Question about Bose Lifestyle SA-2 2-Channel Amplifier
The dvd tray is stuck. I put a dvd in it earlier today, and now the tray will not open. when i press 'open/close', I see 'opening...'. If I press the open/close button again, I see 'closing...'. But I hear nothing and nothing happens. I unplugged the system and turned it off for 20+ minutes. Then turned back on, but still the same thing is happening. Please help.
  • 2 more comments
  • ritustuff Sep 29, 2009
    I would like specific advise for the Bose AV48 Media Center. This is my friend's machine, and I am house-sitting. I want to be 100% sure the expert is familiar with the Bose AV48 Media Center.
    There is no hole in the front of this Bose Media Unit. So I cannot stick a pin inside the hole to open the tray.
    This media system is more complicated than a simple dvd unit.
    Hi Eske,
    This sounds good. It's so late here now and I'm going to sleep. I'll try this during the day tomorrow and get back to you.
    Thanks so much!
  • ritustuff Sep 30, 2009
    Hi Eske,
    I just made a sad attempt to open the case as you suggested, and I chickened out. This is my friend's system, as I am house-sitting. I am afraid to break something.
    Thanks for your help, anyway. If I need assistance in the future, I will certainly seek you out.
  • 13,433 Answers
If you are outside of warranty, you can open up the whole player, and take the cd out, plug in the power and try ejecting the drive while you have the cover open, don't touch the internals aside from the tray while you have it plugged in.
Try ejecting / opening the drive, try to help it with your fingers, the drive may simple have become stuck.
If the drive opens and it stays open, doesn't close when you press close, the rubber cord that moves the tray in and out with the help of the small motor may have become off its place or the motor may have stopped working.
Posted on Sep 29, 2009
  • Ekse Sep 29, 2009
    No problem, sounds good.
  • Ekse Sep 30, 2009
    its not difficult to open the case, unscrew all screws you find, look for hidden screws under soft objects and labels, in the end the case may be hold in place with plastic clips, use a flat screwdriver to open up the case.
    President:
  • 1,185 Answers
Check to see if there is a small hole drilled in the front panel of the dvd unit
If there is then insert a straightened paper clip into that hole and push the door should open
  • 3,230 Answers
Please follow the below steps to remove the disk -
1. Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
2. Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It’s the part that holds the DVD loader in place.
3. Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don’t want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
4. Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn’t quite finished yet.
5. Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center.
6. Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you’re careful. You should be able to access and remove the disc.
Good Luck!!
Thanks
Eject button is stuck
Get in touch with the manufacturer's product support and ask them.
May 07, 2015 | Televison & Video
The tray on DVD won't open when pressing OPEN button DVD/CD is inside
Often the tray is powered by a rubber belt. If the latter breaks or slips the try will not open/close. The motor will work and tell the electronics that all is well because it has done its job but it really hasn't since the tray is inert!
Sep 10, 2017 | RCA DRC247N DVD Player
DVD disc stuck in vision plusTV/DVD combo
There should be a tiny hole somewhere on the front of the DVD tray, where you put the disk in. If it's not on the tray itself, it should be very close to it. Bend a paper clip out a bit, and carefully press it into that tiny little hole, and the tray should open up. If that doesn't work, then it's physically jammed, and mechanically unable to open.
Jan 31, 2013 | LG 32LG40 32 in. LCD HDTV
The dvd is stuck mid way not opening or closing
Try unpluging unit, then plug back in and press open/eject.Also look for a tiny hole on front door used to insert paperclip end, push in this will open tray.
Sep 04, 2009 | Yamaha DV-C6280 DVD Player
DVD Tray stuck open
the tray is not catching (underneath the tray is ridges). unplug the dvd player from the wall for 5-10 min...plug back up and give the tray a lite push while tapping the open/close button
Jun 17, 2009 | Yamaha DVD-C920 Multi-disc DVD Player
DVD Tray in computer not opening
there should be a small hole on the front of the tray that you can push a pin in from and it will eject the tray. if its stuck and you still need to hit it, would be best to use your warranty to get it fixed or take it apart yourself and make sure noting is blocking the tray from opening. you may have to take the tray apart and put it back together to get it to work normally.
Jun 01, 2009 | Samsung Super-WriteMaster SH-S183L Burner
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
Code for multi region free
I figured out the code, it's printed incorrectly many places.
1 - Turn on DVD Player
2 - Press Open/Close button - open tray
3 - Press "8888"
4 - Put a DVD in the tray (from outside your region)
5 - Press Open/Close button - close tray
6 - Voila! It plays!
Works on mine!
Apr 01, 2008 | GPX D1816 DVD Player
Liteon DVD Player LVW-5115GHC+ Disk Tray stuck
The tray is either broken, or off track. You may be able to get it back on track by opening the cover and checking it out, but unplug it first, and only try this if warrantee is over and you're feeling brave...
Jan 27, 2008 | Lite On LVW-5115GHC+ DVD Recorder
DVD trays are stuck
Since it is unusable try this. It might help to have so\meone assist if the unit is heavy.
Raise unit and lower the tray end about 45 degrees down, while lightly shaking press the tray open, they might just fall out.
Nov 30, 2007 | JVC TH-C40 System
Bose Lifestyle SA-2 2-Channel Amplifier Logo
271 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
