Question about IBM ThinkPad T60 Notebook
Why does my laptop beep when closing it?
Help
Ladoooooooooooooooooooooooooooooooooooo
Posted on Oct 31, 2008
  • 383 Answers
Computer Post / Beep codes Helping you with questions you may have about PC POST and beep codes.
Good Luck, Please dont for get to Vote/Thank You.
Posted on Dec 19, 2007
I have a quanta 3082 MB in a HP Pavilion zd8230us laptop when I startup it beeps constantly got any ideas? anyone
The beeps with have a pattern to them. Listen closely when you first turn the laptop on and listen for the pattern. It might be something like 1-3-2 (1 beep, wait, 3 beeps in a row, wait, 2 beeps) It will repeat for listen for a bit to make sure you have the correct pattern. Once you have that pattern got to the HP webpage, in the support section, in the search type in "beep code errors". It will give you a list of beep patterns and tell you what the problem is. It could be the RAM, it could be another problem with the motherboard; those codes are what you need to have first.
Dec 24, 2014 | HP Computers & Internet
Non stop beeping
Is your computer a Desktop or Laptop?
If a laptop maybe the battery is dead or the RAM needs replacement
If a desk top possibly the RAM needs to be replaced.
Try the above and let us know if the suggested solutions worked
Jan 11, 2013 | ASUS P5K SE MOTHERBOARD (4719543152829)
My laptop makes a loud annoying beep when its plugged in or unplugged. The cord is getting tired and often makes this noise for no apparent reason. I've tried to go into the speaker properties but...
this issue might be occurred due to weak battery or either battery is getting weak.Just remove the Battery for a while and check the result
Jun 13, 2011 | Computers & Internet
Hello,my laptop HPCOMPAQ 6735S boots with a series of continuous beeps.Plz help me to solve this problem.In touch.
hi
1. make sure that any key is stick on the keyboard,
2. you will have to remove all key, one by one until the beep sound stop.
if the problem continue then, you have to open the case and disconnect the keyboard cable from
the laptop mainboard, close the case. Then use a mini or normal size USB keyboard
hope this helped you to solve the problem
May 28, 2011 | Computers & Internet
My bosch dishwasher beeps everytime we close the door.
Better switch of till you are ready with full load. Otherwise you have to trace the beeper and disconnect it.
Apr 12, 2010 | Bosch 24 in. SHY66C05 Stainless Steel...
Screen will not come on hp pavillion 2000 laptop help
try powering the laptop on, and open/closing the lid.
this is to ensure, the closed lid catch is activating/de-activating.
you should get a beep or tone, when the lid is closed.
Or the laptop, will go into Sleep/hibernation Mode.
Also try pressing and holding the power on Button for more Than 5 seconds, This will eliminate that the laptop hasn,t gone Into sleep/hibernate Mode.
If none of this Works for You. Try removing and replacing The memory modules ( RAM ) and use 1 stick of memory in each slot individually. failing any of this. i,d suspect. Screen Inverter/tft Panel Or Motherboard Fault. Or possible graphics driver Corrupt/missing.
Mike @ Compurepair.
Oct 22, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
One long beep, two shorter beeps - HP laptop will not start up
Hi...
I had the same problem...
The solution is only temporary and you will have to reapply it after around 5 to 6 boots cuz it'll just happen again (the beep syndrome).
Just heat up the laptop by turning it on and covering its air vents with your hands.
Then after you hear the beeps turn it off.
Turn the laptop on again and immediately turn it over upside down with the lid closed ofcoarse (simply put it on its back).Hopefully you wont hear the beeps and when you open up the laptop lcd...voila display.
Jan 22, 2009 | HP Pavilion dv6000z Notebook
Acer Aspire 3680 Laptop
hi,
1, make sure that your laptop got power. how to do it ? it is easy, the power led (close to headphone jack) is on. and power button led should be on. Just in case you can't power on, please check ac adapter and power port on your laptop.
2. i assume you have power. now power it on and press f2 to got to bios. press f2 many times, it should make a beeps when you press it many times. once you get a beeps, press fn+right arrow to adjust the brightness of lcd. did you see something ? what i am looking is dark display.
If your display is dark, open the power cover (power cover is cover where you see power button), you need to remove 2 screws on that cover, on lcd hinges. After you remove power cover, you can see cable close to power button, remove it and check the display again, is it bright or still dark, if it is still dark it could be inverter or lcd.
if your power is on and you press f2 many times, it doesn't make beeps sound. it is called no post. Reseat memory and if this still not working, your motherboard is bad. if you have 2 memory installed, try 1 by 1. sometime the memory slot is bad, sometime memory is bad.
i hope this troubleshoot will help you to find out whats wrong with your laptop.
good luck
Aug 23, 2008 | Acer Aspire 3680 Laptop
Help again
Hi daisy, your notebook was beeping for a reason. If you would have noted how many beeps. Ex; (1 long + 2 short & repeating) & came here with you're description we could have come up with a better fix. However reading your current troubles suggest there is a problem with one or more devices (hardware) internally. Suggest you take the notebook to a Compaq service center for professional for repair.
So hate giving out bad news.. :-{
Luck!
Mike
Apr 06, 2008 | Compaq Evo N610C Notebook
IBM ThinkPad T60 Notebook Logo
161 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
