Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
I DO NOT HAVE A DIAL TONE FOR MY FAX I CHANGED ALL THE INK
PLEASE HELP WHAT IS THE PROBLEM
    Problem Solver:
  • 4 Answers
For some reason all your question is not shown here or what it is you have already done. Have you replaced your driver? Did it just quit working? Have you upgraded your operating system before it quit working? If so or do this anyway. Uninstall your driver and ,Reinstall your software for your Multi-Function Center.
Posted on Dec 19, 2007
Hi my canon fax-JX500 displays 'line in use' and has no dial tone. Can you please tell me how to fix the problem?
Unplug your fax from the phone line. Plug in a phone. Dial tone? Yes? then either fax is bad or the phone wire is bad.
No dial tone? Phone line dead.
Aug 30, 2015 | Canon Office Equipment & Supplies
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
Fax is not going through. says there is an error. If making copy, it is very dark on right and left sides of the paper. Any sugggestions?
What you are probably experiencing is the fax machine is not getting a dial tone from your line, thus giving you a error.
Many times things get moved, paper runs out, ink runs low or the line gets unplugged. We suggest you check the line making sure it has a dial tone, checking your ink would be another great step.
Many times these machines get dirty with would cause the black ink run on the sides of the paper. You could clean that out with a can of compressed air. You would do this by opening the machine as you where to change the ink in it. You would give it a couple blast of air at the exit paper trail.
The other thing is this is thermal meaning the ink is super heated onto the paper, if there is any residue of ink this would cause this issue.
Now the error message you did not give us, I would be interested it knowing the error code before I can make further comment on how to proceed with the sending issue. Many reasons are:
1. No dial tone
2. Paper jammed inside the machine
3. OCR scanner errors
Please let us know what the error code is so we can give you a great solution on what to do from there. We do Thank You for using Fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 01, 2011 | Sharp UX 108 Roll paper Thermal Fax
No dial tone
Plug a working phone into the jack that the fax uses using the same phone cord, and if it works the modem in the fax is bad. -Carl
Jun 10, 2010 | Brother IntelliFax-2820 Laser Fax
No dial tone
Problem solved - new cable bought which seems to have sorted the problem.
Sep 26, 2008 | Brother FAX 930 All-In-One Thermal Printer
Panasonic KX-FM220 fax machine does not have a dial tone
is your line provider ok.connect your line to ordinary phone to check if there is really a dial tone from the line provider.if there is a dial tone please let the analog board be cheked by a technician near you
May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
No dial tone
-Try to connect line to a phone and check for a dial tone
-make sure that line is connected to line port at the back of printer
-try to use a spare cable if you have an extra available
Apr 05, 2008 | Lexmark X2350 All-In-One InkJet Printer
Intellifax 4100
First the link to the manual
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_4100e_EN_250.PDF
The date and time are set up under general set up. Under that menu there is also TONE/PULSE dial mode setting if you have accidently changed this to pulse it will cause issue. Change it to tone if you have and this will resolve the problem. Pulse is the old style phone system.
Mar 05, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
