Question about Waring Blenders
Waring Pro 39BL56 stripped stud
The stud or screw and "bolt" side (whole in the "gear" that moves the part connected to the blade) are stripped. The screw part is connected to the motor.
  • 79 Answers
SOURCE: Waring Pro MBB Blender- blade too tight
If you can get the shaft out of its bearing, you can clean the shaft with steel wool. You may also have to scrape the inside of the bearing with a small rat-tail file.
Put some vegetable oil on the shaft and reassemble.
DO NOT USE WD-40 OR 3-IN-1 OIL! This mechanism will be in contact with food/beverages, so you want a lubricant that is safe for human consumption.
If the problem continues to occur, I would buy a replacement. In some models, this means buying a whole pitcher assembly.
Posted on Mar 15, 2008
KMusselmann
  • 247 Answers
SOURCE: Drive gear is slipping. Motor turns but the blade fails to turn
sounds like a shear pin either on the motor or the blade assembly. If you put the blender on low without the cannister on top touch the gear on top of the unit and see if the gear slips or stops. Use a pencil or something..Not your finger. If it stoops then the pin is broken at the motor. If not, it is broken at the blade unit.
Hope this helps
Kurt
Posted on Mar 17, 2009
  • 3600 Answers
SOURCE: The gear at the base of my waring bb 180s blender is stripped
You can try the sears online parts store for help they may be able to get the parts you need as they are pretty much the same. iF YOUdon't find it let me know and I will resurch it for you and find the part it is eather the druve nut has come loose or the teeth on the plastic shaft has worn off, it is possible to super glue it to hold if you cant find the part.
Posted on Nov 12, 2009
SOURCE: broken gasket can't find a replacement
Go to www.webstaurantstore.com They have all the parts. I have these blenders for my my nutrition club and this is the only place I have found parts at very reasonable prices.
Posted on Nov 08, 2010
  • 1739 Answers
SOURCE: the bolt that holds the blade to the bottom broke
Check here for replacement parts:
http://www.abtecparts.com/hamilton_beach_blender_58755.htm
Posted on Mar 03, 2011
Why can't coupler turn blade?
Drive shaft may be stripped
Dec 27, 2015 | Waring RB70 Blender
I have a waring pro blender Model WF2111211 It's glass he blade part doesnt come off. motor runs fine but blade really tight won't spin so the motor smells burn out trying to get it to free.
Heat up a cup of water in microwave until boiling in a two cup Pyrex measuring cup. Add one more cup of tap water. Our it in the blender and let it soak. If it doesn't work, repeat but with less tap water.
Sep 15, 2015 | Waring Blenders
Replacing drive side coupler on a Waring HPB300 blender. Threads don't match???
There are not normally any tricks, sometimes they are left hand thread though. More likely if the thread size is really too small then wrong part has been supplied.
Jul 10, 2015 | Waring Megamix Commercial Blender Hpb300
How to fix the blender,the motor works ok but the blades don't move
check to make sure the drive stud is spinning with the motor. If it is, make sure the blade assembly is lining up correctly as well as fitting tight on the drive stud. How to Repair Blender How to Repair Small Appliances Tips and Guidelines
Dec 09, 2014 | Oster Blenders
Remove stud drive from blender
You have to use a flat edge screw driver for locking the motor shaft.
first you put the screw driver to the slit on the motor shaft at at the bottom side at the same time you should use suitable wrench for unscrewing the stud
I hope this helps
Mar 30, 2013 | Waring 502696 Drive Stud
Nov 12, 2009 | Waring BB180 Work Top Blender
Waring Pro Blender is leaking and blade assembly is loose
I know this is an old, old post, but I could not find a solution anywhere, so hopefully this will help someone. We have a model 51BL25, similar to scottman55's blender, and it had the same problem. There are two separate nuts in the blade assembly. One holds the blade on, and the other holds the seal tight. When the latter gets loose, the blender shakes and leaks.
To fix it, first you have to remove the top nut holding the blade on. I had to get in there with pliers, but a ratchet with an extension would be perfect. This nut is right-handed ("normal"). Once that nut is loose, you can remove the nut and the blade. You will also want to remove the washer immediately under the blade (take note of which side goes up).
Now, you can pull the whole axle out by the wheel on bottom of the blender. This exposes a really thin, flat nut. In my case, this nut had come completely off, so nothing was really holding the seal together at all. Again, make sure you remember which direction the nut goes -- it is not quite symmetrical. That nut is what comes loose when the blender starts leaking. By the way, it is a left-handed nut, so it screws on counter-clockwise ("backwards"). Screw it in tight, then put the rest of the blade assembly back together, and your done. If you have the right tools, it should take only maybe 5 minutes.
Depending on your problem/model, this may or may not solve your problem. Hope it helps!
Jan 28, 2009 | Blenders
Waring blender - new blade
I just figured it out. The key is you need to think in terms of keeping the blades and the large washers separate. Here's what you do.
Thread the blade through the glass and use the white rubber gaskets against the glass and the stainless gaskets against the hardware. Then tighten the whole enchilada to the blender with the main nut (that goes on the bottom outside of the blender). Then once that's nice and tight tighten the flange that catches the blender teeth to the remaining portion of the protruding threads. Make sure you use the copper colored gasket first then the stainless washer then the stainless flange. Tighten that real good and you should be good to go.
To check if you've done it right spin the flange. If the blades spin independent of everything else you're good to blend away!
Feb 23, 2008 | Blenders
Blenders Logo
55 people viewed this question
Top Waring Blenders Experts
karen renee may
Level 1 Expert
eyecam
Are you a Waring Blender Expert? Answer questions, earn points and help others
