Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Canon digital ixus 75 has battery and memory card in it. when I turn it on it says "no memory card" infact any memory card I put in it the same thing is said. please help! thank you regards Laura
My canon digital camera ixus 75 card is locked how to procedure to unlock
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 18, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
My canon ixus 75 reads card locked
Take a look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Nov 25, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
The camera will not turn on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jul 30, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
The camera is not turnning on
Jun 25, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My canon ixus 75 displays a black screen when in the shoot mode,this happened suddenly while taking a number of pictures,although I can still veiw pictures on the memory card.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Apr 25, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My camera was working fine and now will not come on
Things to check first are battery contact points, and micro switches that are located on the battery and memory card doors. Details on what needs to be checked may be seen here. It won't work for every case, but it's worth a try.
Apr 10, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
I want to put my photos from my canon IXUS 75 onto the pc
Are you using a memory card or internal memory? If you are using a memory card, get a memory card reader and download the images onto your comp.
Feb 05, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canan digital IXUS 8601S Camera showing Memory Card Error Card Locked
canon camera xius 80 showing - memory card locked .... please help... it beeps at the atempt of clicking photos
Aug 05, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon ixus 75 digital camera reset?
The manual states that the battery door was opened during use. Close the battery door and turn it on and off. You may need to push it closed to make sure the battery connections are made.
Mar 21, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
74 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
