Question about Nextel i860
Phone wont turn on, even if i plug it to a charger.phone just does nothing it wont work
    Brigadier General:
  • 7,752 Answers
Sounds like the phone is dead just take the phone to a professional mobile shop and have them fix it for you.
Posted on Jan 12, 2008
5 Suggested Answers
SOURCE: phone wont turn on
Battery is so low it won't turn on. Leave on charger for a half hour or so and it will turn on again. Replacing the battery worked for me!
Posted on Jul 18, 2008
JAN_yuanjia
  • 470 Answers
SOURCE: LG Model NTLG300GB wont turn on
check the power IC or the CPU, then replace it
Posted on Mar 31, 2009
  • 2973 Answers
SOURCE: My phone went dead, It wont even turn on. Even
It could be the power on switch that may be bad. You cant throw away a phone like this. So, show it to the LG Service Center and let them decide as we cant replace the switch (if need be) without special tools that most of us do not have.
Posted on Aug 21, 2010
  • 11 Answers
SOURCE: My phone died overnight, n
ITS YOUR BATTERY PHONE.NOT HOW UR CHARGING IIT.LOOKIT PUT YOUR BATTERY IN A PLASTIC BAG AND PUT IT IN THE FREEZER FOR ABOUT IDK 10 MIN
Posted on Dec 28, 2010
Iphone will not turn on! Shows Apple logo then fades out?
Leave the phone plugged into the car charger with the "plug into itunes" screen long enough to build a charge. It sounds like the phone is dying before it gets a chance to connect to itunes and start charging through the computer. If this does not work then the store clerk was correct and your battery will need replacing
Feb 09, 2013 | Apple iPhone Smartphone
When i plug my blackberry pearl in its charger nothing happens. It wont turn on or nothing.
try a secondary battery as well as a second charger (I believe the pearl uses micro USB, which is also used by bluetooth headsets, other phones, and pcs- you could even plug it into a pc with the cable to see if it charges)
If neither works, the phone is unfortunately dead. However if the battery works, bad battery. If the different charger works, bad charger
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Mar 31, 2011 | RIM BlackBerry Pearl 8100
My phone wont turn on or charge!! when i plug in the charger only the LG logo comes on and nothing else happens! Even after taking out my memory card i plug in the charger but nothing happens.
hi,
have you tried removing the battery?
most probably, your phone software crashes or corrupted. we can do nothing about it unless we have a special gadget used to fix mobile phones and buying it cost so much for that purpose only.
To save time and money, I recommend to have it reformat at your nearest service center or dealer if it still has the warranty or to trusted mobile phone repair shop.
Hope I helped you in some other ways.
Don't forget to rate me. Thanks...
Best regards,
John
Jan 14, 2011 | LG KC910 Renoir Cell Phone
I was using my blackberry when it froze so I took the battery out to restart it but then when i put the battery back in it wont do anything. I dont even get the light ... any help? really not wanting to...
First thing to do is check to make sure nothing is between the battery and the phone, like dust for example. After that, plug the phone into the charger and see if it will turn on. If it turns on, it is the battery. If it does not turn on, and the charger is working properly, it is the phone. Good luck.
Mar 27, 2010 | RIM BlackBerry Pearl 8100
Wont charge
Try a car charger. If the car charger works, then it is either
A) Your power outlet
B) Your wall charger Power Supply unit
C) The phone connector on your wall charger.
If it doesn't work on the car charger, then it is most likely your phone charging system or the connection for charging on your phone. Either way, you will most likely need a new phone. Sorry.
Sep 23, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Sony Ericsson K770i Phone won't turn on red light apears on the top left, any suggestions?
This has happened to me twice - the first instance occurred when I'd only had the phone a few days and the second occurred today after months of trouble-free use.
On both occasions the phone wouldn't charge via the mains charger - it wouldn't switch on even when plugged in and neither the battery or the charger were warm to the touch after hours of charging, indicating that nothing was happening.
The solution for me was to connect the phone to my PC via the USB cable - nothing happened at first, the PC didn't recognise the phone and it remained lifeless. However, I left it attached to my PC and after 10-15 minutes it suddenly whirred into life.
The battery was COMPLETELY flat despite my attempts at mains charging, so I let it charge via USB for a while then transferred it to the mains charger. This time the mains charger worked.
I've no idea why, but this has worked for me twice so give it a try.
Jun 07, 2008 | Cell Phones
Wont charge or is locked
if you plug the charger in and you can see the battery bars going up and down then it is phone problem if the scrren is blank then it is either the charger but if you have a car charger aswell and both chargers worked before then it is probably the phone that has a problem check where the charger plugs in that their is nothing blocking the terminals like fluff or bit of paper check that none of the terminals are bent or coroded if you have used phone in rain they might have got coroded this can be solved by cleaning the terminals on the charging part of the phone but be carefull when you do this not to wreck any thing check the charger make sure nothing bent or blocking the charge the problem with these phone is the pins on the bottom where the charger plugs in these get damaged really easily and they can be replaced but will have to take to phone shop and get repaired hope this is some help to you....................................
Nov 12, 2007 | Motorola Mobility L6 Cellular Phone
My MDA won't turn on even when its on the charger.
THE SCREEN AND LIGHTS HAVE BLOWN YOU NEED NEW PHONE
Apr 11, 2007 | T-Mobile MDA
Cell Phones Logo
48 people viewed this question
Top Nextel Cell Phones Experts
Rommel Balcita
ray gallant
repairphone
repairphone
Are you a Nextel Cell Phone Expert? Answer questions, earn points and help others
