neck of the trimmer. You can probably find this at an outdoor power and equipment type of store.
Jim
Posted on Jun 02, 2009
SOURCE: Stihl FS45 2 cycle string trimmer. Bought in 5/06
Dealer says shaft has broken. Stihl had a problem with some FS45's doing this. They are trying to have it repaired under warranty.
Thanks for the response.
Posted on Jun 24, 2009
SOURCE: stihl fs 45 trouble getting the cutting head to engage
repair shop shortened shaft just a touch to take up slack in drive cable
Posted on Aug 14, 2009
#1 Taper
  • 1040 Answers
SOURCE: One year old Ryobi s430 4 stroke trimmer will not start.
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to seedaylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 26, 2009
Barely used weed wacker head stopped turning clutch seams loose has play can i unscrew the clutch?allen wrench??
If your clutch is spinning you more than likely have broken the drive shaft that goes down to the head. it is fairly common with craftsman weed trimmers.
Nov 06, 2015 | Garden
Does trimmer head spin at idle
this is a hard question ,ill start with the text book answer , NO the idle should be low enough to disengage the clutch and remove power from head . but in reality this always is not possible , me I judge a clutch and engine idle % to be working correct if I can put cutting head on ground and not have it take off with throttle closed off
May 26, 2015 | Craftsman WeedWacker Gas Trimmer 25cc...
Grass trimmer head keeps turning without power applied to throttle
On an Echo, this means that the clutch is staying engaged to the walls of the clutch drum. Either the clutch drum is loose and the clutch pads are catching it as it turns, or the idle on the engine is set too high and the centrifugal clutch is just opening enough to catch the drum and spin it. Check the clutch housing and your idle speed.
Jun 12, 2011 | Echo Garden
My TB70SS cranks and runs perfect! The problem is the clutch seems to not engage. The head will spin at idle speed, but, when I pull the throttle trigger, it seems to bog a bit, and the head almost quits...
There may be an issue with the clutch or the clutch drum. Some disassembly may be required if the string head doesn't spin quickly when accelerating the engine. The clutch itself is threaded onto the crankshaft of the engine near the handle end and the clutch drum is screwed into the end of the crankshaft. If you can disassemble to that point, you will be able to diagnose your clutch problem...maybe it is worn severely and needs replacing.
Aug 14, 2010 | Troy Bilt Tb70ss Gas Trimmer
Trimmer starts but the spool wont turn anymore
you're trimmer could have one of two problems, One, if it has a clutch on the engine,( the way you would tell is if it doesn't spin when it idles. it has a clutch) Two, your trimmer would spin all the time, they use round flexable cables stamped square on both ends, which fit into square sockets one at the engine one at the trimmer head, so you're problem is either a worn out clutch, or, the cable is broken, or, one maybe both sockets have become rounded out. I hope this helps you out. Bob
Jul 31, 2010 | Poulan Garden
Cutting head on 29cc trimmer will not stop rotating at idle,cleaned filter,changed oil, cleaned spark arrester, tried adjusting idle speed, nothing seemed to help
You didn' t list the model number. Have you tried placing the head on the grass? does it stop then? It has a centrifugal clutch, if the idle speed is too fast, it will spin. There could be a broken spring or dirt in the clutch keeping it engaged.
Jul 26, 2010 | Craftsman Garden
My troy bilt tb70ss trimmer sounds like something is stripped the motor will wind out but the head wont move its only 1 1/2 years old
will need to check if any debris is wrapped around head jamming the head --or -flex shaft is jammed or damaged separate shaft from motor and will see in shaft the flex shaft that turns the head try turning head by hand and observe flex shaft if binding or broke need to lube or replace
Jun 28, 2010 | Troy Bilt Tb70ss Gas Trimmer
How to fix my echo gt200r gas trimmer I was trimming with it and it got hook on a vine. Then when I engaged the throttle it spun for a second and then stopped, tried a couple more times and it did the same...
remove the head from the shaft( tube) and remove the broken drive cable
get and fit new cable and then reattach the head to the shaft ( tube )
the gears in the head are fairly robust but the drive is a cable which twists up and pulls out of the drive squares at either end
Aug 02, 2017 | Echo Garden
Motor works fine, but trimmer will not rotate
Have an assistant start and hold the trimmer. At idle, there should still be a little drag on the clutches to make the shaft spin on that split shaft trimmer with the accessory head removed. No need to rev it or do anything fancy, but teamwork will make it safer.
Now forget about the engine and clutches - does the accessory head spin freely when turned by hand (removed from engine still!) and with a clear rotation of the shaft end visible inside the connector socket? Is the shaft end square with sharply defines angles, or rounded off? Does swapping in a different accessory function normally and as expected?
Sometimes the nub end of the shaft wears. Worse, the socket on the engine side has eaten itself to pieces. Worse, worse yet, clutches in the engine side that engage the accessory shaft are worn and there is simply no transmission of power. Good luck, hopefully this info will set your boots in the right direction!
May 08, 2010 | Craftsman Convertible 25cc. Gas Line...
Trimmer head does not turn as fast as it should. It seems like it is slipping b/c as soon as there is any resistance (place trimmer head flat on ground) it stops. Engine sounds good. Possible connection in...
Maybe, but it sounds as though the clutch may be the problem. If you can get it to run properly except for the turning of the head, check the clutch. If it is just not running with high enough RPM's, the problem may be the engine. I would check the clutch...I may be wrong and it may be the shaft. That would be an easy fix...Lee
Aug 25, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
