Question about Inovix Audio Players & Recorders
Hello, My IItronics MP3 model iMP-11 is stuck.
Hello, My IItronics MP3 model iMP-11 is stuck. The mode menu is showing, but it will not respond to any function on the rocker. The backlight is flashing all colours and the only way to switch it off is to take out the battery. Has it reached the end of it's useful life ? or is there a simple answer. Thanks.
  • 360 Answers
There pretty hard to fix!
Posted on Sep 29, 2009
  • Richard Klein
    Richard Klein Sep 29, 2009
    Have you tried re-installing the firmware or whatever operating system it has on it.? I was just saying because, you made it seem like it had a rough life it was probably physical damage and just hard to fix.
  • Richard Klein
    Richard Klein Oct 02, 2009
    You can get additional information from lltronics and youtube on how to fix you device.Here's a good site that has problems like yours. www.howtomendit.com/answers.php
    Re-installtion from the installation cd might be required in order for your IMP-11 to function properly. I hope this helps!
Computer doesnt show video,slide show, says it downloading but isnt on unit when restarted
Just to be clear,most players require no special drivers. MSC mode will work out of the box with just about any MP3 player and any OS (W*ndows Linux). MTP mode will work as long as you have WMP 10 or 11 installed. Firstly, I will try to explain MSC mode and MTP mode and what they mean. MSC stands for Mass Storage Class. When your player is in this mode, the computer will see it the same way it would see a Thumb drive or flash drive, as a removable disk. It will assign the first available drive letter to your device, as well as one for the memory card (if it uses one and it is installed). This is probably the more popular of the 2 modes, and is a more "open source" type of standard. Most computers detect the player in this mode without a problem very well and right away.
MTP stands for Media Transfer Protocol. It is a Microsoft standard and is Microsoft's solution to connecting MP3 players and cameras to a w*ndow based Computer. MTP mode must be used in order to transfer ANY Digital Rights Management (DRM) protected content. MP3's downloaded form services like Rhapsody and Napster will only function in this MTP mode.
Most good MP3 players will have both of these modes at the users options.
Although not all do, so it is a good idea to check yours for these settings if you are having connection problems
NOTE: Any songs added to your player in MSC mode will not be available in MTP mode and vise-a-versa. In other words You can't see the files added in the other mode and you can not play them. You know you have some files on your player and can not find them now, you may have to change modes so they are available. Some players in the SanDisk line up use Instead, an "Auto Detect" function that is suppose to Automaticly use MTP mode. If MTP mode does not work for any reason, it should default to MSC mode.
To use MSC or MTP modes go to your players settings.
These settings will vary based on player model and you might have to refer to your users Manual. Check their web site for a download in PDF form. Turn the player on, if it is not already Navigate to the main menu of your player; this is the same menu that gives us options such as Play, Record, Info, etc... Navigate to "Settings" on the main menu of the player. After navigating to "Settings", you should see an option that states "USB" or "USB MODE" From here we can select MSC or MTP modes (could vary based on player model) Highlight the desired mode and select it, at this point it will roll back to the 'Settings' menu Connect the player to your computer and verify it is connecting in the desired mode. It should be noted, when a device is in MSC mode, it will appear as a "Removable disk". When connected in MTP mode, it will show up as an "Audio Device".
Now most players now days can and will use`MS W*ndows Media Player. You can also try to reinstall W*ndows Media Player 10 or 11 Next W*ndows has a update to fix if all else fails try this link. http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en
Feb 13, 2010 | SanDisk Sansa e250 MP3 Player
Fm-Radio problem
that model does not support radio.
Jun 21, 2009 | Audio Players & Recorders
Lost firmware of IMP-65 MP3 player
her is a link for the firmware download
IMP-65 Firmware
If this helps please rate the post.
Mar 02, 2009 | Audio Players & Recorders
My mp3 is not connecting to the computer
It may be because that you have not installed the driver for your MP3 player, if you have then it may be that your MP3 player is in the wrong mode to connect to the computer. This can be changed in the settings or system menu on your player. If nonw of these work it is also possible that you have a bad cable but that is un-likely.
Hope everything works,
Fixer Guy
Feb 04, 2009 | i-Bulldog IMP-90 MP3 Player
My i-pod nano chromatic 8 GB is stuck!:S
Press and hold the Menu and Centre buttons at the same time until the apple logo appears. (This usually takes between 5 and 10 seconds.)
Information from: http://ipodsurgery.com/reset-frozen-ipod
Feb 01, 2009 | Apple iPod nano MP3 Player
Driver for IItronics mp3
same here mime wont show on the computer and when i turn it on the 'itronics' screen stays on there for a long time
Jun 15, 2008 | Audio Players & Recorders
Micin.DIR Folder have been Deleted on my Mp3 Player
HI i am glad to tell u that I was facing the same problem but I tried all tricks and formula finally come up with a solution and now my MP3 is working ok
1st u download setup from ur IItronics CD and
then goto my computers right click ur mp3 player
go to properties
select tool menu
select backup option
select restore option
MICIN.dir file will be added to ur mp3 player
I hope u will be succsesful
Mar 13, 2008 | Audio Players & Recorders
Lost installation software
Hello Bigmoney, You can download the CD here: http://www.mpioamerica.com/support/software/IMP-90%20Installation%20CD.zip You could also buy the CD for $2.99 here: http://www.mpioamerica.com/mpio/productInfo.html?productId=221 You will need to unzip it before you install it. Please let us know if you need any additional information or help. Best regards, nightdiver
Sep 06, 2006 | i-Bulldog IMP-90 MP3 Player
Re mp3 wma mp3 imp 11
try deleting the files and reloading and if that dosent work make sure your putting in the proper types of files BUT im sure you are so try this first. also after deleting try also taking out the batterys overnight . Good Luck
May 04, 2006 | Rio S10 MP3 Player
338 people viewed this question
Top Inovix Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Inovix Audio Player and Recorder Expert? Answer questions, earn points and help others
