Question about Nikon D70s Digital Camera
Shutter stays open after getting ''err'' message.Im at sea and cannot send in for repairs.What can I do myself please??
  • 90 Answers
To go the setting of the camera and reset the setting.....
Posted on Sep 29, 2009
  • Nitin Luchmeeparsad Sep 29, 2009
    you need to reset the camera to factory settings
My Nikon D3200 says shutter error can I fix this issue myself?
hi,
did you charge your battery full ? if the battery is not charged enough, it will not drive the shutter opener motor perfectly, and if any type of dirt or friction on the shutter drive gears this will happen, please check the shutter movement by removing the lens.
Feb 23, 2015 | Nikon D Cameras
Err msg on D80. Shutter works, but no images are saved per message "Folder" contains no images". SD card is camera formatted and battery freshly charged. All Card, Battery, lens, and camera body contacts...
I occasionally get an ERR message on my D-90 but when this happens, I can't get anything to work. I fix it by turning the camera off and back on. You probably have already had it repaired by now, but before I would send mine in, I would have first replaced the SD card on the possibility that it was somehow corrupted. if that didn't help, I'd contact Nikon support and see what they might have to say. Nikon support does not have an outstanding reputation but I have found them very helpful when I've had problems. It's worth a try.
Feb 02, 2014 | Nikon D80 Digital Camera with 18-135mm...
I get "Err" on the
The ERR message indicates a camera malfunction. In my D-90 manual it says that it can be cleared by releasing the shutter. The only way to do that is to turn the camera off and back on. Rarely, that won't work and you have to remove and reinstall the battery.
The manual also says that it this have frequently or persist to contact a Nikon authorized service center. I would contact Nikon tech support at www.Nikon.com and discuss the problem them before contacting an authorized service center.
Jan 25, 2011 | Nikon D50 Digital Camera
My d90 flashes an err sign somtimes when i shoot at manual mode.. but when i change my apperture and shutter speed setting, it will not appear anymore. Even at auto mode sometimes it flashes an err. Does...
Try shooting in manual mode with lens set at maximum (wide open) aperture. Then try at a smaller f-stop, say 5.6 or 8. If the error message appears when your lens is set to the smaller aperture, you could have a lens problem. Try another lens using the same test. If a known good lens gives an error message, then the problem is in the body. Also try zooming to different focal lengths and see if your 18-105mm gives the error at particular focal lengths. An error here would indicate a lens problem. In any case, your lens or body would have to be repaired by a professional as these repairs require major disassembly and re-calibration.
Nov 19, 2010 | Nikon D90 Digital Camera with 18-105mm...
Have a canon rebel EOS 20D that registers an error 99 after I take one frame and then won't allow another one to be taken until I turn camera on then off again. Does this require factory repair or is there...
Hi LLFraserny,
You can probably try to isolate the error 99 first.
To isolate the cause of the issue, do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 30 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera will need to be serviced. If the message does not appear, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
One last item to check before sending camera to Canon service is the alignment of the shutter. Life the mirror and visually inspect the shutter curtain. If each segment is not completely straight, touch it lightly with your blower bristles and try to pop it back into alignment.
Hope this helps,
Andrew
Apr 09, 2010 | Canon Photography
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
Error msg
Hello!
Southern Photo Technical Service is a Authorized Service Center for NIKON.
You have a shutter failure!!
We do service the camera model you mentioned and the standard cost to Clean, Lube, Repair and Adjust all functions to meet manufacturers
specifications is $169.00 plus return shipping.
All repairs have a SIX MONTH WARRANTY!
Include a copy of this reply and
receive a 5% INTERNET discount on your repair!!
Bring it in, or
Pack your equipment securely and insure it properly.
Send it to:
37 NE 167th Street
N. Miami Beach, Florida 33162
305-653-7355
May 28, 2009 | Nikon N80 35mm SLR Camera
Error blink in place of shutter indicator
I AM SAGHA REPAIRER FROM MUMBAI I THINK THERE ARE PLENTY OF REASONS SHOWING ERR ON TOP DISPLAY BUT IF ERR IS SHOWING JUST BY TOUCHING THE SHUTTER RELEASE BUTTON THEN THE MAIN BOARD IS DEFECTIVE.IF ANY MECHANICAL ACTION OCCURS AFTER PRESSING SHUTTER RELEASE BUTTON AND THEN ERR APPEARS THEN THE FAULT COULD BE OF SHUTTER & APERTURE BLOCK.I THINK ALL THESE SOLUTIONS ARE FOR EXPERTS AND NOT FOR GENERAL USERS IF ANYBODY FINDS THEM USEFUL LET ME KNOW & ALL THESE ARE BASED ON MY OBSERVATION ABOUT FAULTY CAMERAS.
May 15, 2009 | Nikon D80 Digital Camera with 18-135mm...
Fujifilm E900 camera zoom does not function!
If the shutter and Zoom function both do not operate, you need to send the camera to an authorised repair center. Was the camerra exposed to salt/sea air? If so, you can take a soft rag and gently wipe around the lens area where it meets the body, remove the battery, reinstall the battery and try it. If not, send it in.
Mar 20, 2009 | Fuji FinePix E900 Zoom Digital Camera
ERR MESSAGE, NIKON D2X
the only time i have ever seen this message on my D2x is when the lens is not all the way snapped on. try re-seating the lens.
Dec 25, 2008 | Nikon D2X Digital Camera
Nikon D70s Digital Camera Logo
43 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
