My display screen is in center help me to adjust it
  • Venance Mattei May 11, 2010
    I depends on the type of monitor you are using. Try to check the Screen resolution setup on your pc, or by increasing the size of screen appearance by using the setup buttons located on your monitor. If it doesn't help, send me the monitor details.
  • 107 Answers
Hello, try to go on desktop properties, settings, advance there are some choices tab, try one..
Posted on Sep 29, 2009
TOUCH SCREEN
Initial Mode Function Setting Procedure
1. Remove the Compact Flash Cover [1].
2. Press the Warm Restart switch [2].
3. When "." appears at the center on the left-hand side of the screen, enter "3" from the
10-Key Pad.
4. Enter the 8-digit service code and touch [END]. (Default value: 00000000)
Initial Mode: Total Clear
Touch Panel Adjustment
Marketing Area
Image Data Clear
Clear FAX Setting
Date/Time Setting
Trouble Reset
• To adjust the position of the Touch Panel display
• Make this adjustment if the Touch Panel is slow to respond to a pressing action.
• When the control panel is replaced.
1. Touch [Touch Panel Adjustment] from the Initial mode screen.
2. Following the arrow mark, touch the four points (+) sequentially on the screen using a
pen.
NOTE
• Be sure to touch the very center of each point.
• Use care not to damage the screen surface with the tip of the pen.
Feb 12, 2014 | Konica Minolta Office Equipment & Supplies
The touch screen on my minolta 350 can't be displayed whenever i press exactly on the written box but below the written box it can normal be displayed, i figure out it must need some adjusts to put it...
10-Key Pad.
Functions • To adjust the position of the Touch Panel display
Use
Adjustment
Procedure
pen.
NOTE
How to center my display in acer travelmate 5720
If your display is not centered try adjusting your screen resolution. Click Start/Control Panel and look for Display or Appearance and Personalization. Open them to open the display properties and click the settings tab for screen resolution. Set your resolution up higher. The higher the resolution, the smaller the icons, thus the more fits on the screen. Normal resolution is about 1024x768.
May 29, 2012 | Acer TravelMate 5730-6204 Notebook
How to scan more than 1 page at a time
ADF : Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first. Adjust the width guides to fit the item. Open HP Solution Center with one of the following methods:
  1. Click Start , click All Programs , click the HP folder, and then click HP Solution Center
  • Double-click the HP Solution Center icon on your desktop. A "Scanning from..." screen displays to prompt for scan settings. If this settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
    1. Cancel the scan, return to the home screen of HP Solution Center, and then click the Settings option.
    2. Click Scan Settings , and then click the appropriate option from the popup menu: Scan Picture Settings or Scan Document Settings .
    3. Select the check box, Prompt for settings at the time of scan , and then click OK .
    4. Click Home , and then start the scan again.On the "Scanning from..." screen, click the appropriate option under "Scan Shortcuts" on the left. Each shortcut has a default group of settings that display when you click it.
  • Click Change Settings , and then read through the drop-down menu choices for all of the settings for the shortcut, adjusting any settings as necessary. Also click the Advanced Picture Settings button and the Save to file Save Options button to view your choices and make any changes. Important : HP Solution Center versions and options vary, depending on your printer. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
  • Click Scan . The preview screen might display, if you selected the option to show a preview. Use the options on the preview screen to make any desired adjustments before you finish the scan.
  • After the scan completes, it goes to the destination that you specified in the settings.
  • Scan Button: HP recommends that you first get comfortable with using the "Scan Picture" and "Scan Document" on-screen "buttons" in HP Solution Center as explained in the previous steps. By doing this, you determine the scan settings that you use most often, and then you can more easily set up the scan button on your printer. Important: Before you use the scan button on your printer, use HP Solution Center to create the settings for that button . For example, you need to decide whether you want a settings prompt screen and a scan preview for each scan. Also, you must create the list of "shortcuts" that you want to display on the front panel of the printer. To get started, click Settings , click Scan Settings , click Button Settings , and then click the tab for Front Panel Scan Buttons . Read through the options, and then create the settings that you want. NOTE: The steps to set up the scan button on your printer can vary depending on your printer model, and the version of software that is installed. For specific instructions, click the Help button on the home screen or settings screens in HP Solution Center.
    Dec 04, 2010 | HP Officejet 6310 All-In-One InkJet...
