Question about Konica Minolta PagePro 1400W Laser Printer
I refill konica minvolta 1400w toner but print page is not good it is shaded in between line also coming
  • vgroups64 Sep 29, 2009
    if u want to improve the blog add some proper content nothing in this blog why are posting this blog in fixya this is good site
    if u know the answer kindly send otherwise keep silent
I am printing pictures and they have a white line running through them, what can i do
Does the white line appear in all colors? Or is it limited to just one color? Try printing some full pages of each color (use a gray scale to save on toner, 50% shade should do). If the line appears in only one color, then replace that toner cartridge. If all three colors, then replace the drum.
Nov 25, 2014 | Konica Minolta Magicolor 1600W Printer
Toner error
With very few exceptions, modernprinters need a full set of cartridges to even try and print.
the reasons for this are not quite an sinister as you may think. Many printers use a little colour and them finally apply black to create a very deep shade of black. printers also periodically do small cleans, checks and calibrations to keep the printer running as efficiently as possible. In order for many of these to be performed they need a cartridge of each colour to avoid damage etc.
Feb 27, 2014 | Konica Minolta PagePro Office Equipment &...
Hp 2600n line
after you have printed a few pages switch the machine off just as the paper leaves the fuser. then open the front cover and take a close look at the image transfer belt ( black plastic conveyor type belt)
use a torch shone accross the belt to better light the error- if you can see these Green/yellow/cyan lines on the belt then theres a good chance its coming from the toner units- ( also try print quality troubleshooting pages in the menus under diagnostics.look at the individual colour pages and look for any lines or Uneveness about the shaded colour) replace whichever toner is not printing correctly
Jan 22, 2014 | HP Color LaserJet 2600n Printer
White vertical lines down printed documents...
hello
you have to check the fuser film, it may be not good
regerds and dont forget to rate mt answer
Feb 19, 2010 | Konica Minolta PagePro 1400W Laser Printer
Dirty prints
You have not stated if it is a laser or inkjet.
On laser machines this can usually be one/both of.
1 Faulty toner / poor quality refill (sometimes happens as toner runs low. (Replace toner)
2 Wear in the drum unit (Replace Drum unit)
Jul 01, 2009 | Brother Office Equipment & Supplies
My HP1020 prints black shade throughout the page
You have bad toner or a bad toner cartridge. Get a new cartridge.
Mar 12, 2009 | HP LaserJet 1020 Printer
Konica minolta 9J04 refill
Unfortunately you have to replace the chip or to reset it after the toner refill. The chip keeps count of the number of pages that was printed with that toner, so there is no easy way out.
Chip reset device for Konica Minolta Bizhub and CF imaging units
http://www.chipreset.eu
Nov 20, 2008 | Konica Minolta PagePro 1350W Laser Printer
Magicolor 2400W print fades on right side of page
Have you tried cleaning the leans at the bottom of the printer? Open the cover, pull out the drum. Under it is a long, narrow piece of glass. If it gets dusty or toner accumulates on it, it will cause streaks in the printing. If this is dirty, take a clean, soft cloth and very gently wipe it off.
May 12, 2008 | Konica Minolta magicolor 2400 Laser...
Konica 1400 w printer issue
buy a new printer thats not garbage.
Mar 17, 2008 | Computers & Internet
Random lines printed on extreme right side of page
i had that happen when toner leaked out and got all over the place...try cleaning up any stray toner [even in the places they tell you not to]
Nov 24, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta PagePro 1400W Laser Printer Logo
220 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
