Question about Tecnik 24 in. TKD795/3 Built-in Dishwasher
Water is going in the bottom where it drains but thats as far as it goes
    Sergeant:
    Champion:
  • 205 Answers
Hello sir/mam
you please change the drain pipe 'o' ring inside the dishwasher and check the drain pipe.
Posted on Sep 29, 2009
Washer tube will not fill with water but the water is going in
You most likely have a siphoning effect in your drain line. Either drain hose is too far down house drain pipe, or there is an airtight seal where drain hose goes into house drain.
Sep 24, 2017 | Washing Machines
Washer WPSR3100WOWW Will wash but not drain and spin... Stops at the rinse Cycle
Christina,
Does it leave water inside the tub? There are a couple of possibilitys. One could be the drain pump. If this fails the wash/rinse cycle will stop as it can sense the water not being pumped out. Can you hear the light sound of a small motot running when it goes into rinse cycle? Listen down at the very bottom far right side or far left side. If you hear the drain pump motor running is there any water discharging out the drain tube going into the wall? You should easily hear the flowing water. If not you have a few possible problems: Drain pump has an obstruction in or around it or, drain pump is actually bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 12, 2013 | GE WSXH208A Front Load Washer
Water dripping under the rim, into the tub
Sounds to me like you have a siphoning problem You probably have your drain hose too far down in the drain pipe. When this happens the drain hose goes into the trap of the drain pipe. It then pull the water from the drain pipe back into your washer cause it cant break the vacuum. Pull your drain hose up so that on a little bit of the pipe is sticking down the drain pipe
Aug 25, 2012 | Maytag Washing Machines
Our defrost drain in our Whirlpool top freezer continues to freeze over and plug up. We use a steamer and open in completely, where water and air go all the way to the bottom drain pan. A week later it...
put a heater probe into the drain hole part number WR51X10052
go here to see it
https://www.searspartsdirect.com/part-number/WR51X10052/0046/363.html?utm_source=google&utm_medium=cse&utm_term=WR51X10052&sid=SPDxGPROD&k_clickID=91e4144b-538a-4990-a8d5-3905e4f67477&gclid=CjwKCAiAy4bTBRAvEiwAFtatHB4gQqpl7P8Z0Db6BqBsHtm1zbl6AOrYVStzcg9y44J5cN_oIxLzeRoC2D0QAvD_BwE
stick it into the drain hole to see how far it will go without hitting anything,then rap the other end around the heater,when the heater comes on to defrost the fridge the metal heats up and stops the drain from freezing,also after you steam it and this is what i use it's the best way to do this,pour hot water down the drain and make sure it goes down and out,if you remove the back bottom panel check the bottom of the drain hose sometimes dust gets in the bottom of the hose where it bends or it's like a trap on bottom of hose,just check it to make sure it's clear,if it is and you put the heater probe in you should be all set,you can make a probe out of copper wire that's in the middle of regular house wire if you have any,just remove like 6 inches of the copper stick it into the drain hole and rap the other end around the heater will do the same thing,hope this helps you out.
Jan 19, 2018 | Whirlpool (ET8FTEXSQ) Top Freezer...
Water continues to run, never fills and continue the washing cycle
If I understand you correctly you are saying that a good amount of water will go into the tub but it never get full enough to start the wash cycle.? Obviously its not leaking all the water out or you would see it.. I know this may sound strange but check to see how far down your drain hose goes into the wall drain,I have had many that do this same thing and the hose from the washer was to far down into the wall drain and the water would SIPHON OUT OF THE TUB FASTER THAN THE WATER COULD GO IN hopefully this is you problem secure the hose so only about 6 inches is in the wall drain.. Hope this was it Good Luck
Sep 24, 2010 | Kenmore 24032\24036 Top Load Washer
I have water in my refrigerator on the shelves and in some areas it is freezing?
Could be a clogged condensate drain. Since you did not give a model #, I will assume this has the freezer on top. When it goes into defrost, the water cannot go down the drain hose to the drain pan and accumulates as ice in the freezer, below the bottom liner and may drip into the fridge. Empty the freezer and open the fridge door. The open fridge door can help thaw the drain. Remove the screws holding the bottom of the freezer liner and remove the liner. If there is ice below it, the drain is clogged. Remove as much as possible by hand and then use a hair dryer to carefully melt the ice at the back of the freezer. Blot up any water from the melted ice and concentrate on clearing the 1/2" hole in the center back. That is the drain. When you think the drain is clear, check it with a large glass of hot water. This can be take some time. When done, reassemble, but also make sure the fridge is tilted to the back by adjusting the legs at the front bottom corners of the fridge. You may have to take the grill off the bottom of the fridge to do this. The legs screw down to lengthen them. Adjust them far enough down that the fridge door swings shut by itself. This will help the water down the drain before the fridge comes out of defrost, starts cooling and freezes it in the drain hose.
Mar 03, 2010 | Whirlpool Refrigerators
Water running out from under vegetable and fruit
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Hook the other end , around the glass rod (defrost heater) carefully , to avoid breaking the glass , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Jan 01, 2010 | Refrigerators
Water dripping in to freezer bottom ten pools on
Sounds like you have a drain that is plugged. When it goes into defrost the water hass no place to run. Thats when you get water like that. I would defrost it completly. Then try to get to the drain and pour hot water slowly to see if it goes all the way down to the pan. If not. Yu may have to have air pressure to go thru the drain.
Aug 30, 2009 | Refrigerators
Tecnik 24 in. TKD795/3 Built-in Dishwasher Logo
240 people viewed this question
Top Tecnik Dishwashers Experts
Renee Knafel-Bullock
 Mikey
Mikey
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
