Question about Garden
Pulsating motor, turn machine on pull trigger, it works but not very good, let trigger off, and motor pulsates quite rapid
  • 1 more comment
  • viccarey Sep 29, 2009
    Hi, are you saying it is normal for the machine to pulsate rapid, when triggers off
    ANOTHER PERSON FROM A KARCHER REPAIR SHOP SAID IT WOULD BE A CRACK OR SOMETHING AT THE HEAD, HE DID NOT SAY IT WAS NORMAL TO PULSATE WITH TRIGGER OFF, I HEAR SO MANY DIFFERENT THINGS
    Thanks for your help and patience regards Vic
  • 389 Answers
SOURCE: When I switch my karcher k4.97 washer on it just
Well, first the easy bit... the pulsation is caused by the leak, because the machine can't hold pressure when the trigger is released.  The difficult bit is: what to do about it?  Unfortunately, there are several different places where the leak can occur and, even with the cover off, it's usually impossible to be sure exactly where the water's coming from.  In the repair shop where I work, we almost always replace every part that might be causing trouble without even trying to identify the exact source.  To do otherwise will rack the labour costs up so high as to render the job uneconomic.  We reckon that if you can't complete the job in 45 minutes it's not worth it.  Sad really, but such are the realities of our economics.
Anyway, unless you are a really competent handy-person, this is probably a job you won't want to tackle for yourself.  So your choice is either to live with it (and do whatever you can to limit the pulsating time - keep it working or switch it off immediately) or take it to a repair shop.  If you are in the UK, Karcher head office can direct you to a repairer, and I guess the same applies in many other countries too.
If you do want to have a go at it yourself, post another message here and I'll give you as much guidance as I can (but there will be a limit to the amount of detail I can provide, as I can't get in to writing a complete service manual!).
Posted on Jun 24, 2009
  • 174 Answers
SOURCE: I have a K3 78M electric unit . The motor pulsates
This sounds like an internal leak. If you are handy enough here is a schematic. On B@ it could be #25 is sticking or the valve inside #8 is leaking or the water seals #18 need replacing or #1 is leaking
Posted on Aug 18, 2009
brado83
  • 106 Answers
SOURCE: Karcher 360M pressure washer pulsating problem when idleing
unfortunately these little units have this problem commonly, 9 times out of 10 it will be the plastic head or the plastic valve block on the unit will be cracked and leaking slightly... it builds up pressure then leaks out and tries to build up the pressure again and this just reoccurs over and over...
you can get this repaired but is normally about half the cost of a new unit, if the pressure is still okay i would probably recommend just keep using it until it proper dies...
If you do get this fixed, we have studied into this and believe the main cause of heads cracking is warm water say if your inlet hose is in the sun for a period of time this can cause the water to become quite hot or if the unit sits and water trapped inside the head assy freezes can also cause this. Hope this helps Kind Regards Brad
Posted on Jan 02, 2010
Testimonial: "Thanks very much brado83. The cycling interval has now increased, so I am going to try to fix this myself.You have confirmed my part suspicions.Cheers"
jeff_drakesr
  • 155 Answers
SOURCE: Pulsating when idle
The motor doesn't pulsate when you are spraying and pulsattes when not spraying is normal otherwise the pressure will just keep building and burn out the pump. However, if you are not using the sprayer right away then the unit should be shut off until your ready to start again.
I hope the answer is helpful, please rate if the answer has helped in any way. Good Luck and have a great weekend.
Posted on Apr 04, 2010
  • 623 Answers
SOURCE: POWER CRAFT BY Karcher bought Aldi on 31Mar 05.2100Watts 130 bar.
You did winterize the machine? Leaving water in a powerwasher will freeze and damage the pump. It's a common happening, because people don't think of it or are not told by the maker.
Posted on Apr 30, 2010
Landa pressure washer LT 4035-4000 psi. Why is it losing pressure and continually pulsating?
If the pump is pulsating rapidly most likely valves are leaking or debris under valve keeping one or more from closing. If the pump pulsates slowly, comes up to pressure then low pressure then repeats, problem is pressure regulator /bypass. Or you could have a combination of both. Try lowering the pressure to lowest setting to see if slow pulsation stops. As parts age within pump and debris hinder operation you can no longer operate at full pressure. To make the pump last, use highest pressure as needed and everyday work using only 60 to 75 percent of capacity.
Mar 19, 2013 | Garden
How to remove pulsator from machine
Hi raju_zade,
Quite easy. I take it you are referring to a top loading L.G washing Machine.
- Switch of the appliance at the wall, and open the lid.
- In the center of the pulsator is a small sieve cap, open it's latch
- Inside it, in the middle is a small screw, unscrew it
- Now simply pull the pulsator from the sides, this is sometimes difficult to accomplish due to washing powder buildup, but persist and it will eventually pull free.
I hope this has helped.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 16, 2011 | LG Washing Machines
Power comes on but will not start wash cycle justs sit there and humms
Try the steps below:
- try running it without any load to see if it still hums.
- if it does, see anything underneath the pulsating disk if there's anything stuck. (like a coin or a pin)
- if it doesn't, You can also try removing the belt between the motor and the pulsator to isolate if it's a defect in the motor or the pulsator.
After that, If the motor is defective, then you'd have to replace that or repair it if you know how to. If the pulsator is defective, check again if there's something stuck in the bushings. If you've used the washing machine for quite a long time, you may need to replace the bushings and bearings of the pulsator. You can also buy an assembly unit for the pulsator if there's one available in your area.
Hope this helps.
Jan 27, 2011 | Washing Machines
Pulsating when idle
Apr 03, 2010 | Karcher K 3.98 M Electric Pressure Washer
Karcher k2.40r pulsates
It sems you have a blockage in the tip. If you get a grain of sand in the nozzle it will act like this. Get a piece of fine wire and poke down the nozzle to free it up.
Sep 02, 2009 | Karcher K2.26 Electric Power Washer
Aug 18, 2009 | Karcher Garden
Pressure pulsating when pulling trigger
you have a restriction in the nozzle end of the lance. clean with paper clip.
if not you have some dirt in the pump head valves which need cleaning
Mar 22, 2009 | Garden
The motor is pulsing on and off without the trigger being pressed
It is probably sucking air on one of the connections or around one of the fittings at the regulator. You can also turn the pressure up allittle on the regulator, that might stop it also. Make sure the clamps on the hoses going to the regulator is tite. Also it could be that the regulator is just bypassing water and if it has air in it it will pulsate.
Mar 14, 2009 | Karcher K2.26 Electric Power Washer
Garden Logo
299 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
