Question about Transcend (589307) Media
I am having problem with my pendrive
It always shows the message that
"usb device not recognized" pls help in solving the problem
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 29, 2009
My toshiba 8 gb pendrive is not recognised by desktop,
does this pendrive work on other computers if it does then use a different usb port if it wont replace pendrive
Aug 01, 2014 | Microtoolz PenDrive Autorun
Why my pc shows your device is unrecognized when i connect my pendrive to pc
it may be due to malfunctioning of your USB port, just try to plug out and then plug it into another Port
Nov 22, 2011 | Electronics - Others
Recognized my 4gb transcend pendrive
Try windows repair, it should fix the problem.Else connect the pendrive and check the port settings.You can check for the port settings by
right click on "my computer"-->properties-->hardware-->device manager
A new window opens and at the bottom probably you'll find "Universal Serial Bus controller". Expand that option and check whether all the ports are enabled.If the pendrive is still not detected, then the problem is with the port.Check the same with the other available ports.Any further doubts add comments.Would be glad to answer.Good luck.
Jan 21, 2009 | Transcend (589307) Media
When pendrive is connected shows device has malfunctioned
when i connedted my pen drive i show has malfunctioned
Dec 14, 2008 | Transcend (589307) Media
IPOD MP4- USB DRIVER NOT RECOGNIZED BY XP
Hello!!!
Try connecting to different USB slot!! and try changing the cable too!!
Oct 26, 2008 | Apple iPod nano
My 4gb kingston pendrive is not recognize by any computer
Hello
For Solving your problem do the following
1. Check that the USB is connected properly to the mother board
2. USB 2.0 Drivers are loaded
3. See that the Pendrive is properly connected
Let me know that your problem is solved and rate me as Fixya!
Sep 12, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Transcend 4gb pendrive not being detected in Win XP
my 4gb pendrive is not detecting in my win xp operating system,before 2,3days i repaired my operating system,after that it is not detecting..pls help me
Jul 23, 2008 | Transcend (589307) Media
Transcend (589307) Media Logo
80 people viewed this question
Top Transcend Electronics - Others Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
