Question about RCA HDLP50W151 50" Rear Projection HDTV
RCA DLP/HDTV Vertical Lines
We have owned RCA DLP HDTV model HD50LPW42 for almost 3 years. After the first year we had to replace the bulb. Since that first time, vertical lines appear on the screen and we have no idea how to get rid of them or where they come from. They appear then dissappear for a few minutes then reappear again for a longer period of time. It looks as though, sometimes, they try to go away, but no luck. We thought the bulb, lived through it, and the bulb went out. 2nd year...replaced bulb again, lines still appear. What do you think is causing this? Please help!
  • Larry A Jan 22, 2008
    Black vertical lines appear across the screen with a spacing of about one inch from line to line. The lines appear upon power-up and do not disappear the entire time the set is on. Other days the lines do not appear at all. The TV is the RCA Scenium HD50LPW42. I replaced the bulb about 2 months ago and I don't recall seeing the lines prior to that.
  • David Barna
    David Barna Feb 23, 2008
    Same problem, same TV (RCA Scenium). In addition, we are on our third lamp in four years. Now we have vertical lines come and go. We tried unplugging the TV for 5 minutes so the TV can "reboot." It takes about 30 minutes and the lines come back. They used to only appear about 5 minutes after the TV warmed up, they would stay on for about 5 minutes and then they would disappear for good. Now they come on and stay on 95% of the time. The lines are mostly white and green.
    I called RCA and they never heard of this problem and suggested that I call a local technician.
    Please help if you find a solution. This TV cost us $3,000 4 years ago and we should not be having this problem. Frustrated consumer DJB - 02/23/08.
This is djb1 who commented above on the vertical lines that have gotten progessively worse. I may have found a potential solution. I unplugged the TV, took the back door off where you replace the lamp, took the lamp out, changed our vacuum from a vacuum to a powerful blower and blew ALL visable dust off anywhere that I could. I paid special attention to the heavy dust that was on the TV blower fan blades and around the mirror. I also held the blower on the outside of the TV on the vents around the lamp door.
After I plugged the TV back in, the lines have disappeared. We watched TV last night for about 2 more hours and the vertical lines never came back. So far this morning, the lines have not come back and it has been a couple hours as well.
It's worth a try. The free solution may be as simple as clearing out all dust. LET'S HOPE IT'S A PERMANENT SOLUTION!!
Posted on Feb 24, 2008
  • David Barna
    David Barna Feb 27, 2008
    Djb1 here again. After 1-1/2 days, the vertical lines came back, but not nearly as bad so this time after unplugging the TV, I took the whole back off the TV and cleaned all the dust that I could see. So far, so good. This good be the solution. CLEAN THE DUST OUT OFF THE TV!! You'll be surprised of how much dust there is.
Rest your input source, if is a cable set top box power down and back on, if need be perform a manual rest on the cable box.    Michael
Posted on Sep 13, 2008
Third time replacing 65" mitsubishi dlp bulb ?
Use Osram or Phillips bulbs
Check for blocked air flow
Always allow TV to complete cool down with plug in wall
Check/Replace ballast
Aug 22, 2016 | Mitsubishi WD-65638 65" DLP HDTV
Samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
Jul 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
My rca dlp doesn't turn on
You probably need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 11, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
MUST READ THIS I have a rca 61" hdtv purchased in 2004 with a 5 year extended warranty (thankfully) and have had nothing but problems with it. it is the worst thing i have ever bought.exactly 13 months...
All DLP TVS are lemons really.Most the Convergence ICS,they use on the board held the picture together will alway die about 1 year or 1 1/2 year all way need it replace.The bulb have life spans but never reaches alway dies before than.
Apr 01, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
Vertical lines
do you have a cordless phone placed nearby?
i just had that problem, and realised it was because of the phone's frequency (scary!). i move the phone/base away from the tv, and it's fine now.
Oct 10, 2009 | Samsung HLN5065W 50" Rear Projection...
Vertical lines on Mitsubishi 62" DLP
the DM and/or the FMT board are going bad. the chassis needs to be rebuilt. check out www.tv-techs.com
Jan 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Samsung DLP vertical black lines
I did some reading on this. They said its caused by a faulty DMD board. I understand it's costly... around $700 to replace. Still looking for a cheaper avenue...
Apr 28, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Thin Black Vertical Lines 8 in each row, 9 rows. Whats wrong?
Hope its under warranty! your DLP chip itself most likly is bad or If you are very lucky.. its only dust on the DLP chip,,
Time to take it to the repair man.
Feb 09, 2008 | Samsung DLP HL-P5663W 56" TV
RCA HDLP50W151 50" Rear Projection HDTV Logo
459 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