    The screen has shifted to the right so that i cant see the [X]on any windows. Ive already maxed out the left shift but its still stuck to the right.
    does the screen appear distorted;does it move as you shift left/right/up/down? IF THIS IS TRUE, YOU PROBABLYHAVE THE RESOLUTION SET WRONG....RIGHT CLICK ANYWHERE ON THE SCREEN;PROPERTIES;SETTINGS; ADJUST SLIDEBAR TO PROPER RESOLUTION FOR YOUR MONITOR
    Mar 07, 2010 | AOC 2216Vw 21 inch LCD Monitor
    My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
    Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
    1. Press action button to enter MENU.
    2. Navigate to SETUP.
    3. Scroll down to CONVERGE.
    4. Press VOL > to select.
    5. Press CH buttons to navigate up or down.
    6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
    7. Press VOL > to select.
    8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
    9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
      center of cabinet.
    10. Press ACTION button to display red center correction screen.
    11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
    12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
    NINE POINT CONVERGENCE CORRECTION
    Remote Control must be in TV mode.
    1. Press ACTION button to display red correction screen.
    2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
    3. Use the navigation buttons to align the RED cross with the white cross pattern.
    4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
    5. To exit press ACTION button repeatedly, then press CH up.
    Nov 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
    Screen is distorted
    hi there, Below the monitor, on the center are option button, you can explore that in adjusting your screen display. You can widen the display, or tweak it depending on the angle that you need to. Just press the center button and choose from the menu.
    Oct 25, 2008 | Dell E771p 17" CRT Monitor
    52 in rca projection 2006 cutting of the top of heads of people
    There are manual settings on most projection tv's to adjust the size and to bring the picture down so it is centered on the screen better. Try adjusting the three colors mentioned below first. All projection tv's are pretty similar. If you need to adjust the picture manually, which you should not have to, there are manual knobs behind the front of the tv or at the rear. They should be marked for thier function.
    Here is how to adjust the convergence one color at a time.You should be able to get to the convergence screen with your remote. You need to go into the setup screen and read what is on the menu there. It should say how to adjust when you get there.
    Convergence- The Auto convergence feature automatically adjusts the TV’s tubes
    (this may take several minutes, after which you can make fine adjustments to the
    convergence settings); Red convergence displays the Red convergence screen,
    allowing you to use the arrow buttons to align the red and green images; Blue
    convergence displays the Blue convergence screen, allowing you to use the arrow
    buttons to align the blue and green images.
    Also this is in the manual for a generic projection tv.
    Call 1-877-RCA-HDTV and have your unit’s date of purchase and model/serial number ready.
    • A representative will troubleshoot your problem over the phone.
    • If the representative determines that you should receive service, they will provide you with the name(s) of the
    Authorized Service Center in your area.
    • Contact the Service Center and arrange for home or pick up, repair, and return service, provided that your unit is
    located within the geographic territory covered by an Authorized Service Center. If not, you must take your unit to the
    Service Center location at your own expense, or pay for the cost the Service Center may charge to transport your unit to
    and from your home.
    • Proof of purchase in the form of a bill of sale or receipted invoice which is evidence that the product is within the
    warranty period must be presented to obtain warranty service. For rental fi rms, proof of fi rst rental is also required
    Here is a link to rca tv manuals if you don't have one.
    You can download them in pdf.
    If this is not a help, please give the specific model number.
    Apr 21, 2008 | Televison & Video
    Samsung computer monitor display problem ....display is displaced to left and not centered. what adjustment buttons allows to fix. trying to help someone else. is it part of the menu button or something...
    Hello!
    Infront or in the side of your monitor there is menu option. either you select the right adjustment by selecting the left or right menu then continue pressing the until it go back to the center. refer to monitor manual for the adjustment menu of the screen.
    melnavz
    Mar 19, 2008 | Computers & Internet
    Menu icon does not work properly
    Try this it may help. First, reset by pressing both VOLDW & SRC keys at the same time and boot up the system in Test Mode. Display the Touch Adjustment Screen with the SRC key of Car TV remote controller, press center section of the "Cross-font" using adjustment stick. (Upperleft - upper right - lower left) Note: When conducting the adjustment for the first time, the display position of the cross-cursor may be little off, but the adjustment should be conducted by using the center position of the font.
    Sep 05, 2007 | Kenwood KVT-M700 Car DVD Player
    Computers & Internet Logo
    32 people viewed this question
    David Payne
    David Payne
