Question about Maytag MAH21PDD Commercial Front-Load Washer
Maytag MAH21 - main motor won't run
I have a coin-operated Maytag commercial front loader in which the main motor won't run, but no diagnostic codes come up. I've gone into diagnostic mode and run several of the diagnostic cycles. The hot & cold solenoids work OK, the pump runs when required and the cycles run to completion, but the main drum motor never starts - and no error codes are produced. I would have expected at least the "main motor speed error" code.
While the cycles were running I had the rear cover off. The main drive belt is in place and OK, the drum, belt and motor can be rotated by hand and move smoothly. Couldn't find any sign of a motor thermal overload that may have needed manuall resetting. Any one got any ideas? Any help much appreciated. Ian from Australia.
  • Leo109 Dec 26, 2007
    Hi Guys,
    Anyone want to have a go at this one? Surely one of you American gurus can help out a simple Aussie on this? Or are you all still too upset because we flogged ya and took away the America's Cup back in '83?...
Did you try to ohm the motor,
term. 1,2,3 6-7.5 ohm term.4,5 155-195
if not, harness or motor
check for 120v at the power leads to motor control board
if not, door switch? other
external power cord to power connector
should spin drum @ 50 rpm
if not,probable control board
Posted on Feb 24, 2010
Its whats called the 'WAX door lock motor' it's a small, brown device that drives across the door lock pin "very slowly" at the start of the wash thus making contact with the door locked microswitch. replace the motor!
Posted on Nov 04, 2008
Please check microswitch block door/ Best result change this microswitch on the new. If terminal is shot - longered on wire.
Rashid Moscow (arashid@yandex.ru)
Posted on Jan 25, 2008
Maytag Coin Washer can't select Cycle after putting in coins
check the coin mech
If it is turning on properly
check the selector itself.possibly the switch
Mar 18, 2015 | Maytag MAH21PDD Commercial Front-Load...
Its a commercialcoin operated machine that won't start washing what could be the problem please?
open the coin dispenser and push in the start button that the coin lever should push in when you put the correct coins in the dispenser
Feb 04, 2013 | Maytag Washing Machines
Maytag laundry neptune front loader washer MAH6700AWW. It is showing a E3 code error. what can we do for that
Hi, the E3 error means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 16, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Change the number of coins to operate
you need to take the coin slot apart take pictures as you go to put back together the parts to change amount are hidden inside it in hidden compartment if they wheren't removed by some one. your machine didn't come with the coin mech so if you don't have the parts you will need to take it with you to the parts house to get right parts. open the top of the coin mech box there are 2 long rod screws holding it in place usually 5/16 inch wrench fits may need to wiggle the heck out of it to get it out
Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
Commercial dryer coin op programming
Below is Maytag's commercial laundry website where you should be able to acquire the information requested.
http://www.maytagcommerciallaundry.com/content.jsp?pageName=CustServ
Jun 16, 2009 | Maytag MDE16PD Electric Dryer
Maytag coin-op top load wont spin, motor runs, belt burns.
it not a belt, there is a $20 plastic and rubber coupling between the motor and the transmission that has broken.  It needs replacing.
Dec 25, 2008 | Maytag MAT12CS Top Load Washer
I NEED FAULT CODES FOR DRYERS
PF Power Failure
“PF”
flashes to indicate that a power failure occurred while the dryer was
running. Press START to continue the cycle, or press PAUSE/CANCEL to
clear the display.
F-01 Primary Control Failure “F-01” flashes when there is a primary control failure. Replace the machine
control electronics. See Accessing & Removing the Electronic Assemblies.
F-02 Keypad/User Interface
Failure
“F-02”
flashes when there is a stuck button or user interface mismatch. This
fault code will ONLY appear when in the diagnostic test mode. See TEST #5.
F-22 Exhaust Thermistor Open “F-22” flashes if the thermistor is open. See TEST #3a.
F-23 Exhaust Thermistor Shorted “F-23” flashes if the thermistor has shorted. See TEST #3a.
F-26 Motor Drive System Failure “F-26” flashes if there is a motor drive system failure. See TEST #2.
F-28 Moisture Sensor Open “F-28” flashes if the moisture sensor strip is open. This fault code will ONLY
appear when in the diagnostic test mode. See TEST #4.
F-29 Moisture Sensor Shorted “F-29” flashes if the moisture sensor strip has shorted. This fault code will
ONLY appear when in the diagnostic test mode. See TEST #4.
1M 2M 3M 5M 6M
= Contacts closed
Contacts
Function
Start
Run Red
Lt. Blue
Blue-White (Elec)
White (Gas)
Green-Yellow
Red
Black-White
BLACK
BLUE
WHITE BLUE
WHITE
WHITE
Pluggable Drive Motor Switch Gas Valve - Gas Dryer
Centrifugal Switch (Motor)
Gas Valve this is about close as i can come its matag electronic but not comercial should be about the same software though some where on or in the dryer should be a tech sheet with codes
May 21, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MAH21PDD Commercial Front-Load Washer Logo
337 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
