Question about Rangemaster Kitchen Hood
We are going to fit a rangemaster hood venting outside and the builder needs to know where to have the exit hole from the hood. Can you tell me how far up the hood the exit is situated
  • 72 Answers
The bottom of the hood should be atleast 750mm from the top of a gas burner. Measure up from this atleast 450mm for your hole to be drilled.
Posted on Dec 28, 2009
Rangemaster part 2995 A119
Hi Gerald,
for old Rangemasters it is difficult to find the original parts, as they have their outside model.
But when you open the switch carefully, you will find 2 switches on a board, one for the light and one for the fan.
These parts are common for a lot of cooker hoods. The switches look like the one of link 1
Genuine Creda CRV10W Light Bulb Switch Cooker Hood eBay
the second link gives you a complete unit, so the light switch and the vent switch on a board
https://shop.ukwhitegoods.co.uk/08086215-hygena-cooker-extractor-hood-switch-pcb
I hope you will find the right part.
Kind regards, Dik
Jan 17, 2017 | Rangemaster Kitchen Ranges
My builder has fitted an incorrect cookerhood.The installation manual says as it is a recirculation hood then there should be no gaps between the hood and adjacent wall cupboards.The replacement offered is...
Simple.. call the builder.. tell him its wrong, it does not fit...you are NOT satisfied with the workmanship of the product... have you paid them??? can you stop payment on the check?..
if he does not want to help.. there is always the Better Business Bureau, or facebook, twitter... posting bad things that ARE the truth on these WILL get his attention!!!!!!!
Sep 16, 2017 | Microwave Ovens
Just purchased the above dryer. There is NO Power in the machine. Have checked the electrical cords and power right to the machine than nothing.
  • Measure the amount of distance between your dryer and your venting exit point. This is how many feet of duct to buy. Note how many turns the duct will need to make, and purchase that number of 90-degree fittings. Remember that your venting exit point must be at least 1 foot above ground level, and that your path shouldn't be longer than 25 feet, with 5 feet subtracted for every 90-degree turn.
  • Drill a hole through the wall in the area you'll install the vent. This step is to test for obstructions. Look for the hole outside, and check for obstructions there, too.
  • Bore a 4¼-inch diameter hole into your designated and tested venting exit point, using your bi-metal hole saw on your drill. Start the hole outside of the house. Brace the drill against your leg to help keep it steady, and pull it out frequently to avoid overheating the tool.
  • Install your vent's cap by screwing it over the hole you just drilled. Caulk around any gaps.
  • Cut away excess length from a straight section of duct using your tin snips. Construct the entire length of your duct by snapping the seams together. Start at the dryer. Attach one end of your duct work to your dryer's exhaust point, which is at the back of the dryer. The pieces should fit together snugly.
  • cover the seams between your 90-degree fittings and your straight lengths with metal foil tape. Connect the last piece of metal duct to the cap you installed earlier. Every 5 feet, attach the metal duct work to the wall using metal pipe straps and screws.
  • Plug in your dryer and turn it on to test your work.
  • Dec 20, 2010 | Dryers
    I have one not vented out side is that normal? It has slits on both sides.
    Please check your manual as many hoods can be recirculating, if this is the case then you should also make sure you have a charcoal filter fitted.
    Dec 06, 2009 | Rangemaster Kitchen Hood
    Want to use without outside vent
    sometimes rangemaster hoods have a filter system. check with them if your model does this. nuber for tech help by them on internet.
    Mar 13, 2009 | Rangemaster Kitchen Hood
    Install a Thermador UCV36 cook'n'vent
    Hi schmidt_rich,
    I'm Harvey the Master Plumber.
    Your question is: You took over as owner builder when your builder "took the $ and ran". You are installing kitchen cabs now and discovered the PVC vent pipe (which goes into the foundation and out the side of the house) is in the wrong place for the location of the downdraft unit and integral blower. The vent is actually under the electrical connection panel. You were told initially( 2 yrs ago when you bought the downdraft cook'n'vent) there could be no bends in the exhaust fan route or it would change the effectiveness. Does anyone know if it is ok to put a bend in the connection to the vent? Or do you need to redo your kitchen cabinets?
    I can syphathise. I have had to deal with this same problem. I have found that one ell will not degrade the effectiveness enough to notice. If you need more then you may need to adjust cabinets.
    Feel free contact me again!
    Please give me a rating here at fixya.com before you sign off
    Thank you,
    Harvey your Master Plumber
    Sep 24, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
    Kitchen hood
    Yes you can , usually they got hole on top too , just make sure when its done that the air is going out and it will be fine . I
    Aug 22, 2007 | Whirlpool (RH3736XLS) Kitchen Hood
    Rangemaster Kitchen Hood Logo
    136 people viewed this question
    Top Rangemaster Kitchen Ranges Experts
    Ismael Rodriguez...
    Paul Carew
    Charles T Nevin
    Charles T Nevin
    Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
