Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
I have tried to uninstall epson TX100 printer from my computer by using add & remove programs but this does not work . How can I get it off my computer?
    President:
  • 828 Answers
Only System Restore can remove that programs inside in your Computer. When that options in the Control Panel is also necessary to uninstall & remove by using that Printer Utility Disk to be inserted into your PC. That Disc will help you to remove the Printer.
Posted on Sep 29, 2009
My computer doesn't recognize my printer even several attempt of software installation is performed.
Before you made several attempts to install you Epson Printer Software.Did you Uninstall the software first? To reinstall your Printer Software . The old program that did not work properly has to be uninstalled. Go to your Add and Remove Programs In your Contol Panel and uninstall your Epson Printer Program Software .Then restart your computer.Then try Re-installing your Epson Printer Software.
Jul 30, 2010 | Epson Office Equipment & Supplies
That is the problem. How do you uninstall it? Because the Manual doesn`t give any information as to how it`s done.
Uninstalling depends on several things.
If you used "Add & Remove Programs" to install (some programs automaticly register with "Add & Remove Programs") you can just go to "Add & Remove Programs" and choose "Remove Program"
If that option isn't available, look in the programs folder for an uninstall program (often listed as "unwise")
If neither of these work you'll have to do a manual uninstall. This takes some advanced understanding or the operating system to do without risking messing up the operating system. You'll need to delete the program(s) manually then use the registry editor to remove the references to the program. Be sure to back up the entire system first and then the registry before beginning (one bad key stroke can corrupt the entire OS).
Note: I didn't give step-by-step instructions on the manual uninstall because if you don't already know how you shouldn't try.
Jun 21, 2010 | Epson Stylus RX650 All-In-One Printer
I have an epson stylus TX100 and its not working @ windows 7
I found Epson drivers for Win 7 at their web site (Australian version):
http://tech.epson.com.au/downloads/category.asp?sCategory=Multi_Functional&id=StylusTX100&EmailAdd=&CanEmail=&SelOS=Y&MetricIDReturned=3429820&sCategory1=Multi_Functional
Pick your version of the OS and click through (I had to go through a couple of pages).
If you initially installed a generic Win7 driver or an older version of the Epson driver, you may want to uninstall the driver and start again with the USB cable not connected to the computer.
I hope this helps.
(the site I started at:
http://www.epson.com.au/Products/multifunctional/Stylus%20TX100.asp )
Feb 19, 2010 | Epson Office Equipment & Supplies
Why my tx100 printer can't work with vista
ISSUE : Epson Stylus TX100 is not working with VISTA Computer
Environment :
Printer : Epson Stylus TX100
Computer Operating system : VISTA
Analysis : According my understanding your printer use to work with different operating system like XP Home /Prof. etc But it is not working with VISTA
SOLUTION :
Cause of your problem might be : Software issue
To get the print out of printer your computer need to have a driver software on it. You can check the compatibility information written on the CD / DISK itself
Else you can also download the Compatible drivers from the following link of EPSON
http://www.epson.com.ph/epson/drivers/driver_download.htm?dc=1&mode=3&m=false&catid=4&pid=1373
or you can simply open www.epson.com
and click on Drivers and Support and select the printer -- you can easily download the drivers ...
I Hope it will solve your issue
Jan 02, 2010 | Epson Office Equipment & Supplies
Epson Stylus TX100 printer Woeks but scanner not
It is a scanner as well, but you have to access the scanner through the software that came with it
Aug 27, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson dx6050 printer
A regular remove and reinstall will not correct this issue. To remove the French/Spanish/Portuguese language driver and get a working install of the English driver, use the detailed instructions below:
STEP ONE: USB PRINTER DRIVER REMOVAL
1) Click START and select CONTROL PANEL.
2) Click ADD/REMOVE PROGRAMS.
3) Find EPSON PRINTER SOFTWARE and click on it once to highlight it.
4) Click CHANGE/REMOVE.
5) Select the icon for your printer on the MODEL tab.
6) If a UTILITY tab is present next to MODEL, click UTILITY and check all boxes.
7) Click OK to commence uninstalling. Follow the prompts until the uninstall is complete.
8) Next look for a separate entry in ADD/REMOVE PROGRAMS that reads EPSON STATUS MONITOR. If you do not see this entry, don't worry; skip to step 12. Otherwise, go on to the next step.
9) Highlight EPSON STATUS MONITOR and click CHANGE/REMOVE.
10) When asked: DO YOU WANT TO CONTINUE UNINSTALLING, select YES.
11) After a short delay, when you get a message indicating that the uninstall process has completed, click OK.
12) Disconnect the USB cable from the back of the printer or computer.
13) Restart the computer.
For the next step-give me your email add so that i can send you the instructions- Thanks!!
May 28, 2008 | Epson Office Equipment & Supplies
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
181 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
