Question about General Ovens
Thermostat lead broke off at control ****. in
The rmostat lead broke off at control ****. in caravan oven need a new one..Where near Box hill Vic
I pulled it out and threw it in the rubbish tip.!
Posted on Oct 04, 2009
Were is located the thermostate
The thermostat is solid state, it is incorporated into the control board. You can however locate the temperature probe which goes into the left side of the back of the control board and goes into the top of the oven under a cover near the air pressure switch and high limit thermostat. To locate follow the small aluminum tube coming from your exhaust stack, that will lead you to the air switch which is next to where the temperature probe enters the heat exchanger compartment.
Oct 07, 2010 | Baxter BXA2G Stainless Steel Gas Single...
Sparks from the thermostat control! - frigidaire oven
you may have blown the control board. or blown the ac main control fuse for you home wiring. this is in your fuse box cookers have there own fuse separate from other appliances.
Jun 13, 2017 | Ovens
No temperature control in Oven, even with a new thermostat
If you are certain that is wired correctly, and is the same as the old one, having made sure you have got the sensor located correctly,then it should click off the element at the set temp.
If it does not, then that leads me to suspect that the new stat is either faulty, or the wiring is not as it should be,I do not forsee any other reason for it not to cut out.
Jan 16, 2010 | Ovens
I think I have a bad thermostat.Where is it located on the oven
hello these ovens they have a dial type thermostat or electronic touch pad controller , either model will have a probe in the oven it is a capilary tube at the rear or side in the internal space of the oven , follow that probe and it will lead to the thermostat ,and that part will need changing, if faulty, are sure that the thermostat is bad
Dec 13, 2009 | Dacor ECS130 Epicure Electric Single Oven
KitchenAidKEBS107: NO HEAT after power failure during self clean
Thermostat on the back needs replacement. The problem is caused by overheating the oven. Improper installation or inadequate blower. Depending on the model, the oven might need a new blower in addition to the thermostat. Try calling KitchenAid to find out if the oven needs that blower and get the part number for the thermostat, they might have replaced it with the one with higher temperature rating.
Nov 26, 2009 | KitchenAid KEBS177 Electric Single Oven
I need the squematic wiring GE 24" Built-In Gas Oven
I have the same problem -- did you ever get this question answered?
Feb 28, 2009 | GE 24" Built-In Single Gas Wall Oven
XL 44 Gas Range Oven temperature problem
hi If the oven doesn't heat evenly or doesn't heat at all, the oven thermostat may be malfunctioning. First, determine how much the temperature in the oven is off from the control setting. To do this, put an oven thermometer on a center rack inside the oven and turn the oven on for about 20 minutes, with the thermostat set at any range between 300 degrees and 400 degrees Farenheit. If the oven thermometer reads 25 degrees or more lower or higher than the oven control setting, the thermostat should be recalibrated. Here's how to calibrate the thermostat:
Step 1: Pull off the thermostat knob on the control panel. Behind the knob are two screws holding a round, notched plate. Loosen these screws, but do not remove them.
Step 2: With a screwdriver, change the notch setting on the notched plate by turning the plate counterclockwise; for every eighth of a turn, the oven temperature goes up about 25 degrees Farenheit. To turn the heat down, turn the plate clockwise.
Some thermostats can be adjusted by turning a screw inside the control knob shaft housing. To do so, remove the knob and insert a screwdriver into the shaft so that the screwdriver blade engages a screw slot. Turn the screwdriver counterclockwise about one-eighth of a turn to raise the heat about
25 degrees Farenheit. Here's how to test a malfunctioning thermostat:
Step 1: Test the thermostat with a VOM (multimeter) set to the RX1 scale. The thermostat is located directly on the back of the control knob that regulates the heat. To gain access to the thermostat, remove the back service panel to the control panel.
Step 2: Disconnect one electrical lead wire from a terminal of the thermostat and clip one probe of the VOM to each thermostat terminal. If the thermostat is in working order, the meter will register zero. If the needle jumps to a higher reading, the thermostat is faulty and should be replaced.
Step 3: If necessary, replace the thermostat with a new one of the same type.
If you need to replace the thermostat, follow these guidlines:
Step 1: Disconnect the terminal wires to the thermostat and pull off the control knob.
Step 2: Remove the retaining screws. On some ranges, there is a wire running from the thermostat into the oven. This wire operates a sensing bulb that controls the thermostat. The sensing bulb is usually held by a bracket; unscrew this bracket to remove the bulb. Then carefully slip out the wire, the bulb, and the thermostat.
Step 3: Install the new thermostat using a reverse procedure.
Nov 06, 2008 | Ovens
Frigidare wall oven pleb30sccc
i ran a new lead wire copper new breaker from a new breaker box it was alum wire i guess it was droping amps on one lead
Jun 24, 2008 | GE Profile JTP18 Electric Single Oven
Ovens Logo
99 people viewed this question
Top General Ovens Experts
Oloyede Monsuru
ray gallant
Melissa Martin
Melissa Martin
Are you a General Oven Expert? Answer questions, earn points and help others
