Acer Aspire 4520-5141 -Dual-Core Athlon 64 X2 TK-57 / 1.9 GHz - RAM 2 GB - HDD 120 GB - DVD±RW (±R D... PC Notebook
Problem for Acer Aspire 4520-5141 -Dual-Core Athlon 64 X2 TK-57 / 1.9...
When i turn on my 4520, all the led's, i.e. HDD,
By dontuknowsun on Sep 29, 2009
when i turn on my 4520, all the led's, i.e. HDD, Bluetooth, wireless, dvd drive, flashes for less than a second and then they go off...the system doesnt start at all..i need my data urgently, can some one please help...cheers!!
Solution #1
posted on Sep 29, 2009
Somewhat Helpful)
mothmanmeg
Rank: Wiz
Rating: 85%, 58 votes
has happened to me before- remove power cord, remove battery. flip laptop over, look for removable covers for memory (ram), hard drive, motherboard. you can either slide the covers off, or they have a phillips head screw (+) holding them down- you'll need a small one for this! don't lose the screws! first touch metal (lamp, pipe, whatever, to discharge static electricity from your body!) OR YOU COULD FRY SOMETHING! start with the ram sticks, they should flip up, then have a little hold-down on either end- spread (gently!) the hold downs and release the chip- then re-seat it. if there are 2, then repeat with 2nd chip. lock chips back in place (push them back down until they lock into place- parallel with the bottom of the laptop- replace cover.
next, after touching metal again, take the cover off of the hdd enclosure- see if you can release it and reseat it. you may not be able to without removing a bunch of screws- anyway, try making sure it is well seated! replace cover.
next, if you can (touch metal first!), remove cover from motherboard enclosure. examine how it's connected to the rest of the circuitry. if it plugs in, remove hold down screws- slide it out a little, and re-seat it. look for any areas that may have lost their 'smoke' (burnt, or discolored areas) see these and your mobo is probably shot! if your hdd is still good, your data is still there! you may have to replace the mobo, or get another laptop that can access your hdd, so you can re-access your data.
re-secure your mobo, and replace cover. replace battery, power cord, and try re-booting!!
no guarantees! can only try!
good luck!
Was this helpful?
Yes
No
Solution #2
posted on Oct 21, 2009
Not Rated)
villalon_sab
Rank: Apprentice
Rating: 0%, 0 votes
My acer aspire 4520 Will not come on
Was this helpful?
Yes
No
Solution #3
Not Rated)
speedypablo
Rank: Guru
Rating: 85%, 92 votes
remove your battery for about 15-20 mins. plug back in and try. If same thing occurs there may be issues with your motherboard.
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 4520-5141
Questions and Unsolved Problems for Acer Aspire 4520-5141
Do you recommend Acer Aspire 4520-5141 -Dual-Core Athlon 64 X2 TK-57 / 1.9 GHz - RAM 2 GB - HDD 120 GB - DVD±RW (±R D... PC Notebook?
Answer
Answer
I have a Goodmans Laptop which has developed a problem. I now need to re-install Windows XP but no... (More)
Answer
I have just installed my windows 7 home premium upgrade to replace vista home premium that my acer... (More)
Answer
For the past few weeks my laptop has started randomly shutting down. My battery charger wire was... (More)
Answer
i have a acer one computer and can get the camera to come up how do I get it to come up
Answer
my keypad has stopped working all other keys & the mouse work? have i turned something off
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire 4520-5141...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
