Question about Fujitsu Siemens Computers & Internet
My fujitsu laptop recently had a new hard drive installed in it ,but i want to transfer the data i have on the old hard drive that was removed from laptop to my new hard drive. I bought the all in one coolmax converter from central computers only that there is no manual guide nor cd driver only a web site that doesnt have any information can you please tell me how to use this device
  • Fujitsu Siemens Master
  • 32,281 Answers
The Coolmax adapter is an USB hard drive adapter that can connect various types hard drives to your computer. This is used for testing and and transferring data to and from hard drives connected to the computer via the computer's USB port.
This Coolmax USB hard disk adapter can connect a 2.5-, 3.5- and 5.25-inch IDE or SATA hard disk to a PC. The black adapter box connects the hard disk, while the secondary power plug/adapter powers the drive. In the case of smaller notebook or SATA disks, the power cable is plugged directly into the adapter (as opposed to straight into the IDE hard disk).
The red USB cable, meanwhile, can be used to power hard disks directly from the host PC's bus via another USB port.
Connect the hard drive to the adapter as detailed above, power up your computer and plug the Coolmax USB cable into the conputer's USB port. The computer will detect and see this as an external drive, most likely as a E drive (the next drive letter that is available). Click on this drive and open to open the folder/s where your data is stored then select the folder/s and/or data and copy them, then open the hard drive on the computer and paste the folder/s and/or files onto the new hard drive.
Posted on Sep 29, 2009
How do I transfer data from the hard drive on a VF-16 to a new hard drive
Why do that? You can add a second drive to the computer easily without removing the one that is already in there. If it's a laptop you can get USB external drives that will act the same way. If you don't want to do that then there is software available that will transfer the data .
Oct 10, 2014 | Computers & Internet
How to remove hard drive from fujitsu n6000
On the bottom of your Fujitsu N6000 laptop, find the hard drive door to access the hard drive.
2. Remove the Screws.
3. In this step, you will either need to pry out your Fujitsu N6000 hard drive caddy, or simply remove the door.
4. Once the Fujitsu N6000 hard drive is removed the laptop, you need to remove the hard drive caddy. There are usually four screws to remove from the caddy.
5. Simply Insert the new hard drive into the caddy. Place the screws back in. Install your new Fujitsu N6000 hard drive.
Good Luck
Aug 31, 2014 | Computers & Internet
How can I transfer data between two primary hard drive after replacing one
Windows needs to be installed on the new primary hard drive and also thecomputer or laptop's device drivers plus your programs etc. to get afunctioning computer/laptop again.
Jul 09, 2012 | Toshiba Computers & Internet
Do i have to transfer all my hard drive data when installing a new desktop pc
No you don't need too, but you might want to copy all your documents, music and pictures to your new computer.
Jun 12, 2012 | Fujitsu Computers & Internet
Iintend to change my sata hard drive to a SSD hard drive.How do I format before change
When you install Windows on your new SSD hard drive you can then transfer data from your old hard drive using an USB hard drive adapter or install the old hard drive into an USB hard drive adapter case and use it as an USB external hard drive after you have transferred your data to your laptop.
When you connect the USB hard drive adapter to the laptop, the laptop will see it as an external storage device, you can then open the various folders anf files and copy them to your new hard disk.
Apr 07, 2012 | Dell Computers & Internet
I got an old laptop and I bought a new toshiba laptop I just wanna ask how do I transfer my application and files from my old laptop to a new one using external hardrive,also wat external hardrive,and also...
You can transfer the data files only from the old laptop to the new one. You cannot transfer the installed applications/software. Software are required to installed again on the new laptop afresh.
To transfer the data you can use external portable hard disk, which can be connected to the PC using any USB port (just like pen drive) and you can copy - paste the required data to the external disk just like you copy data from one partition to another. After copying the required data, you can connect the external drive to new laptop and copy the data to the new laptop. You can use external drive of any brand/ capacity. However, it is better to have an external drive with larger capacity, so that you can transfer the data in one go.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | Toshiba Computers & Internet
I recently bought a Toshiba Satalite laptop to replace the one I dropped which was also a Toshiba Satalite. I had taken out the old hard drive and installed it in the new one but now it wont do anything...
Yes it does matter. XP was configured for the old Toshiba and this will only work if both Toshiba laptops are exactly the same model.
To get your new Toshiba operating, put the new hard drive with the Vista operating system back in the Toshiba laptop.
To transfer your data from the old hard drive, purchase a USB adapter hard drive case and place the old hard drive inside this case. This will then be an external USB hard drive.
Plug this USB hard drive into the new Toshiba's USB port and it will detect it as an external storage/hard drive. You can then open the various folders and files and copy the data files to your new Toshiba.
To free up disk space on this USB hard drive, delete the Windows folder, Program Files folder and other folders that are no longer needed.
Use this hard drive as a backup hard drive etc.
Sep 11, 2010 | Toshiba Computers & Internet
I have a ibm t41 2373 3HU which has been damaged. Can I simply buy another t41 and install my hard drive in it in order to get going again, or am I being too simplistic? The hard drive is a fujitsu 13n6772...
You should be able to put the hard drive with little trouble. If Windows 2000 or later is installed on the new hard drive, it will give you the "blue screen of death" and will not operate. I explained this to another person earlier, but the bottom line is you will need to reinstall Windows. By the way, there may be a chance that your data can be salvaged from the old hard drive, but it is usually expensive. Hopefully, you kept a good (and recent) backup of all your documents, and have the software to reinstall. Be sure to have both laptops unplugged, the battery or batteries removed, and ground yourself before prodeding. Be sure the phillips screwdriver you use IS NOT MAGNETIZED.
Aug 10, 2010 | IBM ThinkPad T41 2373 Notebook
Data transfer
u either plug an external monitor or u remove the hard drive from the broken system then get an external hard disk case . conect it then to yr usb port on the mac system so yu can transfer yr data.
hope this helps
thank u
May 26, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
TRANSFER COMPLETE COMPUTER DATA
only way to do this is to swap the hard drives. Maybe you'll get lucky, and the drives will be form/fit identical..
Apr 25, 2008 | Computers & Internet
Computers & Internet Logo
348 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
