Question about Boating
I have changed fuel filters and oil and filter,on my 90hp honda
I have changed fuel filters and oil and filter, idles ok its just that it stops when going into foward or reverse ,do i need to adjust the valves its done about 1500hrs.thanks rodger
    Problem Solver:
  • 10 Answers
Fuel system possibly airlocked,depends what engine you have.
Posted on Sep 29, 2009
Runs rough dies
change the fuel filter and check the fuel pressure
May 25, 2013 | Ford Expedition Cars & Trucks
1995 honda civic dies when you stop occasionally.
check the throttle lines ,set idle just above stalling point if need be
Oct 22, 2012 | 1995 Honda Civic
1999 Honda VTR 1000 F Firestorm will not idle
Hi, Corey and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
98 honda vtr 1000 wont start SuperHawk Forum
VTR1000f Superhawk idle problem
Honda VTR1000F Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VTR1000F Firestorm Owner Manual
Sep 17, 2012 | 1999 Honda VTR 1000 F Firestorm
I recently purchased a 1978 Honda Goldwing. It had some old gas in the tank so I removed the old gas and replaced the fuel filter. The bike was idling fair before now it's extremely high. Does this...
If the bike was idling OK when you ran it on the old gas, maybe the carbs were adjusted while the old gas was in the tank. The new gas could have cleaned the fuel system some and that's why your idle jumped. The fuel filter will definitely not cause your idle to go higher so no need to worry there.
Jun 28, 2011 | 1978 Honda GL 1000 (K3)
2005 honda element won't idle
COULD BE STOPPED UP FUEL FILTER.CHECK FUEL PRESSURE SHOULD BE 48 PSI. IF LOWER HONDA ADVISE TO REPLACE FUEL FILTER.YOU HAVE TO REMOVE FUEL PUMP THROUGH ACCESS PANEL FROM THE FLOOR.IF FUEL PRESSURE OKAY.REPLACE AIR FILTER.REPLACE SPARK PLUGS IF YOU HAVE OVER 110000 MILES ON THEM.IF SPARK PLUGS BEEN CHANGED ALREADY.IF ENGINE STILL WONT CRANK AND IDLE.CODE SCAN FOR A FAULTY IDLE AIR CONTROL VALVE.
May 12, 2011 | 2005 Honda Element
1996 90hp mercury idles rough
Try removing plug clean regap, change fuel filter add some carberator cleaner and moisture eleminator to the gas.
Aug 22, 2009 | Light Outboard Motor Boat Bass Fishing...
Oil light keeps coming on at an idle
ok. oil ight is probably nothing more than a faulty pressure switch.You can have pressure checked at same screw in port. 15psi is ok...just. very cheap to replace. Ign control module is probably the cut-out fault. You cant really test it; repair by substitution is the trick.
Apr 08, 2009 | 1997 Pontiac Sunfire
I have a 95 honda accord sputers at stop
getting oil on my plugs on 97 honda accord any help or suggest
Mar 17, 2009 | 1995 Honda Accord
Honda cbx 6 clutch rattle at idle and low rev hirendouse
Glazed alternator clutch plates? Kind of a ratcheting sound? Common when oil wasn't changed or sitting unused too long.
1. Easy fix - drain oil, remove filter. Add diesel fuel to crankcase. Turn engine over. let sit and drain. Refill with new nonsynthetic oil and replace filter. Warm up. Drain, remove filter. Refill with fresh nonsynthetic oil, and install new filter.
2. Harder, but better. Remove plates and clean or replace them.
Mar 04, 2009 | 1982 Honda CBX
Boating Logo
54 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
