Question about Samsung HP-R5012 Television
Horizontal lines and colored snow
I have a Samsung Plasma HP-R5012 and Im receiving several horizontal lines with color snow (on top and bottom of screen), the middle is clear. Anyone know what that could be?
    President:
  • 267 Answers
HI,
There are three likely causes for horizontal lines on your plasma TV.
1) A bad incoming signal. Do you see the lines on every channel, and from every source? If you play a DVD or videotape and the lines are still there, then that rules out your cable television or satellite box if you have one. However, if you find that the lines disappear when you play a DVD, I would contact the support desk for your cable or satellite provider.
2) A burn-in. This is caused by things like excessive use of video games or watching TV programs that have static (unchanging elements) like icons or scores or even lines. Have you tried using the built-in burn-in cleanup utility that is part of most Samsung plasma sets? Even if you suspect that the problem is not caused by burn-in i would recommend you try this just to see if it has an effect.
3) A problem with the electronics. Here you have to asnwer the following: is your set still under warranty? Most plasmas come with a one- or two-year warranty. If you paid for the set with certain types of credit cards, your warranty may be extended by a year or so: call your credit card.
If the set is still under warranty, immediately arrange for a repair and keep a record of all dates, names, phone numbers, and promises made. Don't accept any statement that five horizontal lines is "acceptable" to the maker; a pixel here or there may be excused but not a serious problem like yours.
Finally, if your set is NOT under warranty, consider carefully whether to make a repair or buy a new set. New set prices have dropped sharply, and the difference between a repair and a new set may not be significant. Of course, you can wait until the set fails.
thank you,
vijay
Posted on Sep 29, 2009
Horizontal lines plasma screen
The details you provided here is not enough to provide a solution to this problem. Check http://electronicshelponline.blogspot.com/ This link. Pull up older posts there. Defective screen shots to plasma TVs are given. Compare them with your TV, and try to understand the fault. Most plasma screens will have similar circuit configuration, irrespective of brands and models. The only difference will be the number of circuit boards it contains according to its screen size.
May 28, 2013 | Samsung HP-R5012 Television
Horizontal lines high and low on screen top and bottom also bright flecks of red color
Are the bright flecks of red color where it is supposed to be black? That could the one of the sustain boards going out also could cause the horizontal lines too depending on the board - worst case scenario - would be a bad ribbon cable on the panel itself - best case scenario - plug the tv in to an outlet that is by itself to isolate interference as a possibility.
Thanks,
phatcav
Feb 05, 2011 | Samsung HP-T4254 42 in. Plasma Television
I have a 5 yr old Samsung HP-R5012 Plasma Display Television. A display model. Last night, horizontal lines appeared, then, the top half of the screen went black, with color pink and blue surrounding the...
All plasma an lcd TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Aug 11, 2010 | Samsung HP-R4262 42 in. Plasma Television
Colored "snow" vertical line an inch thick on Samsung plasma
That is the sustain and buffer boards. Try to find a repair shop to repair on the component/board level because the cost of new boards out weighs the replacement cost.
Best Regards,
Beach TV Repair
Jul 04, 2010 | Samsung PN50A450 50 in. Plasma HDTV
Samsung Plasma Lines and Colors on Screen
yes it can fix. its only loose connections from LCD connectors. trust me. romsky79@yahoo.com
May 29, 2009 | Samsung HP-R4272 42 in. Plasma HDTV
Samsung Plasma TV has horizontal lines of colored dots
I have the same problem, currently searching for a solution. Have you resolved your problem yet? Looking to repair myself, any tips or ideas that you have/expirenced would be greatly appreciated. Thanks, Todd
Apr 10, 2009 | Samsung SPN4235 42 in. Plasma HDTV
first is it still under warranty through the manufacturer samsung is verry well with wanrranties
It sounds like it is most likely the plasma gas itself and in that case it would cost way more than what you could purchase another one for.
by the time you have a tech come out and fix the plasma gas tube itself yould be looking well over 1000
Mar 30, 2009 | Samsung HP-R4272 42 in. Plasma HDTV
Samsung HP-R5012 Television Logo
472 people viewed this question
Henry  Thomas
Henry Thomas
