How to install an evaporator core in a 2005 chevy impala
  • ktomasian Sep 29, 2009
    Thank you for your help.
    Sergeant:
    Champion:
  • 208 Answers
I assume you need to know the complete from start to finish instruction. The steps are:
1. Reclaim the refrigerant with a reclamation system and cylinder.
2. Remove the old evaporator and dryer. You need to replace the dryer at the same time.
3. Install the new dryer and evaporator coil.
4. Test for leaks.
5. Vacuum the system with an HVAC vacuum pump for about two hours.
6. Charge the system with R134A using a HVAC manifold attached to both high and low side.
These tasks are not easy, and you will need expensive equipment. It is illegal to discharge R134A into the air in the US. You also need to know how to determine the amount of charge you need, either by weight or by pressure adjusted to the ambient temperature.
If you are an experience HVAC tech, I am sorry for pointing out the obvious. Otherwise, good luck.
Posted on Sep 29, 2009
Changing heater core
    2005 Chevy Impala 3.8Liter - YouTube
    ? 3:51
    https://www.youtube.com/watch?v=pq2DoQq6q0A
    Apr 18, 2014 - Uploaded by DerrickTheMechanic
    How to change them out.And what they ... 2005 Chevy Impala3.8Liter ... Heater core information, coolant leak, bypass,replacement, hoses, etc.
    How To Change A Heater Core - Part 2 of 2 - YouTube
    ? 3:12
    https://www.youtube.com/watch?v=OFxQJXWszs8
    Jun 19, 2013 - Uploaded by klowny1969
    How To Change A Heater Core - Part 2 of 2. klowny1969 ...Impala . Caprice . Nova . Biscayne . Corvette . Denali . Landcruiser . ... Chevrolet 1500 * 2500 Truck * Heater Core Replacement * Gasoline * 1997 - Duration: 11:59. images for 2005 Chevrolet Chevrolet Impala LS ...
Feb 03, 2016 | 2005 Chevrolet Chevrolet Impala LS
Is the radiator on a 2005 Chevy impala 5/8 or 1 inch core?
use a tape measure and measure the distant across the rad from cooling fin to cooling fin, outer edges.
Jul 20, 2015 | 2005 Chevrolet Impala
Why does the floor stay wet on the passenger side in my 2005 chevy impala
Put a white cloth on it. If its green or orange (the same color as your antifreeze) its your heater core going out.
Oct 28, 2013 | 2005 Chevrolet Impala
I have a 2001 Chevy Impala and last year it was blowing cold air from a.c. then all of a sudden it quit and started blowing hot air.we put freon in it but apparently it all leaked out.what is wrong with...
Most likely a leaking evaporator(this is a wide spread problem due to a crappy manufacturing process).The evaporator core is a "sandwich" of aluminum sections,with a million possible leak points.I replaced the evaporator on my 98 voyager(same design) with a new one from a company called Evercool(it had a different design that had fewer seams).It outlasted the original part 10 times over.
Apr 04, 2012 | 2001 Chevrolet Impala
My 2005 Chevy Impala smells gasy when ever started and sometimes after idling for awhile.
SMELL GAS YOU NEED CHECK ALL FUEL LINES UNDER THE HOOD IN THE ENGINE COMPARTMENT.IF GAS IS STRONG UNDER HOOD YOU DONT SEE LEAKING FUEL LINES.YOUR FUEL RAIL FUEL INJECTORS LEAKING OR FUEL PRESSURE REGULATOR O - RING OR DIAPHRAM LEAKING GAS.IF FIND NO LEAKS UNDER THE HOOD CHECK FUEL LINES UNDER CAR FROM ENGINE TO FUEL TANK FOR LEAKS.IF ALL IS GOOD YOUR EVAPORATIVE CANISTER SOAKED WITH GAS OR YOUR EMISSION EVAPORATIVE SYSTEM NOT WORKING. DEALERSHIP HAS TO CHECK AND FIX.
Jul 03, 2010 | 2005 Chevrolet Impala
Heater core instructions for 04 Chevy Impala SS
Before you go thru that expense. If it is water leaking,check the evaporator. Sometimes it gets plugged with debris. So first, decide if it is water or anti-freeze. Also, I have taken the heater hoses off of the inside of the motor area and flushed the core out. It works on some.
Jun 01, 2009 | 2004 Chevrolet Impala
The a/c or heater is not blowin out nothing,ihave a 2005 chevy impala
Check your fuses in a chevy they are either in the glove box or on the inside of door by the dash on the pass or drivers side.
Jan 18, 2009 | 2005 Chevrolet Impala
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
