I am trying to use Photoshop to crop and enhance my camera shots. Then save to a jpeg file then send to Pogo. Some print some don't. (bottom red light flashes) What do I need to do for the Pogo to print properly? Is it file size, resolution crop size? PC Vista Home 32 bit 4 ram Thank you Colin
Hi, how do I get my photos to be 300dpi? I have a panasonic DMC F27. Do I do it in photoshop? Sorry, I know very little about cameras. Thanks
1. Select Crop tool
2. Select Resolution
3. Type in 300
4. Crop whole picture as desired
5. Click done
6. Then Save file as jpeg
7. Make sure max quality is on
8. Then click okay
May 03, 2011 | Cameras
I cannot print pictures taken in nef format. Can
Hi dear, most printers can only use jpeg or bmp format .Use Irfanview to convert raw file to either one.
Jan 17, 2010 | Nikon Coolpix 5700 Digital Camera
How can i use my polaroid pogo with my laptop?
This should work. First check your Notebook to see if it is BlueTooth enabled. If not don't worry you'll need to buy a USB Dongle. (about $8.00 street value Check eBay.)
Go to Control Panel >BlueTooth run the wizard. Enter code 6000 the code to recognize your Pogo. Normally the Pogo will accept a jpeg
from your camera. If you intend to manipulate your jpeg in any way say with Photoshop - I mean crop or enhance - sharpen, hue, saturation changes you might not have any success. There seems to be very little technical info for the Pogo printer. Very poor of Polaroid such a well respected name.
Colin
Sep 27, 2009 | Polaroid PoGo Digital Photo Printer
Bluetoth connection
What's 02 lg cookie. Normally cookies have to do with websites.
The technology of the PoGo printer is to send a BlueTooth jpeg file.from your camera/pc to the pogo printer. Nothing to do with website browsers.
Sep 24, 2009 | Polaroid PoGo Digital Photo Printer
Camera RAW and PhotoShop CS3
To start, before building an action or a droplet to convert from Raw, you need at least either the RAW plugin, or the photoshop lightroom plugin, depending on the version of Photoshop. I assume you have the plugin installed on your Photoshop. See: Adobe - Adobe Photoshop CS4: Digital camera raw file support.
A better choice would be having the Nikon Capture NX , that give you the option to work on the native RAW format from Nikon.
Once you have installed a plugin to manage RAW format files you can record an action or droplet to automate the process. If youj want more automation, you set an action first, as a batch process to do action on a single file, then build a droplet on the action batch file. A droplet will give more automation, since droplets can be activated by dropping a folder of images onto that specific Droplet Process, and they will apply the batch process to all the files contained in the folder.
The way you build the batch action depends much on the version of Photoshop you are using and on the plugin used. Here an example using Adobe PS CS2 and camera Raw plugin: Raw Format Workflow with Adobe Bridge .
The action can be saved using the recorder, so that the procedure will de quite instinctive. See the tutorials below for step-by-step instructions.
See also:
Adobe - tutorial : Lights, camera, action!
Batch Processing Camera RAW images in Photoshop CS
Creating a Droplet : Adobe Photoshop Tutorial
Jul 28, 2009 | Computers & Internet
Jpeg Encording
If you want to save a JPEG from Photoshop, use SAVE AS under the FILE menu. In the FORMAT drop down menu, select JPEG.
I hope this helps.
Mike
Jan 06, 2009 | Adobe Photoshop CS2 for PC
Can you connect a PoGo Polarioid printer to a computer for printing
I connect to my pogo via bluetooth with my laptop, To print a picture - Right click on the picture file and send to the bluetooth device.
I would love to see a rinter driver for it myself.
Dec 27, 2008 | Polaroid PoGo Digital Photo Printer
Saving the pictures to my computer
Try copying it again from your camera to your PC. If you browse it in your camera do you still see the images? If you do see the images, it is just a copy problem...
Dec 09, 2007 | Pentax Optio S5i Digital Camera
Enhance pictures
You don't need to buy photoshop realluy, you can download for free from this site. http://www.adobe.com/products/photoshopalbum/starter.html
Nov 01, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
37 people viewed this question
k24674
