Question about Kenmore Elite 45986 Front Load Washer
Filling up with water
Our washer keeps filling up with water when not running. Usually it starts after doing a heavy load like jeans. For abour 3 or 4 days each morning it has water in the tub about 2 inches. Then it quits if you don't check it daily and drain it it will fill up. lately it keeps filling and needs drained daily.
    President:
  • 878 Answers
Jimbo, you are going to need a new inlet valve. This is very easy to change out. Remove the 3 torx screws in the back for the top. Slide it off toward the back. The valve will be on the inside top left. Two quick connect harnesses, a couple of hose clamps and your done. I don't have the part number on hand but you can find it on the tech sheet located behind the bottom panel. Three screws to take that off. Or you can go to repairclinic.com, enter your model number and hunt it down from there. Once you change the valve, your leaking problem will be over. Catriver.
Posted on Dec 19, 2007
    Sergeant:
    Champion:
  • 262 Answers
Replace water inlet valve that your problem ive run into this quite a bit doing warranty work
Machine keeps filling up, replace pressure switch, still nohting, keeps filling up?
Hello dwl770 - If your washer won't stop filling up with water and overflows the tub, check for one of these problems:
1) Turn off the electricity to the washer. If the water *stopped* filling when power was disconnected, the problem would usually be in the control system of the machine. If the water still continues, then the plunger in the water valve is either stuck open or slow to close. Try turning the water faucets off and on a few times. This small joltmight unstick the water valve. If not, it will need replacing.
2) There could be a problem with the water level switch. Call in a professional.
3) There is a pressure switch hose that is attached to an air dome. This switch tells the washer that there is water in the tub and allows the agitator to start.
- Remove the control panel and you will notice a small hose. See if it popped off of the air dome. If it did, secure it with a zip tie.
If water flow continues, but drains out immediately, then raise the drain hose above the highest water level line of the tub. Do not seal the drain hose to the discharge pipe. This could cause a siphoning action.
Sep 30, 2012 | Frigidaire FEX831CS Top Load Stacked...
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
I get an NF error code and the washer sounds like it's filling, but never does, and then there is water in the detergent dispenser.
Hi
Thanks for using FixYa. Error NF means No Fill. The washer has tried to fill but was unsuccessful. NF indicates No Flow. There is something that is interrupting the inbound flow of water to the washer, either hot or cold. Sometimes this happens when water service in the area is interrupted, creating an air pocket that causing the water valve not to sense water. Try running the diagnostic test by:
  • Press the delicates and heavy soil keys together for 3 seconds.
  • You are in the service mode.
  • Now, press wrinkle free key, cold water should start entering.
  • Then, press the cotton sturdy and hot water should flow.
  • To exit the test mode, either unplug the machine or press the delicate and heavy soil again for 3 seconds.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 22, 2010 | Samsung WF328AA Front Load Washer
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
Doesn't fill all the way
the solution to the problem was....a few days before we noticed the washer was not filling all the way, the plumber had come over to clear our pipe, because it was not draining. He had tightened the clamp we were using to keep the pipe in place too tightly, it was air tight and it was creating a vacuum and siphoning the water out when it got to a certain level. We took the clamp off since there was no longer a need for it and the washer fills up and drains as it should.
Dec 10, 2008 | Admiral AAV7000A
The washer overflows with water. help
make sure the water level hose is connected to the tub and the switch,you can remove the front panel to and flip up the top check,let me know now you do-mike
Dec 02, 2008 | Washing Machines
Kenmore heavy duty 70 series extra capacity
This could be from a few things. First test. Turn on the washer to fill it up about 3/4 the way. Now turn it back off. Does the water stop? No? You probably have a bad water valve. Replace it. Yes? Listen for the sounds of running water or look for water on the floor. Do you see/ hear this? Yes? Your pressure hose has probably come off, reattach it. If it does turn off and there is not further sounds or leaking water, you probably need to replace your pressure switch.
Jun 15, 2008 | Kenmore 24032\24036 Top Load Washer
Filling With Water
If the water continues when electricity is discontinued the soleoid valve is jammed open, a fleck of rust or something, not designed to be repaired, it is easier and cheaper to replace. they are a standard part that fits 99% of all washers ~$10-20 at the local parts guy.
Usually only the cold solenoid has failed. it gets used more often.
If you are like me and only use cold water, swap the hoses on the taps, and swap the wire connectors on the solenoid valves, so the former hot is now cold, and you will get about the same number of years before you have to replace anything
May 06, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
145 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
