Question about Motorola Mobility W315 Cellular Phone
Unclock code I accidently saved text messages and dont have an unlock code.
  • trhinkle May 14, 2008
    i locked my phone and can't unlock my phone
According to the phone's manual the default unlock code is 1234 or the last four digits of your phone number. The default security code is 000000.
Posted on Jul 05, 2008
Try the default unlock code from the phone, 0000 This is a factory setting.
Posted on Feb 22, 2008
My GPS says " no detailed maps found that support routing. The Nuvi cannot be used without them." Tried resetting and no change
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
To retrieve unlock codes you need to have your satnav registered with garmin. If you haven't already registered it connect the satnav to your computer and go to https://my.garmin.com/mygarmin/customers/myGarminHome.faces and click Register your garmin device. Follow the prompts. You'll be asked to create a username and password. Write them down and keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
Creating an unlock code file for Mac:
  1. Open the TextEdit application located in the Applications folder on the Mac HD
  2. Click Format
  3. Select Make Plain Text
  4. Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  5. Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  6. Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
If you have a second maps you may also need to unlock it e.g. if the first map is USA and second is EUROPE this may also need to be unlocked
  4. Click Explore
  11. Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  15. Type gmapprom1.unl in all lower-case letters for the File name
  16. Select Save
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
Sep 25, 2010 | Garmin nuvi 205W GPS Receiver
After i updated my nuvi 255w now it is saying '' no detailed maps found that support routing'' the nuvi cannot be used without them.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Sep 20, 2010 | Garmin nuvi 255W GPS Receiver
It is just saying maps are locked
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Sep 08, 2010 | Garmin nuvi 205 GPS Receiver
Unit has lost detailed maps that support routing. Whats wrong? Nuvi cannot be used. Will not go beyond problem screen.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 15, 2010 | Garmin nuvi 255W GPS Receiver
Hello, I have a Nuvi205w...it was working fine this morning and now it is showing on the screen the following message...no detailed maps found that support routing. The nuvi cannot be used without them. Is...
To get your unlock codes you must have registered your satnav. If you haven't already done so you can by connecting your satnav to your computer. Go to www.garmin.com Click on myGarmin and then on Register Your Garmin Product. You'll have to create a username and password to register. Note them down and keep them safe as you'll need them anytime you want to update maps.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
If you have a second map on your satnav e.g. if USA is your main map and you purchased a map of Europe which you need to unlock also
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 10, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
*nuvi x70 owners with transatlantic mapping will need to follow the Creating an unlock code file instructions above for their U.S. mapping and then create another unlock file for their European maps:
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 10, 2010 | Garmin nuvi 205W GPS Receiver
I have a Garmin Nuvi 250, when I start the unit it displays "no detailed maps found that support routing". I have checked the drive and it has over 1.3 Gb used. I used the unit last weekend but it doesn't...
To retrieve unlock codes you need to have registered your satnav. If you haven't already done so connect your satnav to the computer. Go to https://my.garmin.com/mygarmin/customers/myGarminHome.faces and click Register your Garmin product. Follow the prompts. You'll have to create a username and password. Write them down and keep them safe as you'll need them again anytime you need to update your maps.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 09, 2010 | Garmin nuvi 250W GPS Receiver
Maps not found
If the maps are locked you'll need a garmin account. If you don't have one already go to www.garmin.com Click on my garmin and then on register your garmin device. Note you'll have to create a username and password. Write them down and keep them safe. You'll need them anytime you update your satnav.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 08, 2010 | Garmin nuvi 260W GPS Receiver
I get the error no detailed maps found that support routing. Hwow Do I fix this?
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device in the botton paragraph
  1. Go to www.garmin.com and log into MyGarmin. If you don't have a MyGarmin account you'll need to register your satnav to get one. To register click on MyGarmin and then on Register your garmin product. Follow the prompts.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 06, 2010 | Garmin nuvi 260W GPS Receiver
LG env2 will not save text messages
This happened to me. My problem was that i had a memory card, and i accidently put the save options for my pictures to my phone memory instead of to card memory. So it messed up my phone.
May 30, 2009 | Verizon Communications enV2 Cellular Phone
Motorola Mobility W315 Cellular Phone Logo
89 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
