Question about Magic Chef MCBR440 Compact Refrigerator
I've lost my manual and forgot which way to set the thermostat. from 0-7 which number makes it the coldest? it's always been set in the middle and i find i'm using it more now. model # MCBR440 compact. thanks for the help. Coco
  • 555 Answers
Usually the coldest setting is 7. According to the manufacturer, the usual temperature set on your fridge should be 4.
Posted on Sep 29, 2009
I have a mini fridge from chef mate that does not have a freezer in it. It won't keep temp cold even though it's on highest cold setting. Any answers?
in a fridge the highest or coldest setting is 1 or 0
the bigger the number the warmer the setting
door seal /door not closing properly
have a technician check out the thermostat for correct operation
Dec 10, 2016 | Refrigerators
How do I fix a thermostat that appears to have lost its programming?
Have you changed the battery?
usually the battery compartment (and the model number) on located on back of thermostat
Look up manual on internet
Gene
Water Heater Timers Save Money
Nov 11, 2014 | Hardware & Accessories
What is the coldest setting on a Chefmate mini fridge?
Well, mine is set to 1 and it freeze everything in the fridge! I'm going to try the opposite
Sep 10, 2014 | Refrigerators
I've forgot my code for samsanite case and its locked please help
Set the lock on 999, push the buttons on the latches to the outside. If that doesn't work, roll the last number from 9 to 8 and try again. Then roll it to 7 and keep trying, rolling the last number down to 0. Then roll the middle number from 9 to 8, and move the LAST number to 9, and start the whole thing again. When you get to the end of that, roll the middle number on down to 7 and the LAST number on down to 9. Keep doing this until it unlocks (note the numbers at that point to remember!), or, you may have to go on down through the first numbers as well. You only have 1000 possible combinations. That sounds like a lot but if you are watching TV while you are mindlessly rolling a number wheel and then pushing the latches out, it's not too bad, only about an hour ... your thumbs will get sore. :-(
May 31, 2012 | Photography
Refrigerator is not getting cold enough?
Hi, Please check setting of thermostat. If it is set for middle position , set it a little corder. If your thermostat has bet set for coldest, the most probably cause it your refrigerant is insufficient and need to top up.
Dec 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
How do I set the temperature?
Hello Elise, The Dial should be set to the middle number three (3) to start with and allow for 24 hours of running before you make any adjustments, either up or down.
The higher the number the colder the fridge temperature will be. Just remember that it takes almost a full day for the fridge compensate for any changes to the thermostat. Also, only make adjustments in the temperature setting by only 1 increment at a time (either up or down) and again, allow 24 hours before making further changes.
If your fridge has the red button in the center of the temperature dial, that is the manual defrost button. So if you've got a build up of ice on the freezer section, just push it and it will defrost the unit for up 2-4 hours.
Hope you find this Very Helpful and best regards!
Merry Christmas!
Dec 14, 2009 | Magic Chef MCBR440 Compact Refrigerator
I need to know what the numbers mean on the temperature setting (1-7) for my Gibson Upright Freezer? What is best recommended temperature?
The highest number is the coldest setting.When you fill it up with food to freeze , set the freezer to the coldest and after everything is frozen .set the control to the middle.
Oct 05, 2009 | Freezers
Welbuilt Refridgerator (old) - Which way is coldest - 0 or 6?
Most controls work with the highest number being the coldest. Keep in mind that once you adjust that setting you should allow 24 hr for the refrigerator to "equalize" to it new set temp. Hope this helps
Sep 09, 2009 | Refrigerators
Defy Fridge temperature dial is confusing - which way is colder?
0 = off, 1 = cool, 2 = cooler, ..... 7 = coldest.  0 - 7 Nothing to do with the degree the fridge is set to.
Jan 07, 2009 | Refrigerators
With the BevAir DW49 does a lower number mean colder or warmer?
1 is usually the warmest setting. The higher the number to colder the setting. Start in the middle and make minor adjustments allowing considerable time in between to dial in the temp of your unit.
Dec 04, 2008 | Beverage-Air DW49 Stainless Steel Beverage...
Magic Chef MCBR440 Compact Refrigerator Logo
1,278 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
