Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Fridge side works, but the freezer doesn't
My Whirlpool 25.6 cu. ft. on the freezer side is not working, I feel air barley blowing out of it and it's slightly warm. The fridge part is keeping items cold. I have checked the coils and they are pretty clean. Please help can not afford a repair man!
  • 82 Answers
Hi, there is a common fault with these side by side models, the electronics fail in many ways. The first sign of failure is either due to the compressor not working or the 'evaporator' (the cold bit) ices up and air can't pass through it to cool the freezer and fridge.
You can buy a kit to repair the boards for about £30 on ebay
Look for Whirlpool repair
An engineer would charge £200 +
Hope this helps
regards
j
Posted on Sep 29, 2009
Testimonial: "Hey thank you for your help I will look into this kit. It may be a bit pricey but not as bad as a new fridge, or a repair guy! Thanks again!"
I have a maytag msd2572vew side by side refrigerator. the freezer side works fine but fridge side does not get cold. the vents in the fridge feel like no air is blowing. anyone know what's wrong?
You have a defrost problem and will need to thaw out your freezer to change the one of the bad parts and restore air flow. The other bad part is PCA (this is a control of defrost and compressor run). First bad part is a defrost thermostat link under bad and the other is the PCA which controls the defrost cycle. Unplug unit, de-ice the freezer and this will buy you time to get parts, I don't like the use of blow dryers but people use them in this case. Watch the heat, is can warp the plastic.
Good Luck
Oct 07, 2011 | Maytag MSD2572VEW (25 cu ft) Side by Side...
Freezer works, but has some ice forming and refrigerator not cooling.
The refrigerator half of a refrigerator/freezer does not produce any cold! The refrigerator is cooled by transferring air from the freezer to the fridge. The fridge temperature setting controls a flapper between the freezer and the fridge. There should be a fan which blows air from the freezer into the fridge (through the damper).
If the ice forming in the freezer is concealing the cooling coil and air can not move through the coils, then the overall result will be a warm freezer (even though there may be ice in one location) and a warmer yet fridge. This can be tested by unplugging the fridge and allowing a complete thaw. If the ice is the cause of the problem, then it should work for a short while until it freezes up improperly again
:o).
Jun 04, 2011 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
Amana 25 Cu. ft. French door Freezer Fridge quit
IN MOST CASES THERE IS A FAN THAT SENDS COLD AIR FROM THE FREEZER TO KEEP THE FRIDGE COLD. EITHER YOUR FAN MOTOR HAS GONE BAD OR YOUR THERMOSTAT IN YOUR FRIDGE IS BAD.
Feb 20, 2010 | Televison & Video
Refrigerator not cooling down. can fill air comming in but not cool air.side by side whirpol 25 cu.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
gsg
Dec 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Is the vent on the side of the crisper suppose to blow out cool air?I have a whirpool side by side..8years old
No, that vent is for the return air going back to the freezer. The vent at the top is where the freezer fan blows air into the fridge.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My freezer is fine but fridge side is warm and no air blowing
SOUNDS LIKE THE FAN FROM THE FREEZER TO THE FRIDGE TAKE OFF THE COVER TO SEE IF ITS WORKING
Sep 02, 2009 | Maytag 26 cu. ft. Wide-By-Side...
Problems with Whirlpool 21.0 cu. ft.
checklist: freezer fan running, compressor fan running, compressor running, any frost buildup on back wall of freezer. you may have to take a rag and touch the compressor to feel if its vibrating to see if its running unless you can hear it. please reply
Jun 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Amana 25. cu ft..freezer not working...making rattling noise now and then
Check the defrost timer, rotate it until a solid click is heard. If your unit starts to work replace that timer. Good Luck
Aug 05, 2008 | Amana 16.8 cu. ft. / 476 liter Upright...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
187 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
