Question about Sharp AL 1631 Copier
Error L1 The copier is not responding to any typical repairs that I have tried. L then 1 keeps flashing. Can you help?
  • Gisman2008 May 11, 2010
    I have an AL-1551CS that is flashing the L1 in display as well. I have tried the fault reset 14 as you have described. I am still getting the flashing L1 when I power down. I have removed the glass and the lamp cartridge is freely moving. The lamp cartridge will move as the dial is in the unlocked possiton like it is trying to reset then the system will power down with L1 flashing again. The cartridge will move forward then move back to "home" then flash L1, you mention that the main PWB sensed that the carriage did not leave home. What is the PWB and where should I go from here?
    Thanks for your assistance
    Gisman2008
    Novelist:
  • 208 Answers
There are a couple of things to try . First try this to see if this resets the problem..
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
If this reset does not correct it, see if your your lamp carriage, under the glass is moving freely. You may have to remove the glass WITH THE POWER OFF, and see if it moves freely.
Listen and feel carefuly for the lamp making some contact with a sensor or bracket.
Other then that the other cause is the scan motor being plugged in backwards, I seriously doubt you have done that one.
Hope this helps, If not tell me and I will look into it a further, but either a reset 14 or the lamp catching on the home sensor bracket should resolve this.
Posted on Dec 20, 2007
  • Rick Kasper Dec 20, 2007
    L1:Indicates that the Main PWB sensed that the carriage did not leave home after power up or after start is pressed
SHARP COPY MACHINE AL 1631 FLASHES A L1 ERROR
Most likely when removing a copy someone hit the scan lock on the front of the machine.
Look on the front , bottom side of the scanner where the paper comes out. You will see a latch that is used for shipping the machine that is more than likely locked.
Thats what causes an L1 90 percent of the time. Just slide it to the unlocked position or take a small screw driver and remove it and throw it away. You can put a piece of tape over the opening to keep dust and moisture out
Jul 15, 2010 | Sharp AL 1631 Copier
I have a sharp al-1642cs that will not work it just keep flashing L1 can you help
www.cyberscholar.com/sharp/resources/cop_man_soho_AL1642CS.pdf
http://www.service-docs.com/store/catalogue.php?cat=281&exp=0&resultpage=10 L1 00 Feeding is not completed L1 00 Feeding is not completed
within the specified time
after starting feeding.
(The scan head locking
switch is locked)
1.unlock Scanner unit
2. chang connecter
Scanner unit
May 09, 2010 | Sharp AL-1642CS Copier
Error code "L" & "1"
L1 indicates a scanner feed problem. Make sure the scanner isn't locked in the shipping position. It is underneath the scanner where the paper exits the machine. Look for a plastic dial and turn it one way or the other.
Jul 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
L1 is flashing on my copier
Hello, Please check out the following website and see if you can find your error code:  http://www.copier-help.com/copier-help/
Hope this helps. Good luck
Dec 11, 2008 | Sharp AL-1217 Copier
Flashing "L1" error
A letter "L"  and a number "1"  appear alternately = The scan head locking switch is locked. Unlock the scan head locking switch.
Hope this helps. Good luck.
Jul 29, 2008 | Sharp AL-1217 Copier
Getting an error L flashing then 1
Background:
The L1 is indicating a scanner lock.
Easy way to fix it:
1. Turn machine off.
2. Turn scan locking switch to unlock. This is a clear plastic knob. (it is located on the left hand side of the machine under the document glass in the copy exit area - check your manual for a picture of it around page 9 or so).
3. Turn machine back on.
4. Try a copy.
5. If you still get an L1 then it might need service because the scanning bar is jammed. They will ask you to try some service codes first to verify that it is indeed jammed. Call 1800 237-4277 for further support.
Followup:
This also is a fix if you are getting blank copies.
Mar 18, 2008 | Sharp AL-1641CS Laser Digital Copier
Flashing L1 Display
clean the stripe band unther the glass
Dec 26, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
339 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
